Use check_snmp with multiple OID's
kevinkenny
Post by kevinkenny »
The help for check_snmp says I can return metrics for more than one OID, for example:
check_snmp -H 217.69.47.170 -P 2c -C public  -o .1.3.6.1.4.1.9600.1.1.1.1.15.2.67.58 -o .1.3.6.1.4.1.9600.1.1.1.1.18.2.67.58 -l DiskReadBytesPerSecond -l DiskWriteBytesPerSecond
This works fine and I get:
SNMP OK - DiskReadBytesPerSecond 5074767 DiskWritesBytesPerSecond 4978109 | DiskReadBytesPerSecond=5074767 DiskWritesBytesPerSecond=4978109
I now need to set warning and critical levels for each of these values because we have a scenario where we want warnings and critical notifications set at different thresholds for reads and writes.
I tried a few different combinations of the -w and -c switches including:
-w 10000 10000 -c 20000 20000
-w 10000 -w 10000 -c 20000 -c 20000
But I only every get a WARN or CRITICAL for the DiskReadBytesPerSecond. I have a test that purposely writes a large amount of data to the disk whilst keeping the reads very low but I can never trigger a WARN/CRITICAL for writes. It seems that only the first value is checked.
Is this possible or am I doing it wrong? :|
Is this possible?
kevinkenny
Re: Use check_snmp with multiple OID's
I managed to solve this. The trick is to use quoted comma separated values
-w "10000,15000" -c "20000,35000"
:D
