I try to find a way to check openvpn when the vpn service use udp mode.
I don't find a good solution with some searchs, it seems we can use "check_udp" but I don't find the right command and which information we can retrieve.
Many thanks for any help or tricks.
check openvpn with udp mode
Re: check openvpn with udp mode
Ok, I found the solution, I need just to enable the management interface on openvpn config ("management <ip> <port> <password file>" on config file) and after that, I can use the nagios scripts we can found on nagios exchange like check_openvpn.pl.
Hope it helps someone
Glad it's working for you, thanks for posting the solution!
