I'm doing the preflight check after trying to add a new service to monitor with Nagios (which I can't seem to get going) and I stumbled on the fallowing error:
I find it strange once I define RHEL_Destruir in another file which is processed before, called hosts1.cfgProcessing object config file '/usr/local/nagios/etc/objects/service.cfg'...
Error: Could not find any host matching 'RHEL_Destruir' (config file '/usr/local/nagios/etc/objects/service.cfg', starting on line 20)
Error: Could not expand hostgroups and/or hosts specified in service (config file '/usr/local/nagios/etc/objects/service.cfg', starting on line 20)
here is service.cfg:
# Service definition
name servico-generico ; The 'name' of this service template
active_checks_enabled 1 ; Active service checks are enabled
passive_checks_enabled 1 ; Passive service checks are enabled/accepted
parallelize_check 1 ; Active service checks should be parallelized (disabling this can lead to major performance problems)
obsess_over_service 1 ; We should obsess over this service (if necessary)
check_freshness 0 ; Default is to NOT check service 'freshness'
notifications_enabled 1 ; Service notifications are enabled
event_handler_enabled 1 ; Service event handler is enabled
flap_detection_enabled 1 ; Flap detection is enabled
process_perf_data 1 ; Process performance data
retain_status_information 1 ; Retain status information across program restarts
retain_nonstatus_information 1 ; Retain non-status information across program restarts
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL SERVICE, JUST A TEMPLATE!
use servico-generico
host_name RHEL_Destruir
service_description someremoteservice
is_volatile 0
check_period 24x7
max_check_attempts 3
normal_check_interval 3
retry_check_interval 1
contact_groups Administrador
notification_interval 120
notification_period 24x7
notification_options w,u,c,r
check_command check_users
name host-generico ; The name of this host template
notifications_enabled 1 ; Host notifications are enabled
event_handler_enabled 1 ; Host event handler is enabled
failure_prediction_enabled 1 ; Failure prediction is enabled
register 0 ; DONT REGISTER THIS DEFINITION - ITS NOT A REAL HOST, JUST A TEMPLATE!
use host-generico
name RHEL_Destruir ; IP
address 128.1.5.20
check_period 24x7 ; By default, Linux hosts are checked round the clock
check_interval 5 ; Actively check the host every 5 minutes
retry_interval 1 ; Schedule host check retries at 1 minute intervals
max_check_attempts 10 ; Check each Linux host 10 times (max)
check_command check-users ; Default command to check Linux hosts
notification_period workhours ; Linux admins hate to be woken up, so we only notify during the day
; Note that the notification_period variable is being overridden from
; the value that is inherited from the generic-host template!
notification_interval 120 ; Resend notifications every 2 hours
notification_options d,u,r ; Only send notifications for specific host states
contact_groups admins ; Notifications get sent to the admins by default
name 128.1.0.19 ; IP
check_command check-host-alive ; Default command to check Linux hosts
# Definitions for monitoring the local (Linux) host
cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
cfg_file=/usr/local/nagios/etc/objects/hosts1.cfg
cfg_file=/usr/local/nagios/etc/objects/service.cfg
If anyone can land me a hand I would appreciate.
Thank you
