h.sabrey
Posts: 30 Joined: Sun Jun 14, 2015 7:18 am
Post
by h.sabrey » Mon Jul 20, 2015 6:10 pm
hello friends,
after successfully installing the nagios and being able to login remotely, the nagios says this comment
Unable to get process status
how to inspect the reason?
thanks in advance...
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Mon Jul 20, 2015 6:26 pm
How did you install Nagios, did you follow any guides?
What version of Nagios? What OS have you installed it onto?
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
jolson
Attack Rabbit
Posts: 2560 Joined: Thu Feb 12, 2015 12:40 pm
Post
by jolson » Tue Jul 21, 2015 2:09 pm
Is SELinux running?
Any errors in your http logs?
cat /var/log/httpd/error_log
cat /var/log/httpd/access_log
Twits Blog
h.sabrey
Post
by h.sabrey » Fri Aug 28, 2015 6:15 pm
Hello Gents,
sorry for the long time till reply;
for the SELinux it is enabled as follows:
[root@localhost ~]# sestatus
SELinux status: enabled
SELinuxfs mount: /selinux
Current mode: enforcing
Mode from config file: enforcing
Policy version: 24
Policy from config file: targeted
what to do ??
Post
by Box293 » Sun Aug 30, 2015 6:36 pm
I would put SELinux into permissive mode, it causes a lot of headaches:
sed -i 's/SELINUX=enforcing/SELINUX=permissive/g' /etc/selinux/config
setenforce 0
Privacy Policy .
