nagios_objects
Volcharge
nagios_objects
Post by Volcharge »
Hi,everybody:
In /usr/local/nagios/etc/objects/ I created hosts.cfg and services.cfg
But I found one question: I can't define one more host,but I need to minitor 7 linux_hosts in my company.
HOW CAN I DEFINE ONE MORE LINUX by modifying hosts.cfg and services.cfg?
THX THX THX!!!! :D :D :D :D :D :D :D
It's the hosts.cfg:
use linux-server
host_name xianyuan-Linux
alias xianyuan-Linux
address 192.168.1.9
define hostgroup{
hostgroup_name hanminfo-servers
alias hanminfo servers
members xianyuan-Linux
it's the service.cfg
use local-service
service_description Current Load
check_command check_nrpe!check_load
use local-service
service_description Check Disk sda1
check_command check_nrpe!check_sda1
hsmith
Agent Smith
Re: nagios_objects
Post by hsmith »
Volcharge wrote:Hi,everybody:
It's the hosts.cfg:
use linux-server
address 192.168.1.9
define hostgroup{
use local-service
use local-service
Hi Volcharge,
You can add as many
        use                     linux-server
        host_name               something
        alias                   something
        address                 so.me.ip.addr
As you want in the file. The list of files that nagios grabs stuff from can be found in /usr/local/nagios/etc/nagios.cfg
cfg_file=/usr/local/nagios/etc/objects/commands.cfg
cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
cfg_file=/usr/local/nagios/etc/objects/templates.cfg
cfg_file=/usr/local/nagios/etc/objects/hosts.cfg
cfg_file=/usr/local/nagios/etc/objects/something.cfg
cfg_file=/usr/local/nagios/etc/objects/whatever.cfg
cfg_file=/usr/local/nagios/etc/objects/somethingelse.cfg
cfg_file=/usr/local/nagios/etc/objects/supertopsecretawesomehosts.cfg
I hope this helps clear some stuff up for you.
Former Nagios Employee.
me.
