There is a command in nrpe.cfg : /usr/local/nagios/libexec/check_http -I 127.0.0.1
It's critical because I have a virtual directory, my website place is: 127.0.0.1/zmaze
so I tried to modify the command as : /usr/local/nagios/libexec/check_http -I 127.0.0.1/zmaze
but it doesn't work.
Can someone tell me how to solve this problem?
THX THX THX THX THX
nagios_nrpe.cfg
Re: nagios_nrpe.cfg
How about /usr/local/nagios/libexec/check_http -I 127.0.0.1 -u /zmaze ?Volcharge wrote:There is a command in nrpe.cfg : /usr/local/nagios/libexec/check_http -I 127.0.0.1
THX THX THX THX THX
Former Nagios Employee.
me.
me.
