Getting "Error: Could not read host and service status".
Re: Getting "Error: Could not read host and service status".
Sounds good, let us know your results once you look into httpd.
Finally was able to circle back, changing script execution in my php.ini's did not resolve this. Replacing the HD isn't a realistic option, any other ideas?
- Box293
- Too Basu
What Operating System is Nagios installed on?
Following up on this thread. I made changes to httpd.conf and also added a MySQL backend, hoping things would clear up. But I still get these errors and have a serious need to make them go away for the sake of keeping Nagios as our monitoring solution. Any other ideas?
What OS do you have Nagios installed on? Additionally, what other addons / components are you using in conjunction with Nagios?
As you've made changes to httpd.conf, and added a SQL backend, it really becomes harder to further troubleshoot where the issue is.
While we made Core, we can't provide support for external products such as Core running a SQL backend.
Please post your httpd.conf, and entire conf.d folder for us to look at. Also post your apache error and access log for us to look at.
This is on Ubuntu 14.04.
Only change I made in Apache was to the timeouts. This issue started months before I added MySQL and its still a problem. So I do not think MySQL is related. I added in the graphing plugin, pnp4nagios as well. Here are the entries to my configs.
commands.cfg
nagios.cfg
Again this timeout issue existed before all of this was added.
commands.cfg
# 'process-host-perfdata' command definition
command_name process-host-perfdata
command_line /usr/bin/printf "%b" "$LASTHOSTCHECK$\t$HOSTNAME$\t$HOSTSTATE$\t$HOSTATTEMPT$\t$HOSTSTATETYPE$\t$HOSTEXECUTIONTIME$\t$HOSTOUTPUT$\t$HOSTPERFDATA$\n" >> /var/lib/nagios3/host-perfdata.out
# 'process-service-perfdata' command definition
command_name process-service-perfdata
command_line /usr/bin/printf "%b" "$LASTSERVICECHECK$\t$HOSTNAME$\t$SERVICEDESC$\t$SERVICESTATE$\t$SERVICEATTEMPT$\t$SERVICESTATETYPE$\t$SERVICEEXECUTIONTIME$\t$SERVICELATENCY$\t$SERVICEOUTPUT$\t$SERVICEPERFDATA$\n" >> /var/lib/nagios3/service-perfdata.out
command_name process-service-perfdata-file
command_line /usr/lib/pnp4nagios/libexec/process_perfdata.pl --bulk=/var/lib/pnp4nagios/perfdata/hosts
command_name process-host-perfdata-file
command_line /usr/lib/pnp4nagios/libexec/process_perfdata.pl --bulk=/var/lib/pnp4nagios/perfdata/services
broker_module=/usr/lib/check_mk/livestatus.o /usr/lib/nagios/mk-livestatus/live
broker_module=/usr/lib/ndoutils/ndomod-mysql-3x.o config_file=/etc/nagios3/ndomod.cfg
event_broker_options=-1
I have 920 hosts and 7200 service tests.
I enabled use_large_installation_tweaks=1 as well just now.
Enabling tweaks did not work. Once the error presents itself, hitting refresh 5-6 time usually loads the page. Mgmt is starting to frown on this though. ;/
I was watching the nagios.log and what I am seeing is this;
Services keep stopping and restarting themselves.
[1462273898] Warning: Return code of 255 for check of service 'Check IOstat' on host 'MOBILE-U64-926' was out of bounds.
[1462273898] Warning: Return code of 255 for check of service 'Check IOstat' on host 'MOBILE-U64-141' was out of bounds.
[1462273898] Warning: Return code of 255 for check of service 'Check System Load' on host 'MOBILE-U64-141' was out of bounds.
[1462273898] Warning: Return code of 255 for check of service 'Git Sync Delay' on host 'MOBILE-U64-141' was out of bounds.
[1462273899] Warning: Return code of 255 for check of service 'Check System Load' on host 'MOBILE-U64-82' was out of bounds.
[1462273899] Warning: Return code of 255 for check of service 'Disk Usage - /' on host 'MOBILE-U64-82' was out of bounds.
[1462273899] Warning: Return code of 255 for check of service 'Builder Java' on host 'MOBILE-U64-83' was out of bounds.
[1462273899] Warning: Return code of 255 for check of service 'Puppet Last Run' on host 'MOBILE-U64-83' was out of bounds.
[1462273899] Warning: Return code of 255 for check of service 'Git Sync Delay' on host 'MOBILE-U64-926' was out of bounds.
[1462273899] Warning: Return code of 255 for check of service 'Check Disk' on host 'MOBILE-WIN-46' was out of bounds.
[1462273908] Warning: Return code of 255 for check of service 'Git Sync Delay' on host 'MOBILE-U64-82' was out of bounds.
[1462273918] Warning: Return code of 255 for check of service 'Builder Java' on host 'MOBILE-U64-519' was out of bounds.
[1462273918] Warning: Return code of 255 for check of service 'Check Memory Usage' on host 'MOBILE-U64-83' was out of bounds.
[1462273918] Warning: Return code of 255 for check of service 'Check IOstat' on host 'MOBILE-U64-874' was out of bounds.
[1462273918] Warning: Return code of 255 for check of service 'Puppet Last Run' on host 'MOBILE-U64-926' was out of bounds.
[1462273918] Warning: Return code of 255 for check of service 'Check System Load' on host 'MOBILE-U64-83' was out of bounds.
[1462273922] Caught SIGTERM, shutting down...
[1462273922] Successfully shutdown... (PID=24279)
[1462273922] ndomod: Shutdown complete.
[1462273922] Event broker module '/usr/lib/ndoutils/ndomod-mysql-3x.o' deinitialized successfully.
[1462273923] livestatus: Socket thread has terminated
[1462273923] Event broker module '/usr/lib/check_mk/livestatus.o' deinitialized successfully.
[1462273939] Nagios 3.5.1 starting... (PID=32651)
[1462273939] Local time is Tue May 03 04:12:19 PDT 2016
[1462273939] LOG VERSION: 2.0
[1462273939] ndomod: NDOMOD 1.4b9 (10-27-2009) Copyright (c) 2009 Nagios Core Development Team and Community Contributors
[1462273939] ndomod: Successfully connected to data sink. 0 queued items to flush.
[1462273939] Event broker module '/usr/lib/ndoutils/ndomod-mysql-3x.o' initialized successfully.
[1462273939] livestatus: Livestatus 1.2.2p3 by Mathias Kettner. Socket: '/usr/lib/nagios/mk-livestatus/live'
[1462273939] livestatus: Please visit us at http://mathias-kettner.de/
[1462273939] livestatus: Hint: please try out OMD - the Open Monitoring Distribution
[1462273939] livestatus: Please visit OMD at http://omdistro.org
[1462273939] livestatus: Warning: environment_macros are enabled. This might decrease the overall nagios performance
[1462273939] livestatus: archive path /var/log/nagios3/archives
[1462273939] livestatus: Finished initialization. Further log messages go to /var/log/nagios3/livestatus.log
[1462273939] Event broker module '/usr/lib/check_mk/livestatus.o' initialized successfully.
[1462273939] Finished daemonizing... (New PID=32654)
