brandon
Posts: 30 Joined: Wed Aug 19, 2015 4:10 am
Post
by brandon » Wed Nov 04, 2015 4:08 am
when using CheckFiles for monitoring file size:
check_nrpe -H 192.168.1.10 -c CheckFiles -a file="c:\\test\test.txt" "critical=size>100k" "perf-config=size(unit:M)" "detail-syntax=${status}%(file) = %(size)"
or
check_nrpe -H 192.168.1.10 -c alias_file_size -a file="c:\\test\test.txt" "critical=size>100k" "perf-config=size(unit:M)" "detail-syntax=${status}%(file) = %(size)"
Output:
Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option)
The same topic:
https://support.nagios.com/forum/viewto ... =7&t=31926 , but for me does not work
hsmith
Agent Smith
Posts: 3539 Joined: Thu Jul 30, 2015 11:09 am
Post
by hsmith » Wed Nov 04, 2015 10:17 am
Can you post your nsc.ini/nsclient.ini with any passwords / sensitive IP addresses excluded?
Former Nagios Employee.
me.
Posts: 6579 Joined: Mon Oct 05, 2015 11:45 am
Post
by rkennedy » Wed Nov 04, 2015 10:29 am
You will need to edit your
nsclient.ini on your windows machine, and add the following lines -
[/settings/NRPE/server]
allow arguments=1
brandon
Post
by brandon » Wed Nov 04, 2015 11:09 am
password and login are OK, as they checked other plugins and running
Only problem I have with this plugin
maybe we should not executes the command?
Post
by rkennedy » Wed Nov 04, 2015 11:12 am
Did you make the change to your nsclient.ini, and restart the service after?
brandon
Post
by brandon » Thu Nov 05, 2015 4:29 am
In nsclient.ini I have:
alias_file_size = CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%" max-dir-depth=10
the file has not been modified
Post
by rkennedy » Thu Nov 05, 2015 10:17 am
Did you add this line to your nsclient.ini? It's needed for certain commands to run.
allow arguments=1
brandon
Post
by brandon » Fri Nov 06, 2015 3:46 am
so maybe I ask:, what should be on the server query:
use none
host_name server
service_description Check File Log
check_command check_file_size!path='c:\\test\test.txt' 'critical=size>100k' 'perf-config=size(unit:M)' 'detail-syntax=${status}%(file) = %(size)'
output:
Not a file or directory (or doesn't exist), don't know what to do with file=c: esttest.txt
and running plugin, for example:
use none
host_name server
service_description Open Files
check_command check_open_files.pl!-w 30 -c 50!
output
OK: 1856 open files (0% of max 205045)
The only problem is
check_file_size plugin
hsmith
Agent Smith
Post
by hsmith » Fri Nov 06, 2015 11:03 am
What happens when you run check_nrpe -H 192.168.1.10 -c alias_file_size -a file="c:\\test\test.txt" "critical=size>100k" "perf-config=size(unit:M)" "detail-syntax=${status}%(file) = %(size)" from the command line?
me.
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Mon Nov 09, 2015 1:35 am
hsmith wrote: What happens when you run check_nrpe -H 192.168.1.10 -c alias_file_size -a file="c:\\test\test.txt" "critical=size>100k" "perf-config=size(unit:M)" "detail-syntax=${status}%(file) = %(size)" from the command line?
Also, the file path requires double back slashes all the way through it, you have
c:\\test\test.txt but it should be
c:\\test\\test.txt
I would also try single quotes instead of double quotes.
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
