Check file size windows
Re: Check file size windows
the same problem
I tried single quotes and double quotes.
Did you also do the double backslashes? Please provide both the commands run and their output so we can get a better idea of what is working as what is not.
Also, since this is not a Nagios idea I will be moving this to the Nagios Core forum.
- Box293
- Too Basu
Also, what version of NSClient++ are you using?
OK, as I check with the command line:
for example:
./check_nt -H 192.168.0.10 -p 12489 -v MEMUSE -l -w 80 -c 90
and how do I check open_files from the command line?
Here is a good tutorial http://docs.nsclient.org/tutorial/nagios/check_nt.html but no examples for the checkfilesize
use service ; Name of service template to use
host_name server
service_description Open Files
check_command check_open_files.pl!-w 30 -c 50!
use service
host_name server
service_description Memory Usage
check_command check_nt!MEMUSE!-l -w 80 -c 90
- Box293
- Too Basu
So check_nt is not going to be able to execute the plugin, it is very limited to what it can do, hence this is why we need to use check_nrpe with NSClient++ and the nrpe module.
Can you please upload a copy of your nsclient.ini file.
Can you please answer this question. If you don't know, run this from your XI server:Box293 wrote:Also, what version of NSClient++ are you using?
/usr/local/nagios/libexec/check_nrpe -H 192.168.0.10
Please provide the full command you typed at the command line along with the output. This will speed up the troubleshooting process and there might be a simple spelling mistake.brandon wrote:the same problem
nsclient version: 0.4.1.102
Configuratiuon nsclient.ini file:
; Undocumented section
[/modules]
; CheckDisk - CheckDisk can check various file and disk related things. The current version has commands to check Size of hard drives and directories.
CheckDisk = 1
; Event log Checker. - Check for errors and warnings in the event log. This is only supported through NRPE so if you plan to use only NSClient this wont help you at all.
CheckEventLog = 1
; Check External Scripts - A simple wrapper to run external scripts and batch files.
CheckExternalScripts = 1
; Helper function - Various helper function to extend other checks. This is also only supported through NRPE.
CheckHelpers = 1
; Check NSCP - Checkes the state of the agent
CheckNSCP = 1
; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters.
CheckSystem = 1
; NRPE server - A simple server that listens for incoming NRPE connection and handles them.
NRPEServer = 1
; NSClient server - A simple server that listens for incoming NSClient (check_nt) connection and handles them. Although NRPE is the preferred method NSClient is fully supported and can be used for simplicity or for compatibility.
NSClientServer = 1
[/settings/default]
; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges.
allowed hosts = 192.168.0.10
; PASSWORD - Password used to authenticate againast server
; A list of aliases available. An alias is an internal command that has been "wrapped" (to add arguments). Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop)
[/settings/external scripts/alias]
; alias_cpu - Alias for alias_cpu. To configure this item add a section called: /settings/external scripts/alias/alias_cpu
alias_cpu = checkCPU warn=65 crit=80 time=5m time=1m time=30s
; alias_cpu_ex - Alias for alias_cpu_ex. To configure this item add a section called: /settings/external scripts/alias/alias_cpu_ex
alias_cpu_ex = checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s
; alias_disk - Alias for alias_disk. To configure this item add a section called: /settings/external scripts/alias/alias_disk
alias_disk = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED
; alias_disk_loose - Alias for alias_disk_loose. To configure this item add a section called: /settings/external scripts/alias/alias_disk_loose
alias_disk_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ignore-unreadable
; alias_event_log - Alias for alias_event_log. To configure this item add a section called: /settings/external scripts/alias/alias_event_log
alias_event_log = CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1 "filter=generated gt -2d AND severity NOT IN ('success', 'informational') AND source != 'SideBySide'" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%count%)"
; alias_file_age - Alias for alias_file_age. To configure this item add a section called: /settings/external scripts/alias/alias_file_age
alias_file_age = checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%"
; alias_file_size - Alias for alias_file_size. To configure this item add a section called: /settings/external scripts/alias/alias_file_size
alias_file_size = CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%" max-dir-depth=10
; alias_mem - Alias for alias_mem. To configure this item add a section called: /settings/external scripts/alias/alias_mem
alias_mem = checkMem MaxWarn=80% MaxCrit=90% ShowAll=long type=physical type=virtual type=paged type=page
; alias_process - Alias for alias_process. To configure this item add a section called: /settings/external scripts/alias/alias_process
alias_process = checkProcState "$ARG1$=started"
; alias_process_count - Alias for alias_process_count. To configure this item add a section called: /settings/external scripts/alias/alias_process_count
alias_process_count = checkProcState MaxWarnCount=$ARG2$ MaxCritCount=$ARG3$ "$ARG1$=started"
; alias_process_hung - Alias for alias_process_hung. To configure this item add a section called: /settings/external scripts/alias/alias_process_hung
alias_process_hung = checkProcState MaxWarnCount=1 MaxCritCount=1 "$ARG1$=hung"
; alias_process_stopped - Alias for alias_process_stopped. To configure this item add a section called: /settings/external scripts/alias/alias_process_stopped
alias_process_stopped = checkProcState "$ARG1$=stopped"
; alias_sched_all - Alias for alias_sched_all. To configure this item add a section called: /settings/external scripts/alias/alias_sched_all
alias_sched_all = CheckTaskSched "filter=exit_code ne 0" "syntax=%title%: %exit_code%" warn=>0
; alias_sched_long - Alias for alias_sched_long. To configure this item add a section called: /settings/external scripts/alias/alias_sched_long
alias_sched_long = CheckTaskSched "filter=status = 'running' AND most_recent_run_time < -$ARG1$" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_sched_task - Alias for alias_sched_task. To configure this item add a section called: /settings/external scripts/alias/alias_sched_task
alias_sched_task = CheckTaskSched "filter=title eq '$ARG1$' AND exit_code ne 0" "syntax=%title% (%most_recent_run_time%)" warn=>0
; alias_service - Alias for alias_service. To configure this item add a section called: /settings/external scripts/alias/alias_service
alias_service = checkServiceState CheckAll
; alias_service_ex - Alias for alias_service_ex. To configure this item add a section called: /settings/external scripts/alias/alias_service_ex
alias_service_ex = checkServiceState CheckAll "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc
; alias_up - Alias for alias_up. To configure this item add a section called: /settings/external scripts/alias/alias_up
alias_up = checkUpTime MinWarn=1d MinWarn=1h
; alias_updates - Alias for alias_updates. To configure this item add a section called: /settings/external scripts/alias/alias_updates
alias_updates = check_updates -warning 0 -critical 0
just do not know how, because it does not work, and what to open_files workPlease provide the full command you typed at the command line along with the output.
Reason: Please use [code][/code] tags around long output
For clarification, are you trying to run check_open_files.pl from the machine running NSClient or the Nagios machine?
- Box293
- Too Basu
It looks like your config file does not have the changes we requested, this is why it is not working.brandon wrote:nsclient version: 0.4.1.102
Configuratiuon nsclient.ini file:Code: Select all
; Undocumented section [/modules] ; CheckDisk - CheckDisk can check various file and disk related things. The current version has commands to check Size of hard drives and directories. CheckDisk = 1 ; Event log Checker. - Check for errors and warnings in the event log. This is only supported through NRPE so if you plan to use only NSClient this wont help you at all. CheckEventLog = 1 ; Check External Scripts - A simple wrapper to run external scripts and batch files. CheckExternalScripts = 1 ; Helper function - Various helper function to extend other checks. This is also only supported through NRPE. CheckHelpers = 1 ; Check NSCP - Checkes the state of the agent CheckNSCP = 1 ; CheckSystem - Various system related checks, such as CPU load, process state, service state memory usage and PDH counters. CheckSystem = 1 ; NRPE server - A simple server that listens for incoming NRPE connection and handles them. NRPEServer = 1 ; NSClient server - A simple server that listens for incoming NSClient (check_nt) connection and handles them. Although NRPE is the preferred method NSClient is fully supported and can be used for simplicity or for compatibility. NSClientServer = 1 ; Undocumented section [/settings/default] ; ALLOWED HOSTS - A comaseparated list of allowed hosts. You can use netmasks (/ syntax) or * to create ranges. allowed hosts = 192.168.0.10 ; PASSWORD - Password used to authenticate againast server ; A list of aliases available. An alias is an internal command that has been "wrapped" (to add arguments). Be careful so you don't create loops (ie check_loop=check_a, check_a=check_loop) [/settings/external scripts/alias] ; alias_cpu - Alias for alias_cpu. To configure this item add a section called: /settings/external scripts/alias/alias_cpu alias_cpu = checkCPU warn=65 crit=80 time=5m time=1m time=30s ; alias_cpu_ex - Alias for alias_cpu_ex. To configure this item add a section called: /settings/external scripts/alias/alias_cpu_ex alias_cpu_ex = checkCPU warn=$ARG1$ crit=$ARG2$ time=5m time=1m time=30s ; alias_disk - Alias for alias_disk. To configure this item add a section called: /settings/external scripts/alias/alias_disk alias_disk = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ; alias_disk_loose - Alias for alias_disk_loose. To configure this item add a section called: /settings/external scripts/alias/alias_disk_loose alias_disk_loose = CheckDriveSize MinWarn=10% MinCrit=5% CheckAll FilterType=FIXED ignore-unreadable ; alias_event_log - Alias for alias_event_log. To configure this item add a section called: /settings/external scripts/alias/alias_event_log alias_event_log = CheckEventLog file=application file=system MaxWarn=1 MaxCrit=1 "filter=generated gt -2d AND severity NOT IN ('success', 'informational') AND source != 'SideBySide'" truncate=800 unique descriptions "syntax=%severity%: %source%: %message% (%count%)" ; alias_file_age - Alias for alias_file_age. To configure this item add a section called: /settings/external scripts/alias/alias_file_age alias_file_age = checkFile2 filter=out "file=$ARG1$" filter-written=>1d MaxWarn=1 MaxCrit=1 "syntax=%filename% %write%" ; alias_file_size - Alias for alias_file_size. To configure this item add a section called: /settings/external scripts/alias/alias_file_size alias_file_size = CheckFiles "filter=size > $ARG2$" "path=$ARG1$" MaxWarn=1 MaxCrit=1 "syntax=%filename% %size%" max-dir-depth=10 ; alias_mem - Alias for alias_mem. To configure this item add a section called: /settings/external scripts/alias/alias_mem alias_mem = checkMem MaxWarn=80% MaxCrit=90% ShowAll=long type=physical type=virtual type=paged type=page ; alias_process - Alias for alias_process. To configure this item add a section called: /settings/external scripts/alias/alias_process alias_process = checkProcState "$ARG1$=started" ; alias_process_count - Alias for alias_process_count. To configure this item add a section called: /settings/external scripts/alias/alias_process_count alias_process_count = checkProcState MaxWarnCount=$ARG2$ MaxCritCount=$ARG3$ "$ARG1$=started" ; alias_process_hung - Alias for alias_process_hung. To configure this item add a section called: /settings/external scripts/alias/alias_process_hung alias_process_hung = checkProcState MaxWarnCount=1 MaxCritCount=1 "$ARG1$=hung" ; alias_process_stopped - Alias for alias_process_stopped. To configure this item add a section called: /settings/external scripts/alias/alias_process_stopped alias_process_stopped = checkProcState "$ARG1$=stopped" ; alias_sched_all - Alias for alias_sched_all. To configure this item add a section called: /settings/external scripts/alias/alias_sched_all alias_sched_all = CheckTaskSched "filter=exit_code ne 0" "syntax=%title%: %exit_code%" warn=>0 ; alias_sched_long - Alias for alias_sched_long. To configure this item add a section called: /settings/external scripts/alias/alias_sched_long alias_sched_long = CheckTaskSched "filter=status = 'running' AND most_recent_run_time < -$ARG1$" "syntax=%title% (%most_recent_run_time%)" warn=>0 ; alias_sched_task - Alias for alias_sched_task. To configure this item add a section called: /settings/external scripts/alias/alias_sched_task alias_sched_task = CheckTaskSched "filter=title eq '$ARG1$' AND exit_code ne 0" "syntax=%title% (%most_recent_run_time%)" warn=>0 ; alias_service - Alias for alias_service. To configure this item add a section called: /settings/external scripts/alias/alias_service alias_service = checkServiceState CheckAll ; alias_service_ex - Alias for alias_service_ex. To configure this item add a section called: /settings/external scripts/alias/alias_service_ex alias_service_ex = checkServiceState CheckAll "exclude=Net Driver HPZ12" "exclude=Pml Driver HPZ12" exclude=stisvc ; alias_up - Alias for alias_up. To configure this item add a section called: /settings/external scripts/alias/alias_up alias_up = checkUpTime MinWarn=1d MinWarn=1h ; alias_updates - Alias for alias_updates. To configure this item add a section called: /settings/external scripts/alias/alias_updates alias_updates = check_updates -warning 0 -critical 0
Do this:
Open a command prompt
cd "\Program Files\NSClient++\"
nscp settings --activate-module NRPEServer --add-defaults
nscp settings --path /settings/NRPE/server --key "allow arguments" --set true
nscp settings --path /settings/NRPE/server --key "allow nasty characters" --set true
Now test from your Nagios server:
check_nrpe -H 192.168.1.10 -c check_files -a path="c:\\test\\test.txt" 'filter=size gt 100k' 'master-syntax={%total% Files Found} %list%' 'syntax=%filename%: %size%' MaxCrit=1
As a note, I would upgrade to at least NSClient++ 0.4.3.138 onwards, as the commands from your version to this version have changed a bit.
On my site I show different examples for different versions of NSClient++:
http://sites.box293.com/nagios/guides/c ... es-folders
One last thing, NSClient++ has a module built in to check files, so there is no need for any extra scripts. My examples use the built in modules.
I want to run check_open_files nagios machinerkennedy wrote:For clarification, are you trying to run check_open_files.pl from the machine running NSClient or the Nagios machine?
check_open_files works, but I do not know how to check the command line
I added NSCP settings on the command line, then did restart the NSClient++ service and:
Exception processing request: Request contained arguments (not currently allowed, check the allow arguments option).
Can you add this to your NSClient configuration?
Then, restart the service and try again. Let us know the result.
[/settings/NRPE/server]
allow arguments = true
