When installing nagios core on Ubuntu got following error. I guess it is the reason for not able to access "http://<your.nagios.server.ip>/nagios". Please help
root@ubuntuvm2:~/xyz/nagios-4.1.1# make install-webconf
/usr/bin/install -c -m 644 sample-config/httpd.conf /etc/httpd/conf.d/nagios.conf
/usr/bin/install: cannot create regular file â/etc/httpd/conf.d/nagios.confâ: No such file or directory
make: *** [install-webconf] Error 1
root@ubuntuvm2:~/xyz/nagios-4.1.1# uname -a
Linux ubuntuvm2 3.16.0-30-generic #40~14.04.1-Ubuntu SMP Thu Jan 15 17:43:14 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
"make install-webconf" FAILS while core installation.
Re: "make install-webconf" FAILS while core installation.
What instructions are you following?
The command you mentioned is how it should install on a Centos or RHEL machine. This directory is changed in Ubuntu to /etc/apache2/sites-enabled/.
This should work in place of make install-webconf
sudo /usr/bin/install -c -m 644 sample-config/httpd.conf /etc/apache2/sites-enabled/nagios.conf
I am following the instructions mentioned in the following document:
https://assets.nagios.com/downloads/nag ... Source.pdf
Instructions don't mention that this command is for Centos or RHEL machine in fact it says "All systems".
tried "/usr/bin/install -c -m 644 sample-config/httpd.conf /etc/apache2/sites-enabled/nagios.conf" still not able to access "http://<your.nagios.server.ip>/nagios"
Did you finish the remaining commands?
What error messages are you receiving when running 'service nagios start'?
cp -R contrib/eventhandlers/ /usr/local/nagios/libexec/
chown -R nagios:nagios /usr/local/nagios/libexec/eventhandlers
/etc/init.d/nagios start
yes i executed all the remaining commands.
there is no error message for command 'service nagios start'.
# /etc/init.d/nagios start
Starting nagios: done.
I get following error message when tried accessing nagios page
http://<sys_IP>/nagios
Not Found
The requested URL /nagios was not found on this server.
Apache/2.4.7 (Ubuntu) Server at <sys_IP> Port 80
Not Found
- Box293
- Too Basu
Most likely it's the configure script that needs adjusting:
Here's a guide I wrote for Core 4.0.8 which is pretty similar.
http://sites.box293.com/nagios/guides/i ... untu-14-04
Also you may need to do:
./configure --with-nagios-group=nagios --with-command-group=nagcmd --with-mail=/usr/bin/sendmail --with-httpd-conf=/etc/apache2/sites-enabled
a2enmod rewrite
a2enmod cgi
Thanks sir.
following option worked. May be it should be updated in the instructions doc.
Glad to see this worked for you! As this is resolved, I will now close this thread out. Feel free to open another if you ever need assistance in the future.
