[root@nagios libexec]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nag ios.cfg|more
Nagios Core 4.1.1
Copyright (c) 2009-present Nagios Core Development Team and Community Contributo
rs
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Checking objects...
Error: Service check command 'check_load' specified in service 'CPU Load' for ho
st 'ora_linux7_xen2.xyz.local' not defined anywhere!
Error: Service check command 'check_users' specified in service 'Current Users'
for host 'ora_linux7_xen2.xyz.local' not defined anywhere!
Error: Service check command 'check_total_procs' specified in service 'Total Pro
cesses' for host 'ora_linux7_xen2.xyz.local' not defined anywhere!
Checked 12 services.
Checked 2 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 24 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 2 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 3
***> One or more problems was encountered while running the pre-flight check...
Error: Service check command 'check_load' specified in service 'CPU Load' for host 'ora_linux7_xen2.xyz.local' not defined anywhere!
Error: Service check command 'check_users' specified in service 'Current Users' for host 'ora_linux7_xen2.xyz.local' not defined anywhere!
Error: Service check command 'check_total_procs' specified in service 'Total Processes' for host 'ora_linux7_xen2.xyz.local' not defined anywhere!
Can you please post the config file that has the services for ora_linux7_xen2.xyz.local
[root@ora_linux7_xen2 etc]# vi services
# /etc/services:
# $Id: services,v 1.55 2013/04/14 ovasik Exp $
# Network services, Internet style
# IANA services version: last updated 2013-04-10
# Note that it is presently the policy of IANA to assign a single well-known
# port number for both TCP and UDP; hence, most entries here have two entries
# even if the protocol doesn't support UDP operations.
# Updated from RFC 1700, ``Assigned Numbers'' (October 1994). Not all ports
# are included, only the more common ones.
# The latest IANA port assignments can be gotten from
# http://www.iana.org/assignments/port-numbers
# The Well Known Ports are those from 0 through 1023.
# The Registered Ports are those from 1024 through 49151
# The Dynamic and/or Private Ports are those from 49152 through 65535
# Each line describes one service, and is of the form:
# service-name port/protocol [aliases ...] [# comment]
tcpmux 1/tcp # TCP port service multiplexer
tcpmux 1/udp # TCP port service multiplexer
rje 5/tcp # Remote Job Entry
rje 5/udp # Remote Job Entry
echo 7/tcp
echo 7/udp
discard 9/tcp sink null
discard 9/udp sink null
systat 11/tcp users
systat 11/udp users
daytime 13/tcp
daytime 13/udp
qotd 17/tcp quote
qotd 17/udp quote
msp 18/tcp # message send protocol (historic)
msp 18/udp # message send protocol (historic)
chargen 19/tcp ttytst source
chargen 19/udp ttytst source
ftp-data 20/tcp
ftp-data 20/udp
# 21 is registered to ftp, but also used by fsp
ftp 21/tcp
ftp 21/udp fsp fspd
ssh 22/tcp # The Secure Shell (SSH) Protocol
[root@ora_linux7_xen2 etc]# vi /usr/local/nagios/etc/nrpe.cfg
# Sample NRPE Config File
# Written by: Ethan Galstad (nagios@nagios.org)
# Last Modified: 11-23-2007
# NOTES:
# This is a sample configuration file for the NRPE daemon. It needs to be
# located on the remote host that is running the NRPE daemon, not the host
# from which the check_nrpe client is being executed.
# LOG FACILITY
# The syslog facility that should be used for logging purposes.
log_facility=daemon
# PID FILE
# The name of the file in which the NRPE daemon should write it's process ID
# number. The file is only written if the NRPE daemon is started by the root
# user and is running in standalone mode.
pid_file=/var/run/nrpe.pid
# PORT NUMBER
# Port number we should wait for connections on.
# NOTE: This must be a non-priviledged port (i.e. > 1024).
# NOTE: This option is ignored if NRPE is running under either inetd or xinetd
server_port=5666
# SERVER ADDRESS
# Address that nrpe should bind to in case there are more than one interface
# and you do not want nrpe to bind on all interfaces.
#server_address=127.0.0.1
"/usr/local/nagios/etc/nrpe.cfg" 237L, 8124C
