[root@nagios etc]# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Error: Invalid service object directive 'hostname'.
Error: Could not add object property in file '/usr/local/nagios/etc/services.cfg' on line 38.
[root@nagios etc]#
hsmith wrote:You're not giving the check_nrpe command enough information to run. Look at my earlier post for an example.
As far as your services.cfg that you posted, change where it says hostname to host_name to make that error go away.
Thanks for all your help. This seemed to fix the issue. Now I just gotta figure out how to give the proper arguments in the check_nrpe command for the rest of the commands.
