Raspberry PI running raspbian
Nagios 4.1 Core
Have many services working from my Windows Server platform no issues.
I tried to add this service which has a space in the name which from what I read is supported but it fails to find the services
host_name SERV013
service_description ADManager Plus
check_command check_nt!SERVICESTATE!-d SHOWALL -l ADManager Plus
This is the service details from the server
[serv013]: PS C:> get-service ad* | fl
DisplayName : ManageEngine ADManager Plus
Status : Running
DependentServices : {}
ServicesDependedOn : {}
CanPauseAndContinue : False
CanShutdown : True
CanStop : True
ServiceType : Win32OwnProcess, InteractiveProcess
Thoughts
Nagios define service help
Re: Nagios define service help
can you try this I use NagiosXI and i use backslash to avoid space issue.
edit: if above doesnt work try adding single quote
check_command check_nt!SERVICESTATE!-d SHOWALL -l ADManager\ Plus
'ADManager Plus'
the
Worked
This issue has been reolved
the
Worked
Glad we were able to help. We'll lock this thread now and feel free to open another should you require assistance with anything else.
