Hi Support,
I have installed Nagios Core latest version that is 4.1.1 on CentOS release 6.7 (Final) Server, When I am clicking on Trends under Reports section I am not getting anything, its appearing as blank page (attached the screen shot), When I checked http error log from /var/log/httpd/error_log.log I found the below:
[Sat Nov 28 05:22:32 2015] [error] [client **********] File does not exist: /data/tools/nagios/share/bootstrap-3.3.0/css/bootstrap.min.css, referer: http://**********/nagios/trends.html
[Sat Nov 28 05:22:32 2015] [error] [client **********] File does not exist: /data/tools/nagios/share/bootstrap-3.3.0/css/bootstrap-theme.min.css, referer: http://**********/nagios/trends.html
[Sat Nov 28 05:22:32 2015] [error] [client **********] File does not exist: /data/tools/nagios/share/d3/d3.min.js, referer: http://**********/nagios/trends.html
[Sat Nov 28 05:22:32 2015] [error] [client **********] File does not exist: /data/tools/nagios/share/angularjs/angular-1.3.9/angular.min.js, referer: http://**********/nagios/trends.html
[Sat Nov 28 05:22:32 2015] [error] [client **********] File does not exist: /data/tools/nagios/share/angularjs/ui-bootstrap-tpls-0.12.0.min.js, referer: http://**********/nagios/trends.html
[Sat Nov 28 05:22:32 2015] [error] [client **********] File does not exist: /data/tools/nagios/share/angularjs/ui-utils-0.2.1/ui-utils.js, referer: http://**********/nagios/trends.html
[Sat Nov 28 05:22:32 2015] [error] [client **********] File does not exist: /data/tools/nagios/share/spin/spin.min.js, referer: http://**********/nagios/trends.html
Looks like some .css files are missing from share directory, hence I just went inside the respective directories and verified and found files are missing there. May I please request your suggestion how they can be restore so that Trends reporting tool will work as expected..!
Sachikanta Mishra
Trends reporting tool not working[Solved]
Re: Trends reporting tool not working[Solved]
I have copied all required files from nagioscore source file and its working fine now.
Regards,
Sachikanta
Regards,
Sachikanta
Glad to hear it's working. Are we all right to close this?
Former Nagios Employee.
me.
me.
yes, all looks fine now and we can close this ticket.
Regards,
Sachikanta
Regards,
Sachikanta
Thanks for the update! I'll go ahead and close this out now, if you ever need assistance in the future feel free to open a new thread.
