Nagios version 4.1.1
NagiosQL version 3.2.0
CentOS 7
pnp4nagios version 0.6.25
vi /usr/local/nagios/etc/nagios.cfg
#cfg_file=/usr/local/nagios/etc/objects/commands.cfg
#cfg_file=/usr/local/nagios/etc/objects/contacts.cfg
#cfg_file=/usr/local/nagios/etc/objects/timeperiods.cfg
#cfg_file=/usr/local/nagios/etc/objects/templates.cfg
# Definitions for monitoring the local (Linux) host
#cfg_file=/usr/local/nagios/etc/objects/localhost.cfg
# Definitions for monitoring a Windows machine
#cfg_file=/usr/local/nagios/etc/objects/windows.cfg
# Definitions for monitoring a router/switch
#cfg_file=/usr/local/nagios/etc/objects/switch.cfg
# Definitions for monitoring a network printer
#cfg_file=/usr/local/nagios/etc/objects/printer.cfg
# You can also tell Nagios to process all config files (with a .cfg
# extension) in a particular directory by using the cfg_dir
# directive as shown below:
cfg_dir=/etc/nagiosql
it verify OK
command : /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
and restart nagios
command : systemctl restart nagios.service
In First time, The hosts (and services) that I config in Nagiosql shown in Nagios core.
when I modify host or service in Nagiosql (and restart nagios service), The host file (of nagiosql) was changed but the host in Nagios core not change (not sync).
How can I track this problem ?
Thank You
NagiosQL Host not update in Nagios Core
Re: NagiosQL Host not update in Nagios Core
Is this using a pre-built VM from us or did you install Core + QL yourself?
I have the same issue. The install was Core + Nagios QL, not XI.
Unfortunately we aren't able to provide support for NagiosQL issues since this is not our product. We offer a pre-built VM that has been tested and is guaranteed to work, but QL + Core installed on their own is out of scope.
I understand...
@narin_pao - let us know when you get a chance to get back to us.
I have overcome this problem adapting a removal script supplied for Nagios XI, then implementing a fresh install of Core 4.1.1 and NagiosQL.
I'd be careful the first few times you go that route - there are some differences between the original QL code and our CCM we use in XI.
I'll be closing this thread now, but feel free to open another if you need anything in the future!
