Please run the two commands that @Box293 mentioned above, and post the output. You just want to run 'echo $?' which will show us the exit code that check_snmp runs on -
Are you specifying a $1 and $2 variable? I don't think your check command needs to specify a -w and -c since you're already specifying that in the wrapper script. It just expects to be ran like this -
the issue is that i dont received any email alert it done not show warning or critical it just show "SNMP WARNING - 0| iso.3.6.1.4.1.318.1.1.12.2.3.1.1.2.1=6.7"
what i would like for it to show is warring or critical and what the current level is so her is my lastest info
i run my script directly {as before i am specifying the Variable }
use generic-service,srv-pnp
host_name Metered Rack PDU 241
service_description APC Metered Total
check_command 241_total_load! 70 100 {do i specific the variable here or in the command } {and is this the right format}
max_check_attempts 5
check_period 24x7
notification_interval 30
notification_period 24x7
contacts nagiosadmin
here is the command.cfg
# '241_total_load' command definition
command_name 241_total_load
command_line $USER1$/241_total_load {do i specific the variable here or in the command } {-w $ARG1$ -c $ARG2$} {is this the right format}
as stated in the previous comments i am not receiving email alert i did add AWK command function to it so that it display in 9.6 Amps instead of 96 which is more realistic i ams sorry for the mix up but i hope my point get across but if i remove the variable in the wrapper script the command function just fine and display it in the right format of 9.6 i am not 100 sure so i was changing thing around to see what result i would get
