I want to deploy Nagios Core with the Security on Cloud, I had read one link which got from Nagios website which mentioned below.
https://assets.nagios.com/downloads/nag ... urity.html
Someone help me to get the steps deploy the Nagios with the security as per above links.
Deploy Nagios Core with the Security
Re: Deploy Nagios Core with the Security
Can you please be more specific as to what you need help with? How can we help you out with this?
Former Nagios Employee.
me.
me.
Want to cover all this Security points during installation of Nagios Core, Please help me if have any document.
- Don't Run Nagios As Root
- Lock Down The Check Result Directory.
- Lock Down The External Command File
- Require Authentication In The CGIs
- Implement Enhanced CGI Security Measures.
- Hide Sensitive Information With $USERn$ Macros.
- Strip Dangerous Characters From Macros.
- Secure Access to Remote Agents.
- Secure Communication Channels.
The document outlines what needs to be done for each of the bullet points, what exactly are you looking for?
I want to deploy Nagios Core on Cloud with Security considering below bullet points so please if have any document to configure Nagios Core. (https://assets.nagios.com/downloads/nag ... 1464191385).
- Don't Run Nagios As Root.
The page has links to more information, as well as a paragraph about each bullet point you mentioned. Let us know if you have any questions regarding something specifically.
ok, thanks for support you can close this ticket.
Closing this. Let us know if you need additional assistance!
