Nagios Core 4.1 Down Time
I run Nagios Core 4.1.1 on my Raspberry Pi Works great.
All my Computers and workstations report back with no problems
I have two servers that run a process every Monday at 2:00 PM and it takes about 30 to 60 minutes to run
This process causes a service that I monitor to stop and the cpu spikes a bit.
During my testing I scheduled down time manually with Nagios.
How can I schedule these two server not to be monitored starting at 1:30 PM to 2:30 PM only on a Monday?
Thank you
Tom
Thank you
Tom
Re: Nagios Core 4.1 Down Time
Does this documentation offer any assistance?
https://assets.nagios.com/downloads/nag ... ntime.html
no not really
I understand how to schedule a host and or service down time
My question is I do I set a schedule on a regular basis for down time.
My example above was clear on what I wanted.
Maybe not that clear
I want to schedule down time for two servers EVERY Monday at 1:45 PM to 2:45 PM
I am not just trying to schedule for one time I need a method to schedule a recurring downtime
I know I loose down time stats but I could just not monitor the one service during that time period also
Thoughts
Thoughts
Ah, apologies for misunderstanding.
One way to achieve this is to set a specific time period for your host that excludes Monday from 1:30pm to 2:30pm:
https://assets.nagios.com/downloads/nag ... riods.html
So your time period definition might look something like this:
Alternatively you could define a new time period based on the default 24x7 definition and use the exclude directive:
In which case, you would use the monday_reboots as the check_period directive for your host. If you wanted the checks to run but simply didn't want to get notifications, you would use the notification_period directive instead.
define timeperiod {
timeperiod_name foo
sunday 00:00-24:00
monday 00:00-13:30,14:30-24:00
tuesday 00:00-24:00
wednesday 00:00-24:00
thursday 00:00-24:00
friday 00:00-24:00
saturday 00:00-24:00
define timeperiod {
name reboots
timeperiod_name reboots
monday 13:30-14:30
define timeperiod {
timeperiod_name monday_reboots
use 24x7
exclude reboots
EDIT: Looks like @mcapra beat me to it, but both answers illustrate the same thing here.
Ah, your best bet may be to use the time periods built into Core. For example, create a new time period called 'skip1451hrm' -
Now, update those checks you do not want to execute during those times. Change the check_period for them. For example -
The checks will stop running on monday at 1:45 until 2:45.
define timeperiod {
timeperiod_name skip1451hrm
sunday 00:00-24:00
monday 00:00-13:45,14:45-24:00
tuesday 00:00-24:00
friday 00:00-24:00
check_period skip1451hrm
Where do I do this?
Commands.cfg? for the define timeperiod
then where do I place the notification_period skip1451hrm does this go in the hosts definition file? or on the define service code?
I have a windows.cfg file that defines all my servers hosts and services
With Core, you can put the definitions in whatever configuration file you like as long as that file (or it's parent directory) is recognized in nagios.cfg.
Generally, time periods are defined in /usr/local/nagios/etc/timeperiods.cfg
If your windows.cfg file contains the host definition, the check_period directive would go under the host definition in that file.
I do not have a timeperiods.cfg file in /usr/local/Nagios/etc
should I create one?
If I do will I need to check any place else ?
Found it
was here /usr/local/Nagios/etc/objects
Found it
Seem not able to create the timeperiod in the timeperiods.cfg file
root@raspberrypi:~# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Reading configuration data...
Read main config file okay...
Error: Name or alias for timeperiod is NULL
Error: Could not register timeperiod (config file '/usr/local/nagios/etc/objects/timeperiods.cfg', starting on line 95)
my entries
# Exclude Time when WSUS does Cleanup Process on Mondays at 1:45 PM to 2:45 PM
define timeperiod{
sunday 00:00-24:00
tuesday 00:00-24:00
friday 00:00-24:00
Thoughts?
Nagios Core 4.1.1
License: GPL
my entries
define timeperiod{
sunday 00:00-24:00
tuesday 00:00-24:00
friday 00:00-24:00
Thoughts?
Ah - looks like I forgot an alias. Add one in here -
That should work.
define timeperiod{
alias WSUS Monday Cleanup
sunday 00:00-24:00
tuesday 00:00-24:00
friday 00:00-24:00
