root@TGCS017:~# grep -R TGCS011 /usr/local/nagios/etc/*
/usr/local/nagios/etc/objects/windows.cfg: host_name TGCS011 ; The name we're giving to this host
/usr/local/nagios/etc/objects/windows.cfg:# Create a service for monitoring the System services on TGCS011
root@TGCS017:~#
Moved nrpe.cfg to /usr/local/Nagios/etc/objects
Made it same permissions as other .cfg files
Same error
root@TGCS017:/usr/local/nagios/etc/objects# /usr/local/nagios/bin/nagios -vv /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.1.1
Last Modified: 08-19-2015
License: GPL
Website:
https://www.nagios.org
Reading configuration data...
Read main config file okay...
Processing object config file '/usr/local/nagios/etc/objects/commands.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/contacts.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/timeperiods.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/templates.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/localhost.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/windows.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/computer.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/switch.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/printer.cfg'...
Processing object config file '/usr/local/nagios/etc/objects/nrpe.cfg'...
Warning: Duplicate definition found for host 'TGCS011' (config file '/usr/local/nagios/etc/objects/nrpe.cfg', starting on line 11)
Error: Could not add object property in file '/usr/local/nagios/etc/objects/nrpe.cfg' on line 13.
root@TGCS017:/usr/local/nagios/etc/objects# ls -ltr /usr/local/nagios/etc/objects/
total 212
-rw-rw-r-- 1 nagios nagios 10621 Jul 22 19:23 templates.cfg
-rw-rw-r-- 1 nagios nagios 5375 Jul 22 19:23 localhost.cfg
-rw-rw-r-- 1 nagios nagios 3991 Jul 22 19:23 windows.org
-rw-rw-r-- 1 nagios nagios 3265 Jul 22 19:23 switch.org
-rw-rw-r-- 1 nagios nagios 2365 Jul 22 20:41 contacts.cfg
-rw-rw-r-- 1 nagios nagios 3632 Jul 23 08:55 timeperiods.cfg
-rw-rw-r-- 1 nagios nagios 3567 Jul 23 09:14 printer.cfg
-rw-rw-r-- 1 root root 15500 Jul 23 10:26 computer.cfg
-rw-rw-r-- 1 root root 4907 Jul 23 18:01 switch.cfg
-rw-rw-r-- 1 root root 137225 Jul 23 18:02 windows.cfg
-rw-rw-r-- 1 nagios nagios 8053 Jul 25 20:14 commands.cfg
-rw-rw-r-- 1 root root 991 Jul 25 23:22 nrpe.cfg
I figured it out
I removed the Host definition in NRPE.CFG
Now the verify ran successful
I restarted NAGIOS service
And now the service for the plugin shows
But it failed with this
(No output on stdout) stderr: execvp(/usr/lib/nagios/plugins/check_nrpe, ...) failed. errno is 2: No such file or directory
Do I need to restart NRPE service also???
Thoughts
