hack3rcon
Posts: 27 Joined: Sat Jul 16, 2016 9:50 am
Post
by hack3rcon » Tue Jul 26, 2016 5:15 am
Hello.
When I use "/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg" then it show me :
Nagios Core 4.0.1
Last Modified: 10-15-2013
License: GPL
Reading configuration data...
Read main config file okay...
Warning: Duplicate definition found for service 'Total Processes' on host 'localhost' (config file '/usr/local/nagios/etc/objects/localhost.cfg', starting on line 101)
Warning: Duplicate definition found for service 'Current Users' on host 'localhost' (config file '/usr/local/nagios/etc/objects/localhost.cfg', starting on line 89)
Checking objects...
Checked 11 services.
Checked 2 hosts.
Checked 1 host groups.
Checked 0 service groups.
Checked 1 contacts.
Checked 1 contact groups.
Checked 25 commands.
Checked 5 time periods.
Checked 0 host escalations.
Checked 2 hosts
Checked 0 host dependencies
Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors: 0
Posts: 6579 Joined: Mon Oct 05, 2015 11:45 am
Post
by rkennedy » Tue Jul 26, 2016 9:47 am
Then it appears there are multiple definitions found for the same service. Take a look at your configuration files and see where they are occurring. You should be able to run grep -r -A 5 -B 5 'Total Processes' /usr/local/nagios/etc/ to help search through them all.
hack3rcon
Post
by hack3rcon » Wed Jul 27, 2016 12:27 am
The result is :
[root@localhost ~]# grep -r -A 5 -B 5 'Total Processes' /usr/local/nagios/etc/
/usr/local/nagios/etc/objects/localhost.cfg-# > 400 users.
/usr/local/nagios/etc/objects/localhost.cfg-define service{
/usr/local/nagios/etc/objects/localhost.cfg- use local-service ; Name of service template to use
/usr/local/nagios/etc/objects/localhost.cfg- host_name localhost
/usr/local/nagios/etc/objects/localhost.cfg: service_description Total Processes
/usr/local/nagios/etc/objects/localhost.cfg- check_command check_local_procs!250!400!RSZDT
/usr/local/nagios/etc/objects/localhost.cfg- }
/usr/local/nagios/etc/services.cfg-check_command check_nrpe!check_load
/usr/local/nagios/etc/services.cfg-}
/usr/local/nagios/etc/services.cfg-define service{
/usr/local/nagios/etc/services.cfg-use generic-service
/usr/local/nagios/etc/services.cfg-host_name localhost
/usr/local/nagios/etc/services.cfg:service_description Total Processes
/usr/local/nagios/etc/services.cfg-check_command check_nrpe!check_total_procs
How can I solve it?
Posts: 5126 Joined: Sun Feb 07, 2010 10:55 pm
Post
by Box293 » Wed Jul 27, 2016 1:29 am
You have the a service definition in these files that have the same service_description :
You need to remove / comment out the duplicate services in one of these files. I would do this to the file:
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy .
hack3rcon
Post
by hack3rcon » Wed Jul 27, 2016 1:57 am
Thank you.
I did it and problem solved. I hope it cause not any problem.
Posts: 3739 Joined: Thu May 05, 2016 3:54 pm
Post
by mcapra » Wed Jul 27, 2016 9:52 am
Is it alright if we lock this thread and mark the issue as resolved?
hack3rcon
Post
by hack3rcon » Sun Jul 31, 2016 7:45 am
Yes. I remove the lines and problem solved.
