paries
Posts: 4 Joined: Thu Feb 09, 2017 12:03 pm
Post
by paries » Thu Feb 09, 2017 12:09 pm
Hello, I am a newbie
setting up my nagios core for the first time
So far so good
So i have created a command
command_name snmp_Disk1_Usage
command_line $USER1$/check_snmp -o .1.3.6.1.4.1.2021.9.1.8.1 -H $HOSTADDRESS$ $ARG1$
This works fine with
host_name www2.myhost.com
service_description Disk 1 Usage Percentage
check_command snmp_Disk1_UsedPercentage!-C my_monitor
The one part where i can not seem to connect the dots is how do i set this up to fail when a particular MAX Percentage is reached
Posts: 6579 Joined: Mon Oct 05, 2015 11:45 am
Post
by rkennedy » Thu Feb 09, 2017 12:26 pm
You'll want to append to your check_command, further information to pass to $ARG1$. The warning / critical values are usually adjusted with the -w / -c variables -
[root@xi libexec]# ./check_snmp
check_snmp: Could not parse arguments
Usage:
check_snmp -H <ip_address> -o <OID> [-w warn_range] [-c crit_range]
[-C community] [-s string] [-r regex] [-R regexi] [-t timeout] [-e retries]
[-l label] [-u units] [-p port-number] [-d delimiter] [-D output-delimiter]
[-m miblist] [-P snmp version] [-L seclevel] [-U secname] [-a authproto]
[-A authpasswd] [-x privproto] [-X privpasswd]
Posts: 9117 Joined: Mon Sep 23, 2013 8:40 am
Post
by tmcdonald » Wed Mar 01, 2017 2:26 pm
Just checking in since we have not heard from you in a while. Did
@rkennedy 's post clear things up or has the issue otherwise been resolved?
