Radwin Radios SNMP
Radwin Radios SNMP
I'm have 2 test systems Nagios Core & NagiosXI and both of them have the same issue.
I need to monitor Radios signal.
Radwin's MIB was installed on NagiosXI through GUI (Admin->Manage MIBs->"Process trap" Upload MIB). On the NagiosCore server it was uploaded to /usr/share/snmp/mibs/ and /root/.snmp/mibs/
Looks like on both servers that MIB was added
addmib /usr/share/snmp/mibs/WinLink1000.mib This file looks like it has been added already! Exiting.
"If" (ifSpeed.1), if commands are working well. I think because they are using default MIBs.
./check_snmp -H 192.168.1.110 -o ifSpeed.1 -P 3 --seclevel=authPriv --secname=admin --authproto=md5 --authpasswd='netman123' --privpasswd='netman123' --privproto=des
SNMP OK - 1000000000 | IF-MIB::ifSpeed.1=1000000000
But commands from WinLink1000.mib (Radwin's MIB) are not working
./check_snmp -H 192.168.1.110 -o winlink1000OduAdmProductType -P 3 --seclevel=authPriv --secname=admin --authproto=md5 --authpasswd='netman123' --privpasswd='netman123' --privproto=des
External command error: Error in packet
Reason: (noSuchName) There is no such variable name in this MIB.
Failed object: RADWIN-MIB-WINLINK1000::winlink1000OduAdmProductType
or
./check_snmp -H 192.168.1.110 -o 1.3.6.1.4.1.4458.1000.1.1.1 -P 3 --seclevel=authPriv --secname=admin --authproto=md5 --authpasswd='netman123' --privpasswd='netman123' --privproto=des
Any ideas why?
or
Any ideas why?
Re: Radwin Radios SNMP
Can you post the WinLink1000.mib file here so we can view it's contents to see if the OID's you are checking are in it?
I'm not sure if I can post it since to receive that file you need to register on their partners website.
In the internet I found
http://www.snmplink.org/cgi-bin/nd/m/En ... nk1000.mib
https://www.google.com/url?sa=t&rct=j&q ... 7831,d.amc
MIB file start
-- RADWIN Management Information Base (MIB)
-- Generated 01/05/16 14:23:32 Version: 10.2.40_b9653
RADWIN-MIB-WINLINK1000 DEFINITIONS ::= BEGIN
IMPORTS
enterprises, IpAddress, Counter, Gauge, TimeTicks
FROM RFC1155-SMI
OBJECT-TYPE
FROM RFC-1212
DisplayString, ifIndex
FROM RFC1213-MIB
TRAP-TYPE
FROM RFC-1215;
radwin OBJECT IDENTIFIER ::= { enterprises 4458 }
winlink1000 OBJECT IDENTIFIER ::= { radwin 1000 }
-- ODU
winlink1000Odu OBJECT IDENTIFIER ::= { winlink1000 1 }
-- ODU Admin
winlink1000OduAdmin OBJECT IDENTIFIER ::= { winlink1000Odu 1 }
winlink1000OduAdmProductType OBJECT-TYPE
SYNTAX DisplayString
ACCESS read-only
STATUS mandatory
DESCRIPTION
"ODU configuration description."
::= { winlink1000OduAdmin 1 }
So as you can see "winlink1000OduAdmProductType" is there.
MIB file start
IMPORTS
FROM RFC1155-SMI
OBJECT-TYPE
FROM RFC-1212
FROM RFC1213-MIB
TRAP-TYPE
FROM RFC-1215;
-- ODU
-- ODU Admin
ACCESS read-only
STATUS mandatory
DESCRIPTION
It might be a format issue with the file so that is why I would like to see it.
Can you run this snmptranslate command on your Nagios server and post the output here?
It should print out descriptive name of the OID's as well as the numeric value so you can confirm that the file format is valid.
snmptranslate -m /usr/share/snmp/mibs/WinLink1000.mib -TZ
Invalid -T<lostpad> character: Ztgriep wrote:It might be a format issue with the file so that is why I would like to see it.
Can you run this snmptranslate command on your Nagios server and post the output here?It should print out descriptive name of the OID's as well as the numeric value so you can confirm that the file format is valid.Code: Select all
USAGE: snmptranslate [OPTIONS] OID [OID]...
Version: 5.7.2
Web: http://www.net-snmp.org/
Email: net-snmp-coders@lists.sourceforge.net
It is my day for typo's, it is a lower case z so try running this instead.
snmptranslate -m /usr/share/snmp/mibs/WinLink1000.mib -Tz
tgriep wrote:It is my day for typo's, it is a lower case z so try running this instead.Code: Select all
"org" "1.3"
"dod" "1.3.6"
"internet" "1.3.6.1"
"directory" "1.3.6.1.1"
"mgmt" "1.3.6.1.2"
"mib-2" "1.3.6.1.2.1"
"system" "1.3.6.1.2.1.1"
"sysDescr" "1.3.6.1.2.1.1.1"
"sysObjectID" "1.3.6.1.2.1.1.2"
"sysUpTime" "1.3.6.1.2.1.1.3"
"sysContact" "1.3.6.1.2.1.1.4"
"sysName" "1.3.6.1.2.1.1.5"
"sysLocation" "1.3.6.1.2.1.1.6"
"sysServices" "1.3.6.1.2.1.1.7"
"interfaces" "1.3.6.1.2.1.2"
"ifNumber" "1.3.6.1.2.1.2.1"
"ifTable" "1.3.6.1.2.1.2.2"
"ifEntry" "1.3.6.1.2.1.2.2.1"
"ifIndex" "1.3.6.1.2.1.2.2.1.1"
"ifDescr" "1.3.6.1.2.1.2.2.1.2"
"ifType" "1.3.6.1.2.1.2.2.1.3"
"ifMtu" "1.3.6.1.2.1.2.2.1.4"
"ifSpeed" "1.3.6.1.2.1.2.2.1.5"
"ifPhysAddress" "1.3.6.1.2.1.2.2.1.6"
"ifAdminStatus" "1.3.6.1.2.1.2.2.1.7"
"ifOperStatus" "1.3.6.1.2.1.2.2.1.8"
"ifLastChange" "1.3.6.1.2.1.2.2.1.9"
"ifInOctets" "1.3.6.1.2.1.2.2.1.10"
"ifInUcastPkts" "1.3.6.1.2.1.2.2.1.11"
"ifInNUcastPkts" "1.3.6.1.2.1.2.2.1.12"
"ifInDiscards" "1.3.6.1.2.1.2.2.1.13"
"ifInErrors" "1.3.6.1.2.1.2.2.1.14"
"ifInUnknownProtos" "1.3.6.1.2.1.2.2.1.15"
"ifOutOctets" "1.3.6.1.2.1.2.2.1.16"
"ifOutUcastPkts" "1.3.6.1.2.1.2.2.1.17"
"ifOutNUcastPkts" "1.3.6.1.2.1.2.2.1.18"
"ifOutDiscards" "1.3.6.1.2.1.2.2.1.19"
"ifOutErrors" "1.3.6.1.2.1.2.2.1.20"
"ifOutQLen" "1.3.6.1.2.1.2.2.1.21"
"ifSpecific" "1.3.6.1.2.1.2.2.1.22"
"at" "1.3.6.1.2.1.3"
"atTable" "1.3.6.1.2.1.3.1"
"atEntry" "1.3.6.1.2.1.3.1.1"
"atIfIndex" "1.3.6.1.2.1.3.1.1.1"
"atPhysAddress" "1.3.6.1.2.1.3.1.1.2"
"atNetAddress" "1.3.6.1.2.1.3.1.1.3"
"ip" "1.3.6.1.2.1.4"
"ipForwarding" "1.3.6.1.2.1.4.1"
"ipDefaultTTL" "1.3.6.1.2.1.4.2"
"ipInReceives" "1.3.6.1.2.1.4.3"
"ipInHdrErrors" "1.3.6.1.2.1.4.4"
"ipInAddrErrors" "1.3.6.1.2.1.4.5"
"ipForwDatagrams" "1.3.6.1.2.1.4.6"
"ipInUnknownProtos" "1.3.6.1.2.1.4.7"
"ipInDiscards" "1.3.6.1.2.1.4.8"
"ipInDelivers" "1.3.6.1.2.1.4.9"
"ipOutRequests" "1.3.6.1.2.1.4.10"
"ipOutDiscards" "1.3.6.1.2.1.4.11"
"ipOutNoRoutes" "1.3.6.1.2.1.4.12"
"ipReasmTimeout" "1.3.6.1.2.1.4.13"
"ipReasmReqds" "1.3.6.1.2.1.4.14"
"ipReasmOKs" "1.3.6.1.2.1.4.15"
"ipReasmFails" "1.3.6.1.2.1.4.16"
"ipFragOKs" "1.3.6.1.2.1.4.17"
"ipFragFails" "1.3.6.1.2.1.4.18"
"ipFragCreates" "1.3.6.1.2.1.4.19"
"ipAddrTable" "1.3.6.1.2.1.4.20"
"ipAddrEntry" "1.3.6.1.2.1.4.20.1"
"ipAdEntAddr" "1.3.6.1.2.1.4.20.1.1"
"ipAdEntIfIndex" "1.3.6.1.2.1.4.20.1.2"
"ipAdEntNetMask" "1.3.6.1.2.1.4.20.1.3"
"ipAdEntBcastAddr" "1.3.6.1.2.1.4.20.1.4"
"ipAdEntReasmMaxSize" "1.3.6.1.2.1.4.20.1.5"
"ipRouteTable" "1.3.6.1.2.1.4.21"
"ipRouteEntry" "1.3.6.1.2.1.4.21.1"
"ipRouteDest" "1.3.6.1.2.1.4.21.1.1"
"ipRouteIfIndex" "1.3.6.1.2.1.4.21.1.2"
"ipRouteMetric1" "1.3.6.1.2.1.4.21.1.3"
"ipRouteMetric2" "1.3.6.1.2.1.4.21.1.4"
"ipRouteMetric3" "1.3.6.1.2.1.4.21.1.5"
"ipRouteMetric4" "1.3.6.1.2.1.4.21.1.6"
"ipRouteNextHop" "1.3.6.1.2.1.4.21.1.7"
"ipRouteType" "1.3.6.1.2.1.4.21.1.8"
"ipRouteProto" "1.3.6.1.2.1.4.21.1.9"
"ipRouteAge" "1.3.6.1.2.1.4.21.1.10"
"ipRouteMask" "1.3.6.1.2.1.4.21.1.11"
"ipRouteMetric5" "1.3.6.1.2.1.4.21.1.12"
"ipRouteInfo" "1.3.6.1.2.1.4.21.1.13"
"ipNetToMediaTable" "1.3.6.1.2.1.4.22"
"ipNetToMediaEntry" "1.3.6.1.2.1.4.22.1"
"ipNetToMediaIfIndex" "1.3.6.1.2.1.4.22.1.1"
"ipNetToMediaPhysAddress" "1.3.6.1.2.1.4.22.1.2"
"ipNetToMediaNetAddress" "1.3.6.1.2.1.4.22.1.3"
"ipNetToMediaType" "1.3.6.1.2.1.4.22.1.4"
"ipRoutingDiscards" "1.3.6.1.2.1.4.23"
"icmp" "1.3.6.1.2.1.5"
"icmpInMsgs" "1.3.6.1.2.1.5.1"
"icmpInErrors" "1.3.6.1.2.1.5.2"
"icmpInDestUnreachs" "1.3.6.1.2.1.5.3"
"icmpInTimeExcds" "1.3.6.1.2.1.5.4"
"icmpInParmProbs" "1.3.6.1.2.1.5.5"
"icmpInSrcQuenchs" "1.3.6.1.2.1.5.6"
"icmpInRedirects" "1.3.6.1.2.1.5.7"
"icmpInEchos" "1.3.6.1.2.1.5.8"
"icmpInEchoReps" "1.3.6.1.2.1.5.9"
"icmpInTimestamps" "1.3.6.1.2.1.5.10"
"icmpInTimestampReps" "1.3.6.1.2.1.5.11"
"icmpInAddrMasks" "1.3.6.1.2.1.5.12"
"icmpInAddrMaskReps" "1.3.6.1.2.1.5.13"
"icmpOutMsgs" "1.3.6.1.2.1.5.14"
"icmpOutErrors" "1.3.6.1.2.1.5.15"
"icmpOutDestUnreachs" "1.3.6.1.2.1.5.16"
"icmpOutTimeExcds" "1.3.6.1.2.1.5.17"
"icmpOutParmProbs" "1.3.6.1.2.1.5.18"
"icmpOutSrcQuenchs" "1.3.6.1.2.1.5.19"
"icmpOutRedirects" "1.3.6.1.2.1.5.20"
"icmpOutEchos" "1.3.6.1.2.1.5.21"
"icmpOutEchoReps" "1.3.6.1.2.1.5.22"
"icmpOutTimestamps" "1.3.6.1.2.1.5.23"
"icmpOutTimestampReps" "1.3.6.1.2.1.5.24"
"icmpOutAddrMasks" "1.3.6.1.2.1.5.25"
"icmpOutAddrMaskReps" "1.3.6.1.2.1.5.26"
"tcp" "1.3.6.1.2.1.6"
"tcpRtoAlgorithm" "1.3.6.1.2.1.6.1"
"tcpRtoMin" "1.3.6.1.2.1.6.2"
"tcpRtoMax" "1.3.6.1.2.1.6.3"
"tcpMaxConn" "1.3.6.1.2.1.6.4"
"tcpActiveOpens" "1.3.6.1.2.1.6.5"
"tcpPassiveOpens" "1.3.6.1.2.1.6.6"
"tcpAttemptFails" "1.3.6.1.2.1.6.7"
"tcpEstabResets" "1.3.6.1.2.1.6.8"
"tcpCurrEstab" "1.3.6.1.2.1.6.9"
"tcpInSegs" "1.3.6.1.2.1.6.10"
"tcpOutSegs" "1.3.6.1.2.1.6.11"
"tcpRetransSegs" "1.3.6.1.2.1.6.12"
"tcpConnTable" "1.3.6.1.2.1.6.13"
"tcpConnEntry" "1.3.6.1.2.1.6.13.1"
"tcpConnState" "1.3.6.1.2.1.6.13.1.1"
"tcpConnLocalAddress" "1.3.6.1.2.1.6.13.1.2"
"tcpConnLocalPort" "1.3.6.1.2.1.6.13.1.3"
"tcpConnRemAddress" "1.3.6.1.2.1.6.13.1.4"
"tcpConnRemPort" "1.3.6.1.2.1.6.13.1.5"
"tcpInErrs" "1.3.6.1.2.1.6.14"
"tcpOutRsts" "1.3.6.1.2.1.6.15"
"udp" "1.3.6.1.2.1.7"
"udpInDatagrams" "1.3.6.1.2.1.7.1"
"udpNoPorts" "1.3.6.1.2.1.7.2"
"udpInErrors" "1.3.6.1.2.1.7.3"
"udpOutDatagrams" "1.3.6.1.2.1.7.4"
"udpTable" "1.3.6.1.2.1.7.5"
"udpEntry" "1.3.6.1.2.1.7.5.1"
"udpLocalAddress" "1.3.6.1.2.1.7.5.1.1"
"udpLocalPort" "1.3.6.1.2.1.7.5.1.2"
"egp" "1.3.6.1.2.1.8"
"egpInMsgs" "1.3.6.1.2.1.8.1"
"egpInErrors" "1.3.6.1.2.1.8.2"
"egpOutMsgs" "1.3.6.1.2.1.8.3"
"egpOutErrors" "1.3.6.1.2.1.8.4"
"egpNeighTable" "1.3.6.1.2.1.8.5"
"egpNeighEntry" "1.3.6.1.2.1.8.5.1"
"egpNeighState" "1.3.6.1.2.1.8.5.1.1"
"egpNeighAddr" "1.3.6.1.2.1.8.5.1.2"
"egpNeighAs" "1.3.6.1.2.1.8.5.1.3"
"egpNeighInMsgs" "1.3.6.1.2.1.8.5.1.4"
"egpNeighInErrs" "1.3.6.1.2.1.8.5.1.5"
"egpNeighOutMsgs" "1.3.6.1.2.1.8.5.1.6"
"egpNeighOutErrs" "1.3.6.1.2.1.8.5.1.7"
"egpNeighInErrMsgs" "1.3.6.1.2.1.8.5.1.8"
"egpNeighOutErrMsgs" "1.3.6.1.2.1.8.5.1.9"
"egpNeighStateUps" "1.3.6.1.2.1.8.5.1.10"
"egpNeighStateDowns" "1.3.6.1.2.1.8.5.1.11"
"egpNeighIntervalHello" "1.3.6.1.2.1.8.5.1.12"
"egpNeighIntervalPoll" "1.3.6.1.2.1.8.5.1.13"
"egpNeighMode" "1.3.6.1.2.1.8.5.1.14"
"egpNeighEventTrigger" "1.3.6.1.2.1.8.5.1.15"
"egpAs" "1.3.6.1.2.1.8.6"
"transmission" "1.3.6.1.2.1.10"
"snmp" "1.3.6.1.2.1.11"
"snmpInPkts" "1.3.6.1.2.1.11.1"
"snmpOutPkts" "1.3.6.1.2.1.11.2"
"snmpInBadVersions" "1.3.6.1.2.1.11.3"
"snmpInBadCommunityNames" "1.3.6.1.2.1.11.4"
"snmpInBadCommunityUses" "1.3.6.1.2.1.11.5"
"snmpInASNParseErrs" "1.3.6.1.2.1.11.6"
"snmpInTooBigs" "1.3.6.1.2.1.11.8"
"snmpInNoSuchNames" "1.3.6.1.2.1.11.9"
"snmpInBadValues" "1.3.6.1.2.1.11.10"
"snmpInReadOnlys" "1.3.6.1.2.1.11.11"
"snmpInGenErrs" "1.3.6.1.2.1.11.12"
"snmpInTotalReqVars" "1.3.6.1.2.1.11.13"
"snmpInTotalSetVars" "1.3.6.1.2.1.11.14"
"snmpInGetRequests" "1.3.6.1.2.1.11.15"
"snmpInGetNexts" "1.3.6.1.2.1.11.16"
"snmpInSetRequests" "1.3.6.1.2.1.11.17"
"snmpInGetResponses" "1.3.6.1.2.1.11.18"
"snmpInTraps" "1.3.6.1.2.1.11.19"
"snmpOutTooBigs" "1.3.6.1.2.1.11.20"
"snmpOutNoSuchNames" "1.3.6.1.2.1.11.21"
"snmpOutBadValues" "1.3.6.1.2.1.11.22"
"snmpOutGenErrs" "1.3.6.1.2.1.11.24"
"snmpOutGetRequests" "1.3.6.1.2.1.11.25"
"snmpOutGetNexts" "1.3.6.1.2.1.11.26"
"snmpOutSetRequests" "1.3.6.1.2.1.11.27"
"snmpOutGetResponses" "1.3.6.1.2.1.11.28"
"snmpOutTraps" "1.3.6.1.2.1.11.29"
"snmpEnableAuthenTraps" "1.3.6.1.2.1.11.30"
"experimental" "1.3.6.1.3"
"private" "1.3.6.1.4"
"enterprises" "1.3.6.1.4.1"
"radwin" "1.3.6.1.4.1.4458"
"radwinProducts" "1.3.6.1.4.1.4458.20"
"winlink1000Family" "1.3.6.1.4.1.4458.20.2"
"odu" "1.3.6.1.4.1.4458.20.2.1"
"oduIntegratedAntenna" "1.3.6.1.4.1.4458.20.2.1.1"
"oduExternalAntenna" "1.3.6.1.4.1.4458.20.2.1.2"
"radwin2000Family" "1.3.6.1.4.1.4458.20.3"
"odu2000" "1.3.6.1.4.1.4458.20.3.1"
"odu2KIntegratedAntenna" "1.3.6.1.4.1.4458.20.3.1.1"
"odu2KExternalAntenna" "1.3.6.1.4.1.4458.20.3.1.2"
"gpsSynchronizerFamily" "1.3.6.1.4.1.4458.20.4"
"oduGSU" "1.3.6.1.4.1.4458.20.4.1"
"oduGSUExternalAntenna" "1.3.6.1.4.1.4458.20.4.1.2"
"hssSyncUnits" "1.3.6.1.4.1.4458.20.4.2"
"hssISU" "1.3.6.1.4.1.4458.20.4.2.1"
"hssGSU" "1.3.6.1.4.1.4458.20.4.2.2"
"radwin5000HBSFamily" "1.3.6.1.4.1.4458.20.5"
"oduHBS" "1.3.6.1.4.1.4458.20.5.1"
"oduHBSIntegratedAntenna" "1.3.6.1.4.1.4458.20.5.1.1"
"oduHBSExternalAntenna" "1.3.6.1.4.1.4458.20.5.1.2"
"radwin5000HSUFamily" "1.3.6.1.4.1.4458.20.6"
"oduHSU" "1.3.6.1.4.1.4458.20.6.1"
"oduHSUIntegratedAntenna" "1.3.6.1.4.1.4458.20.6.1.1"
"oduHSUExternalAntenna" "1.3.6.1.4.1.4458.20.6.1.2"
"radwin6000Family" "1.3.6.1.4.1.4458.20.10"
"odu6000" "1.3.6.1.4.1.4458.20.10.1"
"odu6K" "1.3.6.1.4.1.4458.20.10.1.1"
"gateway6000" "1.3.6.1.4.1.4458.20.10.2"
"gateway6K" "1.3.6.1.4.1.4458.20.10.2.1"
"radwinWiFiAPFamily" "1.3.6.1.4.1.4458.20.20"
"odu600" "1.3.6.1.4.1.4458.20.20.1"
"oduWiFiAP" "1.3.6.1.4.1.4458.20.20.1.1"
"winlink1000" "1.3.6.1.4.1.4458.1000"
"winlink1000#" "1.3.6.1.4.1.4458.1000.0"
"trunkStateChanged" "1.3.6.1.4.1.4458.1000.0.1"
"linkUp" "1.3.6.1.4.1.4458.1000.0.2"
"linkDown" "1.3.6.1.4.1.4458.1000.0.3"
"detectIDU" "1.3.6.1.4.1.4458.1000.0.4"
"disconnectIDU" "1.3.6.1.4.1.4458.1000.0.5"
"mismatchIDU" "1.3.6.1.4.1.4458.1000.0.6"
"openedServices" "1.3.6.1.4.1.4458.1000.0.7"
"closedServices" "1.3.6.1.4.1.4458.1000.0.8"
"incompatibleODUs" "1.3.6.1.4.1.4458.1000.0.9"
"incompatibleIDUs" "1.3.6.1.4.1.4458.1000.0.10"
"incompatibleOduIdu" "1.3.6.1.4.1.4458.1000.0.11"
"probingChannel" "1.3.6.1.4.1.4458.1000.0.12"
"radarDetected" "1.3.6.1.4.1.4458.1000.0.13"
"transmittingOnChannel" "1.3.6.1.4.1.4458.1000.0.14"
"scanningChannels" "1.3.6.1.4.1.4458.1000.0.15"
"incompatiblePartner" "1.3.6.1.4.1.4458.1000.0.16"
"timeClockSet" "1.3.6.1.4.1.4458.1000.0.17"
"configurationChanged" "1.3.6.1.4.1.4458.1000.0.18"
"hssOpStateChangedToINU" "1.3.6.1.4.1.4458.1000.0.19"
"hssOpStateChangedToHSM" "1.3.6.1.4.1.4458.1000.0.20"
"hssOpStateChangedToHSC" "1.3.6.1.4.1.4458.1000.0.21"
"vlanModeActive" "1.3.6.1.4.1.4458.1000.0.22"
"spectrumAnalysis" "1.3.6.1.4.1.4458.1000.0.23"
"hbsHsuDeregisteredOffline" "1.3.6.1.4.1.4458.1000.0.24"
"hbsHsuDeregisteredSuccessfully" "1.3.6.1.4.1.4458.1000.0.25"
"hbsHsuRegisteredSuccessfully" "1.3.6.1.4.1.4458.1000.0.26"
"hbsHsuRegistrationFailed" "1.3.6.1.4.1.4458.1000.0.27"
"hbsHsuViolatedState" "1.3.6.1.4.1.4458.1000.0.28"
"hsuViolatedState" "1.3.6.1.4.1.4458.1000.0.29"
"hbsUnregisteredSynchronizedHsu" "1.3.6.1.4.1.4458.1000.0.30"
"hbsUnregisteredUnsynchronizedHsu" "1.3.6.1.4.1.4458.1000.0.31"
"cableQuality" "1.3.6.1.4.1.4458.1000.0.32"
"httpAuthentication" "1.3.6.1.4.1.4458.1000.0.33"
"telnetAuthentication" "1.3.6.1.4.1.4458.1000.0.34"
"tdmServiceAlarm" "1.3.6.1.4.1.4458.1000.0.100"
"ethServiceClosed" "1.3.6.1.4.1.4458.1000.0.101"
"ethServiceNotPermitted" "1.3.6.1.4.1.4458.1000.0.102"
"encryptionAlarm" "1.3.6.1.4.1.4458.1000.0.103"
"changeLinkPasswordAlarm" "1.3.6.1.4.1.4458.1000.0.104"
"externalAlarmInPort1Alarm" "1.3.6.1.4.1.4458.1000.0.105"
"externalAlarmInPort2Alarm" "1.3.6.1.4.1.4458.1000.0.106"
"bitFailedAlarm" "1.3.6.1.4.1.4458.1000.0.107"
"wrongConfigurationLoadedAlarm" "1.3.6.1.4.1.4458.1000.0.108"
"lanPort1DisconnectedAlarm" "1.3.6.1.4.1.4458.1000.0.109"
"lanPort2DisconnectedAlarm" "1.3.6.1.4.1.4458.1000.0.110"
"mngPortDisconnectedAlarm" "1.3.6.1.4.1.4458.1000.0.111"
"externalAlarmInPort3Alarm" "1.3.6.1.4.1.4458.1000.0.112"
"externalAlarmInPort4Alarm" "1.3.6.1.4.1.4458.1000.0.113"
"swVersionsMismatchFullCompatibilityAlarm" "1.3.6.1.4.1.4458.1000.0.114"
"swVersionsMismatchRestrictedCompatibilityAlarm" "1.3.6.1.4.1.4458.1000.0.115"
"swVersionsMismatchSoftwareUpgradeRequired" "1.3.6.1.4.1.4458.1000.0.116"
"swVersionsIncompatible" "1.3.6.1.4.1.4458.1000.0.117"
"hssMultipleSourcesDetectedAlarm" "1.3.6.1.4.1.4458.1000.0.118"
"hssSyncToProperSourceStoppedAlarm" "1.3.6.1.4.1.4458.1000.0.119"
"hssSyncPulseDetectedAlarm" "1.3.6.1.4.1.4458.1000.0.120"
"tdmBackupAlarm" "1.3.6.1.4.1.4458.1000.0.121"
"linkLockUnauthorizedRemoteODU" "1.3.6.1.4.1.4458.1000.0.122"
"linkLockUnauthorizedODU" "1.3.6.1.4.1.4458.1000.0.123"
"hotStandbyAlarm" "1.3.6.1.4.1.4458.1000.0.124"
"sfpInsertion" "1.3.6.1.4.1.4458.1000.0.126"
"sfpPort1DisconnectedAlarm" "1.3.6.1.4.1.4458.1000.0.127"
"ringRplStateActiveAlarm" "1.3.6.1.4.1.4458.1000.0.128"
"desiredRatioCanNotBeAppliedAlarm" "1.3.6.1.4.1.4458.1000.0.129"
"cbwMismatch" "1.3.6.1.4.1.4458.1000.0.130"
"gpsNotSynchronized" "1.3.6.1.4.1.4458.1000.0.131"
"pdTooHighDueCbwLimitations" "1.3.6.1.4.1.4458.1000.0.132"
"hbsEncryptionAlarm" "1.3.6.1.4.1.4458.1000.0.133"
"hbsEhServiceClosedToHsu" "1.3.6.1.4.1.4458.1000.0.134"
"hbsUnsynchronizedHsuAlarm" "1.3.6.1.4.1.4458.1000.0.135"
"hbsInactiveHbsAlarm" "1.3.6.1.4.1.4458.1000.0.136"
"incompatibleHsu" "1.3.6.1.4.1.4458.1000.0.137"
"hsuUnsupportedBeacon" "1.3.6.1.4.1.4458.1000.0.138"
"lanPortDisconnectedAlarm" "1.3.6.1.4.1.4458.1000.0.139"
"poePortDisconnectedAlarm" "1.3.6.1.4.1.4458.1000.0.140"
"poePowerConsumptionAlarm" "1.3.6.1.4.1.4458.1000.0.141"
"hobupFaultyStateAlarm" "1.3.6.1.4.1.4458.1000.0.149"
"gpsOverCurrentAlarm" "1.3.6.1.4.1.4458.1000.0.150"
"gpsCommunicationFailiureAlarm" "1.3.6.1.4.1.4458.1000.0.151"
"temperatureThresholdAlarm" "1.3.6.1.4.1.4458.1000.0.152"
"localRouterDiscoveryStatus" "1.3.6.1.4.1.4458.1000.0.153"
"trackRouterDiscoveryStatus" "1.3.6.1.4.1.4458.1000.0.154"
"lastUserSnmpAccessOverHourAgo" "1.3.6.1.4.1.4458.1000.0.155"
"btsTargetUnreachable" "1.3.6.1.4.1.4458.1000.0.156"
"tdmServiceClear" "1.3.6.1.4.1.4458.1000.0.200"
"ethServiceOpened" "1.3.6.1.4.1.4458.1000.0.201"
"encryptionClear" "1.3.6.1.4.1.4458.1000.0.203"
"changeLinkPasswordClear" "1.3.6.1.4.1.4458.1000.0.204"
"externalAlarmInPort1Clear" "1.3.6.1.4.1.4458.1000.0.205"
"externalAlarmInPort2Clear" "1.3.6.1.4.1.4458.1000.0.206"
"lanPort1Clear" "1.3.6.1.4.1.4458.1000.0.209"
"lanPort2Clear" "1.3.6.1.4.1.4458.1000.0.210"
"mngPortClear" "1.3.6.1.4.1.4458.1000.0.211"
"externalAlarmInPort3Clear" "1.3.6.1.4.1.4458.1000.0.212"
"externalAlarmInPort4Clear" "1.3.6.1.4.1.4458.1000.0.213"
"swVersionsMatchFullCompatibilityClear" "1.3.6.1.4.1.4458.1000.0.214"
"swVersionsMatchRestrictedCompatibilityClear" "1.3.6.1.4.1.4458.1000.0.215"
"swVersionsMatchSoftwareUpgradeRequiredClear" "1.3.6.1.4.1.4458.1000.0.216"
"swVersionsCompatibleClear" "1.3.6.1.4.1.4458.1000.0.217"
"hssMultipleSourcesDisappearedClear" "1.3.6.1.4.1.4458.1000.0.218"
"hssSyncToProperSourceAchievedClear" "1.3.6.1.4.1.4458.1000.0.219"
"hssSyncPulseDisappearedClear" "1.3.6.1.4.1.4458.1000.0.220"
"tdmBackupClear" "1.3.6.1.4.1.4458.1000.0.221"
"linkLockAuthorizedRemoteODU" "1.3.6.1.4.1.4458.1000.0.222"
"linkLockAuthorizedODU" "1.3.6.1.4.1.4458.1000.0.223"
"linkAuthenticationDisabled" "1.3.6.1.4.1.4458.1000.0.224"
"hotStandbyClear" "1.3.6.1.4.1.4458.1000.0.225"
"sfpExtraction" "1.3.6.1.4.1.4458.1000.0.226"
"sfpPort1Clear" "1.3.6.1.4.1.4458.1000.0.227"
"compatibleIdus" "1.3.6.1.4.1.4458.1000.0.228"
"desiredRatioCanNotBeAppliedClear" "1.3.6.1.4.1.4458.1000.0.229"
"cbwMatch" "1.3.6.1.4.1.4458.1000.0.230"
"switchCbwAndChannel" "1.3.6.1.4.1.4458.1000.0.231"
"ringRplStateIdle" "1.3.6.1.4.1.4458.1000.0.232"
"ringEthServiceStatus" "1.3.6.1.4.1.4458.1000.0.233"
"ringFirstRpmReceived" "1.3.6.1.4.1.4458.1000.0.234"
"ringEthernetSrviceUnblockedTO" "1.3.6.1.4.1.4458.1000.0.235"
"gpsSynchronized" "1.3.6.1.4.1.4458.1000.0.236"
"hbsEncryptionClear" "1.3.6.1.4.1.4458.1000.0.237"
"hbsEhServiceOpenedToHsu" "1.3.6.1.4.1.4458.1000.0.238"
"hbsSynchronizedHsuAlarm" "1.3.6.1.4.1.4458.1000.0.239"
"hbsActiveHbs" "1.3.6.1.4.1.4458.1000.0.240"
"switchCBW" "1.3.6.1.4.1.4458.1000.0.241"
"changeRatio" "1.3.6.1.4.1.4458.1000.0.242"
"lanPortClear" "1.3.6.1.4.1.4458.1000.0.243"
"poePortClear" "1.3.6.1.4.1.4458.1000.0.244"
"poePowerConsumptionClear" "1.3.6.1.4.1.4458.1000.0.245"
"incompatibleHbsHsu" "1.3.6.1.4.1.4458.1000.0.246"
"mobilityLinkOff" "1.3.6.1.4.1.4458.1000.0.247"
"enterLocalConnection" "1.3.6.1.4.1.4458.1000.0.248"
"hobupActiveStateFaultyClear" "1.3.6.1.4.1.4458.1000.0.249"
"hobupStandbyState" "1.3.6.1.4.1.4458.1000.0.250"
"gpsOverCurrentClear" "1.3.6.1.4.1.4458.1000.0.251"
"temperatureThresholdClear" "1.3.6.1.4.1.4458.1000.0.252"
"localRouterDiscoverySucceed" "1.3.6.1.4.1.4458.1000.0.253"
"trackRouterDiscoverySucceed" "1.3.6.1.4.1.4458.1000.0.254"
"qosVersion2StrictMismatch" "1.3.6.1.4.1.4458.1000.0.255"
"qosVersion2TtlMismatch" "1.3.6.1.4.1.4458.1000.0.256"
"btsTargetIsReachable" "1.3.6.1.4.1.4458.1000.0.257"
"tcNotSupportedByHSU" "1.3.6.1.4.1.4458.1000.0.258"
"syncEPortHOStateChange" "1.3.6.1.4.1.4458.1000.0.259"
"syncEPortFailureStateChange" "1.3.6.1.4.1.4458.1000.0.260"
"btsCpeUpdateServiceFailed" "1.3.6.1.4.1.4458.1000.0.261"
"btsCpeUpdateServiceSucceed" "1.3.6.1.4.1.4458.1000.0.262"
"radiusServerNoREsponse" "1.3.6.1.4.1.4458.1000.0.263"
"noRadiusServerRespond" "1.3.6.1.4.1.4458.1000.0.264"
"radiusServerRespondedSuccessfully" "1.3.6.1.4.1.4458.1000.0.265"
"bsaAlignmentStarted" "1.3.6.1.4.1.4458.1000.0.266"
"bsaAlignmentFinished" "1.3.6.1.4.1.4458.1000.0.267"
"bsaAlignmentTriggered" "1.3.6.1.4.1.4458.1000.0.268"
"winlink1000Odu" "1.3.6.1.4.1.4458.1000.1"
"winlink1000OduAdmin" "1.3.6.1.4.1.4458.1000.1.1"
"winlink1000OduAdmProductType" "1.3.6.1.4.1.4458.1000.1.1.1"
"winlink1000OduAdmHwRev" "1.3.6.1.4.1.4458.1000.1.1.2"
"winlink1000OduAdmSwRev" "1.3.6.1.4.1.4458.1000.1.1.3"
"winlink1000OduAdmLinkName" "1.3.6.1.4.1.4458.1000.1.1.4"
"winlink1000OduAdmResetCmd" "1.3.6.1.4.1.4458.1000.1.1.5"
"winlink1000OduAdmAddres" "1.3.6.1.4.1.4458.1000.1.1.6"
"winlink1000OduAdmMask" "1.3.6.1.4.1.4458.1000.1.1.7"
"winlink1000OduAdmGateway" "1.3.6.1.4.1.4458.1000.1.1.8"
"winlink1000OduAdmBroadcast" "1.3.6.1.4.1.4458.1000.1.1.10"
"winlink1000OduAdmHostsTable" "1.3.6.1.4.1.4458.1000.1.1.12"
"winlink1000OduAdmHostsEntry" "1.3.6.1.4.1.4458.1000.1.1.12.1"
"winlink1000OduAdmHostsIndex" "1.3.6.1.4.1.4458.1000.1.1.12.1.1"
"winlink1000OduAdmHostsIp" "1.3.6.1.4.1.4458.1000.1.1.12.1.2"
"winlink1000OduAdmHostsPort" "1.3.6.1.4.1.4458.1000.1.1.12.1.3"
"winlink1000OduAdmHostsSecurityModel" "1.3.6.1.4.1.4458.1000.1.1.12.1.4"
"winlink1000OduAdmHostsUserName" "1.3.6.1.4.1.4458.1000.1.1.12.1.5"
"winlink1000OduAdmHostsPassword" "1.3.6.1.4.1.4458.1000.1.1.12.1.6"
"winlink1000OduAdmHostsIPv6" "1.3.6.1.4.1.4458.1000.1.1.12.1.7"
"winlink1000OduBuzzerAdminState" "1.3.6.1.4.1.4458.1000.1.1.13"
"winlink1000OduProductId" "1.3.6.1.4.1.4458.1000.1.1.14"
"winlink1000GeneralSSHSupport" "1.3.6.1.4.1.4458.1000.100.8"
Reason: Please use [code][/code] tags around long output
The MIB file looks good as the output of the translate command shows.
What I think the issue is that the check_snmp plugin is not searching through all of the MIB files in the /usr/share/snmp/mibs/ folder so to change that, you will have to to the following.
Create the file /etc/snmp/snmp.conf, and put into it:
This tells the snmp commands that they should load ALL of the mibs when they are ran.
Save the file.
After the change, this will load all the MIB files when a snmp command is run on your server and that should fix the issue for you.
mibs +ALL
Save the file.
tgriep wrote:The MIB file looks good as the output of the translate command shows.
Create the file /etc/snmp/snmp.conf, and put into it:This tells the snmp commands that they should load ALL of the mibs when they are ran.Code: Select all
mibs +ALL
Save the file.
Nope.
[root@localhost libexec]# ./check_snmp -H 192.168.1.110 -o winlink1000OduAdmProductType -P 3 --seclevel=authPriv --secname=admin --authproto=md5 --authpasswd='netman123' --privpasswd='netman123' --privproto=des
Run a snmpwalk with debugging enabled and post it here so we can see what the error is.
Then run this and post it as well
I am thinking that even though the snmptranslate worked, the MIB file is corrupted so if you can post it, that would help.
snmpwalk 192.168.1.110 -v 3 -a MD5 -A netman123 -l authPriv -x des -X netman123 -u admin -M /usr/share/snmp/mibs/ 1.3.6.1.4.1.4458.1000.1.1.1 -D all
ls -l /usr/share/snmp/mibs/
