Check_NRPE Error
Ravina
Check_NRPE Error
Post by Ravina »
I'm getting the below error ,Please help
[root@bdl09node04 log]# /usr/local/nagios/libexec/check_nrpe -H 127.0.0.1
CHECK_NRPE: Error - Could not connect to 127.0.0.1: Connection reset by peer
[root@bdl09node04 log]# netstat -at | egrep "nrpe|5666"
tcp 0 0 0.0.0.0:nrpe 0.0.0.0:* LISTEN
tcp6 0 0 [::]:nrpe [::]:* LISTEN
Regards,
Anuragh
Re: Check_NRPE Error
There is no point in running check_nrpe against 127.0.0.1, really. What exactly are you looking to accomplish out of this?
Post by dwhitfield »
What version of NRPE are you using? Are you eventually trying to connect to a remote host? If so, what OS/version is the remote host running?
As @rkennedy mentioned, NRPE is the Nagios *Remote* Plugin Executor. If you are trying to monitor the localhost, then you can just run the checks directly.
What version of Core are you using? Was it compiled from source or installed from distro repos? On what OS/version is nagios running? cat /etc/*-release may be of use.
