CHECK_ESX Unkown
nagiosjam
CHECK_ESX Unkown
Post by nagiosjam »
Hello
I have a VMWARE server that takes a few days giving this error when executing the check_esx_net
The rest of checks with check_esx does not fail. I have rebooted the vmware server and it continues giving this error,
please help. Thank you
CHECK_ESX UNKNOWN - plugint time out (timeout 30s)
use linuxvmware
hostgroup_name vmware
service_description ESXi Network usage
check_command check_esx_net!502400!512000
Define command {
Command_name check_esx_net
Command_line $ USER1 $ / check_esx -H $ HOSTADDRESS $ -u nagios -p xxxx -l net -s usage -w $ ARG1 $ -c $ ARG2 $
Re: CHECK_ESX Unkown
Post by mcapra »
Could you share where you got the check_esx plugin from? It probably has a timeout value you can increase up to 60 seconds. That might prevent the false negatives.
nagiosjam
Post by nagiosjam »
Hello
I increased the timeout from 30 to 40 in the file check_esx and now everything ok, thank you very much
cdienger
Post by cdienger »
Is it okay to close this thread or did you have any further questions?
nagiosjam
Post by nagiosjam »
good morning
I fail the plugin again.
I increase the timeout to 59 and it continues giving me CHECK_ESX UNKNOWN - plugin timed out (timeout 59s)
If I put timeout 60 instead of UNKOWN I get critical and this error (Service check timed out after 60.01 seconds)
Please help
Thank you
Post by mcapra »
check_esx is just a really heavy plugin. If you've added checks to your Nagios Core machine recently, you may need to increase the available physical resources. Have you either added checks to this machine recently or adjusted it's available physical resources?
nagiosjam
Post by nagiosjam »
Hello
No, nothing has been added or nothing has been adjusted.
It's just the way it was before it failed.
I am using check_esx with other servers and they do not give me problems
Thank you
Post by mcapra »
Can you send us copies of your nagios logs for the last few days? They're typically found in /usr/local/nagios/var/archives or whatever path is set under log_archive_path in your nagios.cfg.
Can we also see some sample Service definitions leveraging check_esx?
nagiosjam
Post by nagiosjam »
Again, ok again and work, thank you, hopefully it will not fail again. You can close the thread
