I need to change the email notification message how do I do that?
like this is the notification message I get
Notification Type: RECOVERY
Service: check_http www.google.ca
Host: hostname
Address: 192.168.1.2
State: OK
Date/Time: Fri Mar 24 16:27:36 EDT 2017
Additional Info:
HTTP OK: Status line output matched 1 200 - 60531 bytes in 4.859 second response time
is there anyway i can change the whole thing? like i want a message just for this host only.
please let me know
ADD NEW TEXT
ADD NEW TEXT
Prendre soin de sa sante viagrasansordonnancefr.com meilleure pharmacie
Re: ADD NEW TEXT
The default email templates are defined in /usr/local/nagios/etc/objects/commands.cfg with the command_lines for "notify-host-by-email" and "notify-service-by-email."
Re: ADD NEW TEXT
is there a way to put this in place ?
Here is the subject and body of the emails:
Subject:
Anomaly - Monitoring of the website (wwbsite.com) -% type of anomaly%
Type of anomaly:% type of anomaly%
Body :
This is to notify you that we have detected an anomaly on the website : website.com
Please check the website as soon as possible.
Have a good day.
Subject:
Body :
Have a good day.
Re: ADD NEW TEXT
You can try something like:
command_line /usr/bin/printf "%b" "Hello,\n\nThis is to notify you that we have detected an anomaly on the website : $ADDRESS$\n\nType of anonmaly: $NOTIFICATIONTYPE$\n\nPlease check the website as soon as possible.\n\nHave a good day.| /bin/mail -s "Anomaly - Monitoring of the website($ADDRESS) - $NOTIFICATIONTYPE$" $CONTACTEMAIL$
List of default macros can be found at:
https://assets.nagios.com/downloads/nag ... olist.html
Re: ADD NEW TEXT
sorry i'm new at this i do not understand this lol
Re: ADD NEW TEXT
/usr/local/nagios/etc/objects/commands.cfg contains a definition for "notify-service-by-email" which specifies the format of the email with command_line. You can modify this line/format as you see fit. After making the changes you need to restart the serivce with "service nagios restart"
Re: ADD NEW TEXT
is that for one host only ?!?!
Re: ADD NEW TEXT
No, this would apply to all services or hosts that call it.
You may find it beneficial to bookmark https://library.nagios.com/library/prod ... e/manuals/ which has links to further documentation that can help you with configuration Nagios.
