hi
we use nagios core 4.3.1 and plugins 2.2.1. after our upgrade, quick search not working and return below error:
It appears as though you do not have permission to view information for any of the hosts you requested...
If you believe this is an error, check the HTTP server authentication requirements for accessing this CGI
and check the authorization options in your CGI configuration file.
what your approach?
thanks
Nagios Core 4.3.1
Re: Nagios Core 4.3.1
That is fixed in the pending release. You can get it at https://github.com/NagiosEnterprises/na ... rc1.tar.gz if you want the fix now, or if you want to wait a little, the 4.3.2 release is scheduled for May 8.asiansuntrading wrote:hi
