check_ping: <max_packets> (%s) must be a non-negative number
donnyforbes
Re: check_ping: <max_packets> (%s) must be a non-negative nu
Post by donnyforbes »
here is the /usr/local/nagios/etc/objects/commands.cfg file
# COMMANDS.CFG - SAMPLE COMMAND DEFINITIONS FOR NAGIOS 4.3.2 # # # NOTES: This config file provides you with some example command definitions
#        that you can reference in host, service, and contact definitions.
#        You don't need to keep commands in a separate file from your other
#        object definitions.  This has been done just to make things easier to
#        understand.
#check_nrpe
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$ }
#host and service definitions
name linux-box ; Name of this template
use generic-host ; Inherit default values
check_period 24x7
check_interval 5
retry_interval 1
max_check_attempts 10
notification_period 24x7
notification_interval 30
notification_options d,r
contact_groups admins
register 0 ; DONT REGISTER THIS - ITS A TEMPLATE
#remote Linux/Unix hosts
use linux-box ; Inherit default values from a template
host_name huey  ; The name or IP or remote server
alias RHEL 7.3 ; A longer name for the server
address 192.168.1.42 ; IP address of the remote server
host_name duey  ; The name or IP or remote server
address 192.168.1.43 ; IP address of the remote server
host_name louie   ; The name or IP or remote server
address 192.168.39.10 ; IP address of the remote server
host_name proxy4gl   ; The name or IP or remote server
address 192.168.1.12 ; IP address of the remote server
host_name taz2   ; The name or IP or remote server
address 192.168.1.10 ; IP address of the remote server
host_name tank   ; The name or IP or remote server
address 192.168.1.15 ; IP address of the remote server
host_name ernestine   ; The name or IP or remote server
address 192.168.39.12 ; IP address of the remote server
#remote services monitored
#This service will monitor the CPU Load
host_name huey
service_description CPU Load
check_command check_nrpe!check_load
host_name duey
host_name louie
host_name proxy4gl
host_name taz2
host_name tank
host_name ernestine
#This service will monitor number of currenlty logged on users
host_name huey
service_description Current Users
check_command check_nrpe!check_users
host_name duey
host_name louie
host_name proxy4gl
host_name taz2
host_name tank
host_name ernestine
#This service will monitor the free drive space on /dev/hda1
host_name huey
service_description /dev/hda1 Free Space
check_command check_nrpe!check_hda1
host_name duey
host_name louie
host_name proxy4gl
host_name taz2
host_name tank
host_name ernestine
#service will monitor the total number of processes
host_name huey
service_description Total Processes
check_command check_nrpe!check_total_procs
host_name duey
host_name louie
host_name proxy4gl
host_name taz2
host_name tank
host_name ernestine
# SAMPLE NOTIFICATION COMMANDS
# These are some example notification commands.  They may or may not work on
# your system without modification.  As an example, some systems will require
# you to use "/usr/bin/mailx" instead of "/usr/bin/mail" in the commands below.
	command_name	notify-host-by-email
	command_line	/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
	command_name	notify-service-by-email
	command_line	/usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
# SAMPLE HOST CHECK COMMANDS
# This command checks to see if a host is "alive" by pinging it
# The check must result in a 100% packet loss or 5 second (5000ms) round trip
# average time to produce a critical error.
# Note: Five ICMP echo packets are sent (determined by the '-p 5' argument)
# 'check-host-alive' command definition
#define command{
#        command_name    check-host-alive
#        command_line    $USER1$/check_ping -H HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
# SAMPLE SERVICE CHECK COMMANDS
# These are some example service check commands.  They may or may not work on
# your system, as they must be modified for your plugins.  See the HTML
# documentation on the plugins for examples of how to configure command definitions.
# NOTE:  The following 'check_local_...' functions are designed to monitor
#        various metrics on the host that Nagios is running on (i.e. this one).
# 'check_local_disk' command definition
        command_name    check_local_disk
        command_line    $USER1$/check_disk -w $ARG1$ -c $ARG2$ -p $ARG3$
# 'check_local_load' command definition
        command_name    check_local_load
        command_line    $USER1$/check_load -w $ARG1$ -c $ARG2$
# 'check_local_procs' command definition
        command_name    check_local_procs
        command_line    $USER1$/check_procs -w $ARG1$ -c $ARG2$ -s $ARG3$
# 'check_local_users' command definition
        command_name    check_local_users
        command_line    $USER1$/check_users -w $ARG1$ -c $ARG2$
# 'check_local_swap' command definition
	command_name	check_local_swap
	command_line	$USER1$/check_swap -w $ARG1$ -c $ARG2$
# 'check_local_mrtgtraf' command definition
	command_name	check_local_mrtgtraf
	command_line	$USER1$/check_mrtgtraf -F $ARG1$ -a $ARG2$ -w $ARG3$ -c $ARG4$ -e $ARG5$
# NOTE:  The following 'check_...' commands are used to monitor services on
#        both local and remote hosts.
# 'check_ftp' command definition
        command_name    check_ftp
        command_line    $USER1$/check_ftp -H $HOSTADDRESS$ $ARG1$
# 'check_hpjd' command definition
        command_name    check_hpjd
        command_line    $USER1$/check_hpjd -H $HOSTADDRESS$ $ARG1$
# 'check_snmp' command definition
        command_name    check_snmp
        command_line    $USER1$/check_snmp -H $HOSTADDRESS$ $ARG1$
# 'check_http' command definition
        command_name    check_http
        command_line    $USER1$/check_http -I $HOSTADDRESS$ $ARG1$
# 'check_ssh' command definition
	command_name	check_ssh
	command_line	$USER1$/check_ssh $ARG1$ $HOSTADDRESS$
# 'check_dhcp' command definition
	command_name	check_dhcp
	command_line	$USER1$/check_dhcp $ARG1$
# 'check_ping' command definition
        command_name    check_ping
        command_line    $USER1$/check_ping -H $HOSTADDRESS$ -w $ARG1$ -c $ARG2$ -p 5
# 'check_pop' command definition
        command_name    check_pop
        command_line    $USER1$/check_pop -H $HOSTADDRESS$ $ARG1$
# 'check_imap' command definition
        command_name    check_imap
        command_line    $USER1$/check_imap -H $HOSTADDRESS$ $ARG1$
# 'check_smtp' command definition
        command_name    check_smtp
        command_line    $USER1$/check_smtp -H $HOSTADDRESS$ $ARG1$
# 'check_tcp' command definition
	command_name	check_tcp
	command_line	$USER1$/check_tcp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
# 'check_udp' command definition
	command_name	check_udp
	command_line	$USER1$/check_udp -H $HOSTADDRESS$ -p $ARG1$ $ARG2$
	command_name	check_nt
	command_line	$USER1$/check_nt -H $HOSTADDRESS$ -p 12489 -s F1reF1411  -v $ARG1$ $ARG2$
# SAMPLE PERFORMANCE DATA COMMANDS
# These are sample performance data commands that can be used to send performance
# data output to two text files (one for hosts, another for services).  If you
# plan on simply writing performance data out to a file, consider using the
# host_perfdata_file and service_perfdata_file options in the main config file.
# 'process-host-perfdata' command definition
	command_name	process-host-perfdata
	command_line	/usr/bin/printf "%b" "$LASTHOSTCHECK$\t$HOSTNAME$\t$HOSTSTATE$\t$HOSTATTEMPT$\t$HOSTSTATETYPE$\t$HOSTEXECUTIONTIME$\t$HOSTOUTPUT$\t$HOSTPERFDATA$\n" >> /usr/local/nagios/var/host-perfdata.out
# 'process-service-perfdata' command definition
	command_name	process-service-perfdata
	command_line	/usr/bin/printf "%b" "$LASTSERVICECHECK$\t$HOSTNAME$\t$SERVICEDESC$\t$SERVICESTATE$\t$SERVICEATTEMPT$\t$SERVICESTATETYPE$\t$SERVICEEXECUTIONTIME$\t$SERVICELATENCY$\t$SERVICEOUTPUT$\t$SERVICEPERFDATA$\n" >> /usr/local/nagios/var/service-perfdata.out
donnyforbes
Here is what I notice ...
Failed at step EXEC spawning /usr/lib/systemd/scripts/nagios: No such file or directory
This /usr/lib/systemd/scripts/nagios ----- Does not exist, however it is here
[root@nag systemd]# pwd
/usr/lib/systemd
[root@nag systemd]# ls
catalog             rhel-loadmodules   systemd-bootchart         systemd-importd            systemd-pull            systemd-shutdownd      systemd-user-sessions   user-preset
import-pubring.gpg  rhel-readonly      systemd-bus-proxyd        systemd-initctl            systemd-quotacheck      systemd-sleep          systemd-vconsole-setup
ntp-units.d         system             systemd-cgroups-agent     systemd-journald           systemd-random-seed     systemd-socket-proxyd  system-generators
rhel-autorelabel    systemd            systemd-coredump          systemd-localed            systemd-readahead       systemd-sysctl         system-preset
rhel-configure      systemd-ac-power   systemd-cryptsetup        systemd-logind             systemd-remount-fs      systemd-timedated      system-shutdown
rhel-dmesg          systemd-activate   systemd-fsck              systemd-machined           systemd-reply-password  systemd-udevd          system-sleep
rhel-domainname     systemd-backlight  systemd-hibernate-resume  systemd-machine-id-commit  systemd-rfkill          systemd-update-done    user
rhel-import-state   systemd-binfmt     systemd-hostnamed         systemd-modules-load       systemd-shutdown        systemd-update-utmp    user-generators
[root@nag systemd]#
[root@nag init.d]# pwd
/etc/init.d
[root@nag init.d]# ls
functions  iprdump  iprinit  iprupdate  nagios  netconsole  network  README
[root@nag init.d]#
The /var/log/messages says it should be here /usr/lib/systemd/scripts/nagios is that correct or misleading?
donnyforbes
so I did the following
/usr/lib/systemd/
mkdir scripts
then did this ..
cp /etc/init.d/scripts/nagios -> /usr/lib/systemd/scripts
Then ran systemctl start nagios
tail -f /var/log/messages
Jun 23 09:51:10 nag nagios: Starting nagios:
Jun 23 09:51:10 nag nagios: Nagios Core 4.3.2
Jun 23 09:51:10 nag nagios: Copyright (c) 2009-present Nagios Core Development Team and Community Contributors
Jun 23 09:51:10 nag nagios: Copyright (c) 1999-2009 Ethan Galstad
Jun 23 09:51:10 nag nagios: Last Modified: 2017-05-09
Jun 23 09:51:10 nag nagios: License: GPL
Jun 23 09:51:10 nag nagios: Website: https://www.nagios.org
Jun 23 09:51:10 nag nagios: Reading configuration data...
Jun 23 09:51:10 nag nagios: Read main config file okay...
Jun 23 09:51:10 nag nagios: Read object config files okay...
Jun 23 09:51:10 nag nagios: Running pre-flight check on configuration data...
Jun 23 09:51:10 nag nagios: Checking objects...
Jun 23 09:51:10 nag nagios: Checked 166 services.
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'ansel' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'babylon2' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'babylon3' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'centari' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'cylon2' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'drakh' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'drazi' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'duey' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'ernestine' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'goauld' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'huey' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'localhost' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'louie' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'narn' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'netmon' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'ori' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'pablo' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'prints' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'proxy4gl' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'rdp-server' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'sgc' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'shadow' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'sql' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'tank' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'taz2' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'tokra' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'tollan' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Error: Host check command 'check-host-alive' specified for host 'vorlon' is not defined anywhere!
Jun 23 09:51:10 nag nagios: Checked 28 hosts.
Jun 23 09:51:10 nag nagios: Checked 2 host groups.
Jun 23 09:51:10 nag nagios: Checked 0 service groups.
Jun 23 09:51:10 nag nagios: Checked 1 contacts.
Jun 23 09:51:10 nag nagios: Checked 1 contact groups.
Jun 23 09:51:10 nag nagios: Checked 24 commands.
Jun 23 09:51:10 nag nagios: Checked 5 time periods.
Jun 23 09:51:10 nag nagios: Checked 0 host escalations.
Jun 23 09:51:10 nag nagios: Checked 0 service escalations.
Jun 23 09:51:10 nag nagios: Checking for circular paths...
Jun 23 09:51:10 nag nagios: Checked 0 service dependencies
Jun 23 09:51:10 nag nagios: Checked 0 host dependencies
Jun 23 09:51:10 nag nagios: Checked 5 timeperiods
Jun 23 09:51:10 nag nagios: Checking global event handlers...
Jun 23 09:51:10 nag nagios: Checking obsessive compulsive processor commands...
Jun 23 09:51:10 nag nagios: Checking misc settings...
Jun 23 09:51:10 nag nagios: Total Warnings: 0
Jun 23 09:51:10 nag nagios: Total Errors:   28
Jun 23 09:51:10 nag nagios: ***> One or more problems was encountered while running the pre-flight check...
Jun 23 09:51:10 nag nagios: Check your configuration file(s) to ensure that they contain valid
Jun 23 09:51:10 nag nagios: directives and data definitions.  If you are upgrading from a previous
Jun 23 09:51:10 nag nagios: version of Nagios, you should be aware that some variables/definitions
Jun 23 09:51:10 nag systemd: nagios.service: control process exited, code=exited status=8
Jun 23 09:51:10 nag nagios: may have been removed or modified in this version.  Make sure to read
Jun 23 09:51:10 nag nagios: the HTML documentation regarding the config files, as well as the
Jun 23 09:51:10 nag nagios: 'Whats New' section to find out what has changed.
Jun 23 09:51:10 nag systemd: Failed to start Nagios Core Monitoring Daemon.
Jun 23 09:51:10 nag systemd: Unit nagios.service entered failed state.
Jun 23 09:51:10 nag systemd: nagios.service failed.
Please advise. Thank you.
Can you first make sure you don't have any config errors? Please run the following command to verify configuration:
Note: If the path to the binary and/or the main config file is different, modify the above command accordingly.
You configs don't look right. You don't have a check command configured for your hosts. You are inheriting the check command from the "linux-box" template.
In your template, you have "check-host-alive" command defined.
check_period 24x7
check_interval 5
retry_interval 1
However, your "check-host-alive" command is commented out...
#define command{
In addition to this, you are missing the first "$" in the "$HOSTADDRESS$" macro... See the text in red.
donnyforbes
Ok I fixed this hosts issue. I had that line comment out by accident trying something I remove the comments and start nagios up.
[root@nag objects]# systemctl start nagios
[root@nag objects]# ps -ef |grep nagios
nagios    2693     1  0 10:05 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
nagios    2695  2693  0 10:05 ?        00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios    2696  2693  0 10:05 ?        00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios    2697  2693  0 10:05 ?        00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios    2698  2693  0 10:05 ?        00:00:00 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
nagios    2699  2693  0 10:05 ?        00:00:00 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
root      2768  2328  0 10:06 pts/0    00:00:00 grep --color=auto nagios
[root@nag objects]#
was able to hit the console had to restart httpd.
[root@nag objects]# service httpd restart
Redirecting to /bin/systemctl restart  httpd.service
[root@nag objects]# ps -ef |grep httpd
root      2982     1  1 10:09 ?        00:00:00 /usr/sbin/httpd -DFOREGROUND
apache    2985  2982  0 10:09 ?        00:00:00 /usr/sbin/httpd -DFOREGROUND
apache    2986  2982  0 10:09 ?        00:00:00 /usr/sbin/httpd -DFOREGROUND
apache    2987  2982  0 10:09 ?        00:00:00 /usr/sbin/httpd -DFOREGROUND
apache    2988  2982  0 10:09 ?        00:00:00 /usr/sbin/httpd -DFOREGROUND
apache    2989  2982  0 10:09 ?        00:00:00 /usr/sbin/httpd -DFOREGROUND
root      2997  2328  0 10:09 pts/0    00:00:00 grep --color=auto httpd
[root@nag objects]#
backup and running now, however back to what originated this request. Please see the attached file.
Please see what I am getting on the console.
donnyforbes
Thank you added the $ sign and I think everything is coming up now the way it was before. Thanks so much. I appreciate your assistance.
Post by dwhitfield »
It sounds like this issue has been resolved. Is it okay if we lock this thread? Thanks for choosing the Nagios forums!
donnyforbes
I just want to say that you guys are great with support. Again thank you for assisting us newbe's as we are still learning.
no problem! Are we ready to lock the thread?
