Hi All,
I'm trying to use non weak SSL ciphers with NRPE. I have compiled NRPE to use SSL and have modified nrpe.cfg file to use only TLSv1.2 however it appears that the only ciphers available to the plugin are ADH. Is there away to use a more modern cipher suite?
J
NRPE 3.1.0 ADH
Re: NRPE 3.1.0 ADH
Can you give us a bit more information about your setup?
- What NRPE and check_nrpe versions?
- Source install or repository install?
- What OS and version?
