So I have this configuration for my Palo Alto 2050
use generic-switch
host_name paloalto
parents testSw2
alias Palo Alto 2050 Firewall
address 172.16.0.6
hostgroups firewalls
define hostgroup{
hostgroup_name firewalls ; The name of the hostgroup
alias Firewalls ; Long name of the group
use local-service ; Inherit values from a template
host_name paloalto
service_description Uptime
check_command check_snmp!-C maunakea -o sysUpTimeInstance
host_name paloalto
service_description MGT Port Link Status
check_command check_snmp!-v 2c -C maunakea -o ifOperStatus.2 -r 1 -m RFC1213-MIB
When I run the snmpget for the two services stated above, I get...
[root@nagios-server-model ~]# snmpget -v2c -c maunakea 172.16.0.6 sysUpTimeInstance
DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (581928) 1:36:59.28
[root@nagios-server-model ~]# snmpget -v2c -c maunakea 172.16.0.6 ifOperStatus.2
IF-MIB::ifOperStatus.2 = INTEGER: up(1)
However, I run "./check_snmp 172.16.0.6 -C maunakea -o sysUpTimeInstance" and "./check_snmp 172.16.0.6 -C maunakea -o ifOperStatus.2" and they both returned "CRITICAL - Plugin timed out while executing system call" message.
BUT, I get a critical state with the following information...
CRITICAL
06-29-2017 09:38:57
0d 0h 12m 19s
4/4
Uptime
CRITICAL
06-29-2017 09:39:42
0d 0h 11m 34s
4/4
I don't know what the problem is if I can get snmpget... please help.
check_snmp problem
Re: check_snmp problem
Without the -P option check_snmp will use snmpv1. Try version 2 with:
./check_snmp 1.2.3.4 -P 2c -C maunakea -o sysUpTimeInstance
Thank you! That works!
