Nagios Monitoroing for Solaris Zonestat
padu_3891
Post by padu_3891 »
Hello Team ,
Is there any plugin or script that help me to monitoring the zonestat in solaris .
Re: Nagios Monitoroing for Solaris Zonestat
Post by mcapra »
The Nagios Exchange is a great place to look for that sort of stuff:
https://exchange.nagios.org/
I wasn't able to find anything. Looking over some of the documentation for the zonestat command, I imagine a nagios-compatible wrapper could be written for it. It would require some scripting knowledge, though.
Guidelines for writing a Nagios plugin:
https://nagios-plugins.org/doc/guidelines.html
Post by dwhitfield »
mcapra wrote:I imagine a nagios-compatible wrapper could be written for it. It would require some scripting knowledge, though.
I did a quick Google search to see if there was something off of exchange. I didn't see anything. Thus, I think @mcapra is spot-on above.
padu_3891
Post by padu_3891 »
Hello All,
Zone state is really complicated wich holds many info and it has many combination of arguments . Will check with solaris support one more time .
Post by mcapra »
If there's any sort of basic API or SNMP based requests you could make against Zonestat, the problem is most likely solvable.
@padu_3891, let us know if you have anymore questions.
