I installed NDOUtils few time ago, but I'm finding an issue with the service. When I see the status of the service I get this messages.
● ndo2db.service - Stores data from Nagios in a database
Loaded: loaded (/usr/lib/systemd/system/ndo2db.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2017-08-11 15:30:16 UTC; 3 days ago
Docs: http://www.nagios.org/documentation
Process: 470 ExecStart=/usr/sbin/ndo2db -c /etc/nagios/ndo2db.cfg (code=exited, status=0/SUCCESS)
Main PID: 487 (ndo2db)
CGroup: /system.slice/ndo2db.service
├─ 487 /usr/sbin/ndo2db -c /etc/nagios/ndo2db.cfg
├─4659 /usr/sbin/ndo2db -c /etc/nagios/ndo2db.cfg
└─4660 /usr/sbin/ndo2db -c /etc/nagios/ndo2db.cfg
Aug 14 18:46:36 ip-10-0-8-150.ec2.eys.internal ndo2db[4659]: Warning: queue send error, retrying...
Aug 14 18:46:37 ip-10-0-8-150.ec2.eys.internal ndo2db[4659]: Message sent to queue.
Aug 14 18:55:44 ip-10-0-8-150.ec2.eys.internal ndo2db[4659]: Warning: Retrying message send. This can occur because you have too few messages allowed or too ...options.
Aug 14 18:55:45 ip-10-0-8-150.ec2.eys.internal ndo2db[4659]: Message sent to queue.
Aug 14 18:56:36 ip-10-0-8-150.ec2.eys.internal ndo2db[4659]: Warning: queue send error, retrying...
Aug 14 18:56:37 ip-10-0-8-150.ec2.eys.internal ndo2db[4659]: Message sent to queue.
Aug 14 19:05:44 ip-10-0-8-150.ec2.eys.internal ndo2db[4659]: Warning: queue send error, retrying...
Aug 14 19:05:45 ip-10-0-8-150.ec2.eys.internal ndo2db[4659]: Message sent to queue.
Aug 14 19:06:36 ip-10-0-8-150.ec2.eys.internal ndo2db[4659]: Warning: Retrying message send. This can occur because you have too few messages allowed or too ...options.
Aug 14 19:06:37 ip-10-0-8-150.ec2.eys.internal ndo2db[4659]: Message sent to queue.
Hint: Some lines were ellipsized, use -l to show in full.
/var/log/messages:Aug 14 11:16:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 11:16:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 11:25:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 11:25:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 11:26:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 11:26:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 11:35:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 11:35:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 11:36:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 11:36:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 11:45:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 11:45:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 11:46:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 11:46:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 11:55:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 11:55:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 11:56:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 11:56:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:05:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 12:05:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:06:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 12:06:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:15:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 12:15:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:16:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 12:16:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:25:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 12:25:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:26:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 12:26:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:35:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 12:35:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:36:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 12:36:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:45:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 12:45:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:46:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 12:46:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:55:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 12:55:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 12:56:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 12:56:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:05:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 13:05:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:06:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 13:06:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:15:45 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 13:15:46 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:16:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 13:16:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:25:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 13:25:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:26:37 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 13:26:38 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:35:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 13:35:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:36:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 13:36:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:45:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 13:45:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:46:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 13:46:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:55:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 13:55:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 13:56:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 13:56:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:05:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 14:05:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:06:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 14:06:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:15:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 14:15:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:16:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 14:16:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:25:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 14:25:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:26:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 14:26:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:35:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 14:35:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:36:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 14:36:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:45:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 14:45:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:46:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 14:46:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:55:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 14:55:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 14:56:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 14:56:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:05:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 15:05:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:06:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 15:06:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:15:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 15:15:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:16:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 15:16:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:25:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 15:25:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:26:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 15:26:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:35:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 15:35:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:36:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 15:36:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:45:45 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 15:45:46 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:46:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 15:46:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:55:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 15:55:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 15:56:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 15:56:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:05:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 16:05:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:06:37 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 16:06:38 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:15:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 16:15:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:16:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 16:16:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:25:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 16:25:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:26:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 16:26:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:35:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 16:35:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:36:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 16:36:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:45:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 16:45:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:46:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 16:46:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:55:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 16:55:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 16:56:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 16:56:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:05:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 17:05:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:06:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 17:06:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:15:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 17:15:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:16:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 17:16:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:25:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 17:25:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:26:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 17:26:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:35:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 17:35:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:36:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 17:36:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:45:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 17:45:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:46:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 17:46:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:55:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 17:55:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 17:56:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 17:56:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:05:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 18:05:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:06:36 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 18:06:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:15:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 18:15:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:16:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 18:16:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:25:45 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 18:25:46 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:26:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 18:26:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:35:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 18:35:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:36:37 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 18:36:38 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:45:44 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 18:45:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:46:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 18:46:37 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:55:44 ip-10-0-8-150 ndo2db: Warning: Retrying message send. This can occur because you have too few messages allowed or too few total bytes allowed in message queues. You are currently using 16 of 1979 messages and 16384 of 16384 bytes in the queue. See README for kernel tuning options.
/var/log/messages:Aug 14 18:55:45 ip-10-0-8-150 ndo2db: Message sent to queue.
/var/log/messages:Aug 14 18:56:36 ip-10-0-8-150 ndo2db: Warning: queue send error, retrying...
/var/log/messages:Aug 14 18:56:37 ip-10-0-8-150 ndo2db: Message sent to queue.
