Hi ,
I have a small requirement could you please help me in fulfilling this reuqirement
My Nagios IP is 172.xx.xx.xx and I have to configure a IP Port(10.xx.xx.xx & UDP) which my client will be connecting to push traffic and this ip port are configured in another server which is of 172.xx.xx.xx series.
Kindly help me in sorting out this
Nagios Core Requirement
Re: Nagios Core Requirement
With a standard install, once you add the IP's you should be able to just restart apache after adding the second IP and nagios should respond on both IP addresses.
Now, you will likely need to setup some type of mapping from your firewall for for the client that maps to the 10.xx.xx.xx address, but that you would need to work out with your firewall/router vendor.
