how to i resolve the below error
Error: Service Status Not Found!
i am using Nagios core 4 and OS is ubuntu
Regards,
Harsha
Nagios Error :- Error: Service Status Not Found!
Regards,
Harsha
Harsha
Re: Nagios Error :- Error: Service Status Not Found!
We need more information to help you ^^
French Baguette
i have added few new services in exesting host and after refrishing i will get the service some times it shows like service status not found
Regards,
Harsha
Harsha
I need to see your architecture (how you call your service and your command.cfg)
French Baguette
yes,
i will call from command.cfg file, same command will work for the hosts which i have configured initial stage. recently which i have configured is not working
Regards,
Harsha
Harsha
You use nscp or nrpe ?
Is the nsclient ++ is rigth configurate ?
French Baguette
i am using nrpe. and all are linux servers
Regards,
Harsha
Harsha
@harsha.s.aryan can you post the commands and service definitions for the service you are referring to?
