Linux machine nrpe version mismatch
amitgupta19
Post by amitgupta19 »
I have installed the nrpe plugin to monitor the linux machines on the nagios server.
Version of the nrpe plugin is 2.14 .
If i install the latest nrpe plugin 3.2.1 on the remote linux host, will it work or not?
do i need to install the same version of the nrpe plugin on the remote linux host?
Re: Linux machine nrpe version mismatch
amitgupta19 wrote:If i install the latest nrpe plugin 3.2.1 on the remote linux host, will it work or not?
Yes
amitgupta19 wrote: do i need to install the same version of the nrpe plugin on the remote linux host?
No, the new version is backwards compatible. You only need to install the new version on both systems if you are going to use a feature that didn't exist in the old version ( like using custom certificates)
ahumandesign.com
enneagrams.com
amitgupta19
Thanks for the clarification scottwilkerson.
kyang
Post by kyang »
Thanks! @scottwilkerson
Did you have any more questions or we are okay to close this thread?
amitgupta19
@kyang Yes it can be closed.
kyang
Post by kyang »
Closing this topic as resolved.
Thanks for using the Nagios Support Forum!
