Hi ,
I am planning a migration/upgrade of nagios core 3.4.3 to 4.3.4 and i have some questions regarding this. Seeking
your kind advice. My questions are as below ;
1. will the configs work without any modification from v3.4.3 to v4.3.4 ?
2. is there any other better ways / recommendation migration method - seamless migration ?
3. the nrpe in current client servers are at v2.12 and does it need to be upgraded to v3.2.1 ?
Migration of Version 3.4.3 to Version 4.3.4 (Nagios Core)
Re: Migration of Version 3.4.3 to Version 4.3.4 (Nagios Core
It depends. Your v3 configs might have directives that were deprecated in v4. Here's a list here that might help:trinetra wrote: 1. will the configs work without any modification from v3.4.3 to v4.3.4 ?
https://assets.nagios.com/downloads/nag ... tsnew.html
This page has some good documentation regarding common issues:trinetra wrote:2. is there any other better ways / recommendation migration method - seamless migration ?
https://assets.nagios.com/downloads/nag ... ading.html
But upgrading is usually a very hands-on process and will have considerations specific to how your Nagios Core 3 was setup.
Nope, they should still work with the v2 version of check_nrpe. I'd suggest getting your Nagios Core machine to 4.3.4 before you worry about NRPE things.trinetra wrote:3. the nrpe in current client servers are at v2.12 and does it need to be upgraded to v3.2.1 ?
hi all ,
thanks alot. sorry i somehow didn't get the email reply for this thread. i had to manually search this again.
but my problem already fixed a week ago. managed to migrate 3.4.3 to 4.3.4 by manually copying the main scripts only.
it works like charm! thanks alot
Sounds great! Thanks for checking in! I'll be closing this topic as resolved.
If you have any more questions, feel free to create another thread!
Thank you for using the Nagios Support Forum!
