check_tcp question
lindigo
check_tcp question
Post by lindigo »
i have to monitor some ports at a remote site.
Normally you can do this with check_tcp. Only incoming port 5666 is allowed at the remote site.
So I try to do this with nrpe:
I define a service at nagios-server
        use                             service-prod
        host_name                       web01
        service_description             Port 2222
        check_command                   check_nrpe!check_tcp_2222
I put the following line to nrpe.conf on client-side
command[check_tcp_2222]=/usr/local/nagios/libexec/check_tcp -H 127.0.0.1 -p 2222
The check is working. But I see there's still traffic between nagios-server and client for port 2222.
Is there an explenation for ?
(At this moment I'm testing without a firewall.)
Re: check_tcp question
Post by dwhitfield »
If there's no firewall, then why wouldn't you expect port 2222 to be open? check_tcp doesn't test if there's traffic going from the two servers, just that there could be. Are you using some other method to see traffic, like a tcpdump? I'm not familiar with anything on that port.
lindigo
Post by lindigo »
I am testing this at our infrastructure. Between the server and the client there is no firewall.
The client is running a service on port 2222. I am trying to check this by only using nrpe (port 5666). At the customers site I can only connect to 5666. They don't want to open other ports for the nagios connection.
I am using tcpdump.
lindigo
Post by lindigo »
Very strange, when I run this command manually:
[root@zabbix objects]# ../../libexec/check_nrpe -H 192.168.0.10 -c check_tcp_2222
TCP OK - 0.001 second response time on 127.0.0.1 port 2222|time=0.000717s;;;0.000000;10.000000
I see the following output from tcpdump (client):
[root@web01 etc]# tcpdump -i lo -nn port 2222
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on lo, link-type EN10MB (Ethernet), capture size 65535 bytes
16:05:25.792934 IP 127.0.0.1.35210 > 127.0.0.1.2222: Flags , seq 77083913, win 43690, options [mss 65495,sackOK,TS val 3615450035 ecr 0,nop,wscale 7], length 0
06:48:06.620043 IP 127.0.0.1.2222 > 127.0.0.1.35210: Flags [S.], seq 703240960, ack 77083914, win 43690, options [mss 65495,sackOK,TS val 3615450035 ecr 3615450035,nop,wscale 7], length 0
So it works by hand.
Running from nagios config :
16:03:10.555702 IP 192.168.0.1.50358 > 192.168.0.10.2222: Flags , seq 75373147, win 29200, options [mss 1460,sackOK,TS val 1219216694 ecr 0,nop,wscale 7], length 0
16:03:10.555792 IP 192.168.0.10.2222 > 192.168.0.1.50358: Flags [S.], seq 2993261616, ack 75373148, win 28960, options [mss 1460,sackOK,TS val 3615314798 ecr 1219216694,nop,wscale 7], length 0
It sounds like there could be another check that is defined on the Nagios server that could be checking for port 2222.
Make sure there is not another service check defined.
cdienger
Post by cdienger »
Please provide the definition for the check_nrpe command. The default location is /usr/local/nagios/etc/objects/commands.cfg
