[b]Black Toner Cartridge OKI DATA CORP is at 30% - OK! Cyan Toner Cartridge OKI DATA CORP is at 10% - WARNING! Magenta Toner Cartridge OKI DATA CORP is at 100% - OK! Yellow Toner Cartridge OKI DATA CORP is at 10% - WARNING! Black Image Drum Unit OKI DATA CORP is at 73% - OK! Cyan Image Drum Unit OKI DATA CORP is at 73% - OK! Magenta Image Drum Unit OKI DATA CORP is at 73% - OK! Yellow Image Drum Unit OKI DATA CORP is at 73% - OK! Belt Unit OKI DATA CORP is at 86% - OK! Fuser Unit OKI DATA CORP is at 91% - OK! [/b]
What do I have to do to make the notifications come individually for each toner?
Unfortunately, but it still does not work as if I wanted it to.
I used one quote, without changes.
The thread you have provided refers to another issue
#!/bin/bash
# SNMP Printer Check #
# check_snmp_printer #
# Version 3.141592 (December 12, 2011) #
# Authored by Jason Leonard #
# E-mail: jason_leonard@yahoo.com #
# Overview #
# This plugin is a rewrite of the SNMP printer #
# check provided by Monitoring Solutions. In operating #
# the plugin at our environment, I noticed the output #
# was combined as one long paragraph when using the #
# CONSUM ALL option (definitely a favorite of mine). #
# While this is in accordance with Nagios plugin dev. #
# guidelines, for devices with numerous consumables #
# (like copiers), this makes it difficult to quickly #
# find the empty consumable when an alert came in. So I #
# set out to spruce up the output of the plugin - using #
# one consumable per line. #
# In the process, I also realized the original #
# plugin was more if/then statements than I had seen #
# since my programming class in college. So I made the #
# code a bit cleaner for faster execution. I also had #
# add SNMP pre-flight checks, as the original would #
# return OK status to Nagios even if SNMP was broken. #
# Lastly, I decided to rewrite the options and #
# add other pre-flight checks that are present in my #
# other plugins. I like to be thorough in making sure #
# the program won't return output if the input is just #
# garbage! #
# NOTE: #
# Because CONSUM ALL uses a multi-line output, #
# you will need to use the $LONGSERVICEOUTPUT$ macro #
# in your service notification commands! #
# This plugin is distributed under the GNU GPL license. #
# You may re-destribute only according to the terms of #
# the GNU GPL v2. #
## GLOBAL VARIABLES ##
APPNAME=$(basename $0)
VERSION="3.14159"
COMMUNITY="public"
EXIT_CODE=0
EXIT_STRING=""
STRING_TYPE=""
PERFDAT=""
CHECK=""
PARAMETER=""
# Set a warning at 20% of consumable, if not passed
WARNING=20
# Set a critical at 5% of consumable, if not passed. The standard of 10
# seems to be high for most consumables, which move very slowly.
CRITICAL=5
# Change this to modify the script's handling of how it separates
# each consumable/tray when multiple checks are output.
# SEPARATOR="\n"
SEPARATOR=" "
# This is the character that tokenizes multiple arguments
# to the TRAY and CONSUM checks. I have this here
# so it's easy to change if I find the current character
# I have is buggy or a bad choice
ARG_TOKEN=","
## print_help Function ##
# Prints out user help and gives examples of proper #
# plugin usage #
function print_help {
echo 'SNMP Printer Check for Nagios'
echo ''
echo 'This plugin is not developped by the Nagios Plugin group.'
echo 'Please do not e-mail them for support on this plugin.'
echo ''
echo 'For contact info, please read the plugin script file.'
echo ''
echo "Usage of $APPNAME"
echo " $APPNAME -H <host/IP> -C <community> -x <check> [-w] [-c] [-S] | -h | -V "
echo '---------------------------------------------------------------------'
echo 'Usable Options:'
echo ''
echo ' -C <community>'
echo ' The SNMP Community variable - use the name of your SNMP community with read privileges'
echo ' By default, the community is assumed to be public'
echo ' -H <hostname>'
echo ' (required option)'
echo ' The IP address or hostname of the system to check'
echo ' -S <text string>'
echo ' assign a particular string as the separator for consumables.'
echo ' Default is " " to conform to Nagios plugin development guidelines'
echo ' -w <warn>'
echo ' warning threshold (% of consumable remaining)'
echo ' -c <crit>'
echo ' critical threshold (% of consumable remaining)'
echo ' -h'
echo ' show this help screen'
echo ' -V'
echo ' show the current version of the plugin'
echo ' -x <check>'
echo ' The check you want to perform for the printer. Choose from the following:'
echo ''
echo ' CONSUM {<string> | TEST | ALL}'
echo ' <string> will give you all consumables matching the string '
echo " For example, 'CONSUM Toner' will only show toner levels"
echo ' TEST will give you the exact names of available consumables'
echo ' For example,'
echo ' Black Toner Cartridge HP C4191A'
echo ' To monitor a consumable, call the function as follows:'
echo " $APPNAME -H <hostname> -C <community> -x \"CONSUM Black\" "
echo ' ALL gives you all consumable output at once.'
echo ''
echo ' CONSUMX <string>'
echo ' this gives you results only for the ***EXACT*** consumable specified by <string>'
echo ' For example, '
echo ' CONSUMX "Black Toner Cartridge" '
echo ' will only give you the usage for a consumable named "Black Toner Cartridge". '
echo ' It will not give you results for "Black Toner Cartridge 1" or "Black Toner". '
echo ' DISPLAY'
echo ' Report contents of printer display'
echo ''
echo ' DEVICES'
echo ' Status of hardware modules'
echo ''
echo ' MESSAGES'
echo ' Event logs reported by the printer'
echo ''
echo ' MODEL'
echo ' ALL will give you all tray output at once.'
echo ''
echo ' PAGECOUNT'
echo ' How many pages this printer has processed (culmulative)'
echo ''
echo ' STATUS'
echo ' Overall status of the printer'
echo ''
echo ' TRAY {<number> | TEST | ALL}'
echo ' <number> will give you output for the specified tray. A comma-separated list of values is possible as well.'
echo " TEST will give you the #'s of all trays available "
echo ''
echo 'Examples:'
echo " $APPNAME -H 10.0.1.10 -C public -x \"CONSUM ALL\" -w 25 -c 10 "
echo " $APPNAME -H 10.0.1.10 -C public -x \"CONSUMX Punch Dust Box\" "
echo " $APPNAME -H 10.0.1.10 -C public -x MODEL "
echo " $APPNAME -H 10.0.1.10 -C public -x \"TRAY 2,3\" "
echo " $APPNAME -V"
echo ''
return 3
## check_model function ##
# Returns printer model and serial. Always returns OK #
function check_model(){
# Vendor specific items to code here!
# possibly serial #
MODEL=$(snmpget -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.25.3.2.1.3.1 2>/dev/null)
SERIAL=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.5.1.1.17 2>/dev/null | tr -d "\"")
EXIT_STRING="$MODEL, Serial # $SERIAL"
return 0
## check_messages function ##
# Shows messages on the printer display. The OID is not #
# commonly used in all printers #
function check_messages(){
MESSAGES=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.18.1.1.8 2>/dev/null | tr -d "\"" | tr "\n" "\!")
if [ -z "$MESSAGES" ]; then
EXIT_STRING="UNKNOWN: Can't determine messages. Device does not support this OID.\n"
EXIT_CODE=3
else
EXIT_STRING="$MESSAGES"
fi
return $EXIT_CODE
## check_page_count function ##
# Returns pretty-formatted page count for the printer. #
# Awesome for tracking historical page usage. #
function check_page_count(){
PAGE_COUNT=$(snmpget -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.10.2.1.4.1.1 2>/dev/null | sed -e :x -e 's/\([0-9][0-9]*\)\([0-9][0-9][0-9]\)/\1,\2/' -e 'tx')
EXIT_STRING="Pagecount is $PAGE_COUNT"
PERFDAT="Pages=$PAGE_COUNT;"
return 0
## check_display function ##
function check_display(){
DISPLAY=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.16.5.1.2.1 2>/dev/null | tr -d "\"" )
# if display is null, we need to let the user know
if [ $? -eq 0 ]; then
# Let's make sure we eliminate any extra new lines, or at least replace them with our
# specified SEPARATOR (which could be a new line)
EXIT_STRING=$(echo "$DISPLAY" | tr "\n" "$SEPARATOR")
return 0
else
# Something happened or this OID isn't available
EXIT_STRING="UNKNOWN - printer does not appear to support using this OID."
return 3
fi
## check_printer_status function ##
function check_printer_status(){
STATUS_EXIT_CODE=0
PRINTER_STATUS=$(snmpget -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.25.3.5.1.1.1 2>/dev/null)
case "$PRINTER_STATUS" in
"other(1)")
EXIT_STRING="CRITICAL: Printer status is $PRINTER_STATUS"
STATUS_EXIT_CODE=2
"idle(3)")
EXIT_STRING="OK: Printer status is $PRINTER_STATUS"
"printing(4)")
"warmup(5)")
EXIT_STRING="WARNING: Printer status is $PRINTER_STATUS"
STATUS_EXIT_CODE=1
esac
return $STATUS_EXIT_CODE
## check_device_status function ##
function check_device_status(){
CURRENT_EXIT_CODE=0
CURRENT_STATUS=0
DEVICE_STATUS=""
DEVICE_NAME=""
DEVICE_IDS=$(snmpwalk -v1 -On -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.25.3.2.1.1 2>/dev/null)
# create this around a for loop on id's, which come from .1.3.6.1.2.1.25.3.2.1.1.x
for ID in $(echo $DEVICE_IDS | egrep -oe '[[:digit:]]+\ =' | cut -d " " -f1)
do
DEVICE_NAME=$(snmpget -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.25.3.2.1.3.$ID 2>/dev/null)
EXIT_STRING="$EXIT_STRING$DEVICE_NAME status is "
DEVICE_STATUS=$(snmpget -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.25.3.2.1.5.$ID 2>/dev/null)
case "$DEVICE_STATUS" in
"unknown(1)")
EXIT_STRING="$EXIT_STRING$DEVICE_STATUS - WARNING!$SEPARATOR"
CURRENT_STATUS=1
"running(2)")
EXIT_STRING="$EXIT_STRING$DEVICE_STATUS - OK!$SEPARATOR"
"warning(3)")
CURRENT_STATUS=1
"testing(4)")
"down(5)")
EXIT_STRING="$EXIT_STRING$DEVICE_STATUS - CRITICAL!$SEPARATOR"
CURRENT_STATUS=2
CURRENT_STATUS=1
esac
if [ "$CURRENT_STATUS" -gt "$CURRENT_EXIT_CODE" ]; then
CURRENT_EXIT_CODE="$CURRENT_STATUS"
fi
done
return $CURRENT_EXIT_CODE
## check_one_consumable function ##
# Given the marker's ID (1, 2, 3, etc.), this function #
# grabs the consmable string for that ID, converts it #
# to a name and determines capacity and status code for #
# it. #
# Only status code is returned. Global string variables #
# are used for printing and other functionality. #
function check_one_consumable () {
local CONSUM_EXIT_CODE=0
CURRENT_CAPACITY=0
MAX_CAPACITY=0
MARKER_NAME=""
MARKER_COLOR=""
MARKER_STRING=$(snmpget -v1 -On -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.11.1.1.6.1.$1 2>/dev/null)
# We'll be parsing our name differently depending on whether we have Hex-String or not
if [ "$STRING_TYPE" == "Hex-STRING:" ]; then
MARKER_NAME=$(echo "$MARKER_STRING" | cut -d ":" -f2- | tr -d "\n" | xxd -r -p)
else
MARKER_NAME=$(echo "$MARKER_STRING" | cut -d " " -f4- | tr -d "\"")
fi
# Some manufacturers don't put the actual cartridge color in the above OID text for
# MARKER_STRING. Instead, each entry just says "toner". The OID used here is
# a place where an associated color string must be stored. We are going to get this
# info. and use it if not already available in the MARKER_NAME we've parsed.
# --- Thanks to Martin Šoltis for letting me know about this problem on some copiers.
GETCOLOR=$(snmpget -v1 -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.12.1.1.4.1.$1 2>/dev/null)
MARKER_COLOR=$(echo $GETCOLOR | cut -d " " -f4- | tr -d "\"")
# We're just checking here to see if the consumable already has this color in its text description
if [ $(echo "$MARKER_NAME" | grep -vqi "$MARKER_COLOR") ]; then
# It doesn't, so we're going to add it
MARKER_NAME="$MARKER_COLOR $MARKER_NAME"
fi
# As usual, if the results are an empty set, something went wrong or didn't match up
if [ -z "$MARKER_NAME" ]; then
EXIT_STRING="UNKNOWN - OID not found! Your printer may not support checking this consumable."
EXIT_STRING="$EXIT_STRING Use the CONSUM TEST option to determine which consumables may be monitored."
PERFDAT=""
CONSUM_EXIT_CODE=3
else
# Determine capacities for the current marker
CURRENT_CAPACITY=$(snmpget -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.11.1.1.9.1.$1 2>/dev/null)
MAX_CAPACITY=$(snmpget -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.11.1.1.8.1.$1 2>/dev/null)
if [ "$MAX_CAPACITY" -lt 0 ]; then
MAX_CAPACITY=0
fi
# the component does not have a measurable status indication
case "$CURRENT_CAPACITY" in
"-3") # A value of (-3) means that the printer knows that there is some supply/remaining space
EXIT_STRING="$EXIT_STRING$MARKER_NAME is OK!$SEPARATOR"
"-2") # The value (-2) means unknown
EXIT_STRING="$EXIT_STRING$MARKER_NAME is at WARNING level!$SEPARATOR"
if [ "$CONSUM_EXIT_CODE" -lt 1 ]; then
CONSUM_EXIT_CODE=1
fi
"0") # Something is empty!
EXIT_STRING="$EXIT_STRING$MARKER_NAME is at CRITICAL level!$SEPARATOR"
CONSUM_EXIT_CODE=2
*) # A positive value means this is a measurable component - let's report it's status code and let user know the % usage
let "CURRENT_CAPACITY=$CURRENT_CAPACITY * 100 / $MAX_CAPACITY"
if [ "$CURRENT_CAPACITY" -gt "$WARNING" ]; then
EXIT_STRING="$EXIT_STRING$MARKER_NAME is at $CURRENT_CAPACITY%% - OK!$SEPARATOR"
else
if [ "$CURRENT_CAPACITY" -le "$WARNING" ] && [ "$CURRENT_CAPACITY" -gt "$CRITICAL" ]; then
EXIT_STRING="$EXIT_STRING$MARKER_NAME is at $CURRENT_CAPACITY%% - WARNING!$SEPARATOR"
CONSUM_EXIT_CODE=1
fi
else
if [ "$CURRENT_CAPACITY" -le "$CRITICAL" ]; then
EXIT_STRING="$EXIT_STRING$MARKER_NAME is at $CURRENT_CAPACITY%% - CRITICAL!$SEPARATOR"
CONSUM_EXIT_CODE=2
fi
fi
fi
esac
PERFDAT="$PERFDAT $MARKER_NAME=$CURRENT_CAPACITY;$WARNING;$CRITICAL;"
fi
return $CONSUM_EXIT_CODE
## check_exact_consumable function ##
# Loops through all consumables and compares the string #
# passed to the consumable string. If a match is found, #
# we calculate and output capacity and status. If a #
# match is not found, let the user know. #
# Global string variables are used for printing status #
# and perf data. #
function check_exact_consumable(){
local CONSUMX_EXIT_CODE=0
FOUND=false
FOUND_MARKER=0
# Now we can loop through everything that matched
for MARKER_ID in $(echo "$ALL_MARKERS" | egrep -oe '[[:digit:]]+\ =' | cut -d " " -f1)
do
MARKER_STRING=$(snmpget -v1 -On -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.11.1.1.6.1.$MARKER_ID 2>/dev/null)
else
fi
# Update our boolean if we find a match!
if [ "$1" == "$MARKER_NAME" ]; then
FOUND=true
FOUND_MARKER="$MARKER_ID"
fi
done
if $FOUND; then
# Determine capacities for the marker of the matching consumable
X_CURRENT_CAPACITY=$(snmpget -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.11.1.1.9.1.$FOUND_MARKER 2>/dev/null)
MAX_CAPACITY=$(snmpget -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.11.1.1.8.1.$FOUND_MARKER 2>/dev/null)
MAX_CAPACITY=0
fi
case "$X_CURRENT_CAPACITY" in
EXIT_STRING="$EXIT_STRING$1 is OK!\n"
EXIT_STRING="$EXIT_STRING$1 is at WARNING level!$SEPARATOR"
if [ "$CONSUMX_EXIT_CODE" -lt 1 ]; then
CONSUMX_EXIT_CODE=1
fi
EXIT_STRING="$EXIT_STRING$1 is at CRITICAL level!$SEPARATOR"
CONSUMX_EXIT_CODE=2
let "X_CURRENT_CAPACITY=$X_CURRENT_CAPACITY * 100 / $MAX_CAPACITY"
if [ "$X_CURRENT_CAPACITY" -gt "$WARNING" ]; then
EXIT_STRING="$EXIT_STRING$1 is at $X_CURRENT_CAPACITY%% - OK!$SEPARATOR"
else
if [ "$X_CURRENT_CAPACITY" -le "$WARNING" ] && [ "$X_CURRENT_CAPACITY" -gt "$CRITICAL" ]; then
EXIT_STRING="$EXIT_STRING$1 is at $X_CURRENT_CAPACITY%% - WARNING!$SEPARATOR"
CONSUMX_EXIT_CODE=1
fi
else
if [ "$X_CURRENT_CAPACITY" -le "$CRITICAL" ]; then
EXIT_STRING="$EXIT_STRING$1 is at $X_CURRENT_CAPACITY%% - CRITICAL!$SEPARATOR"
CONSUMX_EXIT_CODE=2
fi
fi
fi
esac
PERFDAT="$PERFDAT $1=$X_CURRENT_CAPACITY;$WARNING;$CRITICAL;"
else
# Let the user know we didn't find anything, and report back the string they sent. Also prompt them to run the TEST option to double-check their string
EXIT_STRING="UNKNOWN - No match found for '$1'! Use the CONSUM TEST option to determine which consumables may be monitored.\n"
CONSUMX_EXIT_CODE=3
fi
return $CONSUMX_EXIT_CODE
## check_consumables function ##
# Determines which consumables to check and then pass #
# them all off to check_one_consumable #
# and perf data. #
function check_consumables(){
local CONSUMS_EXIT_CODE=0
HEX_ID=0
CURRENT_STATUS=0
HEX_MARKER=""
ASCII_MARKER=""
MARKERS_MATCHED=""
case "$1" in
"TEST") # User passed "TEST" parameter - output what consumables are available
printf "Consumables you may monitor:\n"
for HEX_ID in $(echo "$ALL_MARKERS" | egrep -oe '[[:digit:]]+\ =' | cut -d " " -f1)
do
HEX_MARKER=$(snmpget -v1 -On -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.11.1.1.6.1.$HEX_ID 2>/dev/null)
ASCII_MARKER=$(echo "$HEX_MARKER" | cut -d ":" -f2 | tr -d "\n" | xxd -r -p)
EXIT_STRING="$EXIT_STRING$ASCII_MARKER\n"
done
else
EXIT_STRING=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.11.1.1.6.1 2>/dev/null)
fi
CONSUMS_EXIT_CODE=3
"ALL") # User passed ALL parameter - check everything!
# Let's loop through all consumables available
do
check_one_consumable "$MARKER_ID"
CURRENT_STATUS=$?
if [ "$CURRENT_STATUS" -gt "$CONSUMS_EXIT_CODE" ]; then
CONSUMS_EXIT_CODE="$CURRENT_STATUS"
fi
done
*) # A string was passed, on which we will match to available consumable strings
# If our printer uses Hex-STRING fields, we need to convert our user's string to hex first
HEX_STRING=$(echo "$1" | tr -d "\n" | xxd -p -u)
# Now that we have a hex string for the user string, we need look for it in output that is formatted similarly
# XXD -p doesn't output spaces, but the Hex-STRING fields do use spaces between each byte
MARKERS_MATCHED=$(echo "$ALL_MARKERS" | tr -d " " | egrep -i "$HEX_STRING")
else
MARKERS_MATCHED=$(echo "$ALL_MARKERS" | egrep -i "$1")
fi
if [ -z "$MARKERS_MATCHED" ]; then
PERFDAT=""
EXIT_CODE=3
else
for MARKER_ID in $(echo "$MARKERS_MATCHED" | cut -d "=" -f1 | cut -d "." -f14)
do
CURRENT_STATUS=$?
fi
done
fi
esac
return $CONSUMS_EXIT_CODE
## check_one_tray Function ##
# Checks the tray #, as passed by parameter. If found, #
# it returns the status and capacity. #
function check_one_tray (){
TRAY_EXIT_CODE=0
TRAY_CAPACITY=0
TRAY_MAX_CAPACITY=0
TRAY_FEED_DIMENSION=0
TRAY_XFEED_DIMENSION=0
TRAY_DIMENSION_UNITS=0
TRAY_CAPACITY=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.8.2.1.10.1.$1 2>/dev/null)
if [ -z "$TRAY_CAPACITY" ]; then
EXIT_STRING="$EXIT_STRING UNKNOWN - Tray $1 not found. Use the TRAY TEST option to determine which trays may be monitored.\n"
TRAY_EXIT_CODE=3
else
# Determine information about the tray
TRAY_NAME=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.8.2.1.13.1.$1 2>/dev/null)
# Some manufacturers do not set the tray name OID, so we'll assume a generic name depending on the # passed to the function
if [ "$TRAY_NAME"=="" ]; then
TRAY_NAME="Tray $1"
fi
case "$TRAY_CAPACITY" in
"-3") # The value (-3) means that the printer knows that at least one unit remains.
EXIT_STRING="$EXIT_STRING$TRAY_NAME is OK!$SEPARATOR"
EXIT_STRING="$EXIT_STRING$TRAY_NAME status is UNKNOWN!$SEPARATOR"
TRAY_EXIT_CODE=3
"0") # 0 means there is no paper left! This is our only critical value.
# Determine paper size of current tray
TRAY_FEED_DIMENSION=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.8.2.1.4.1.$1 2>/dev/null)
TRAY_XFEED_DIMENSION=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.8.2.1.5.1.$1 2>/dev/null)
TRAY_DIMENSION_UNITS=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.8.2.1.3.1.$1 2>/dev/null)
if [ "$TRAY_FEED_DIMENSION" -lt 0 ] && [ "$TRAY_XFEED_DIMENSION" -lt 0 ]; then
# If either dimension was negative, then we really don't know much about the dimension
TRAY_DIMENSION_STRING="paper."
else
case "$TRAY_DIMENSION_UNITS" in
"3") # convert ten thousandths of an inch to inches
TRAY_FEED_DIMENSION=$(echo "scale=1;$TRAY_FEED_DIMENSION/10000" | bc)
TRAY_XFEED_DIMENSION=$(echo "scale=1;$TRAY_XFEED_DIMENSION/10000" | bc)
"4") # convert micrometers to inches, and get the int portion
TRAY_FEED_DIMENSION=$(echo "scale=1;$TRAY_FEED_DIMENSION*0.0000393700787" | bc)
TRAY_FEED_DIMENSION=$(echo "scale=1;$TRAY_FEED_DIMENSION+0.5" | bc)
TRAY_FEED_DIMENSION=$(echo "scale=1;$TRAY_FEED_DIMENSION/1" | bc)
TRAY_XFEED_DIMENSION=$(echo "scale=1;$TRAY_XFEED_DIMENSION*0.0000393700787" | bc)
TRAY_XFEED_DIMENSION=$(echo "scale=1;$TRAY_XFEED_DIMENSION+0.5" | bc)
TRAY_XFEED_DIMENSION=$(echo "scale=1;$TRAY_XFEED_DIMENSION/1" | bc)
esac
TRAY_DIMENSION_STRING="$TRAY_XFEED_DIMENSION x $TRAY_FEED_DIMENSION paper."
fi
EXIT_STRING="$EXIT_STRING$TRAY_NAME is at CRITICAL level - please refill with more $TRAY_DIMENSION_STRING$SEPARATOR"
TRAY_EXIT_CODE=2
*) # A positive number indicates how many pages are left. We'll calculate what % of capacity this is and determine status
TRAY_MAX_CAPACITY=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.8.2.1.9.1.$1 2>/dev/null )
let "TRAY_CAPACITY = $TRAY_CAPACITY * 100 / $TRAY_MAX_CAPACITY"
if [ "$TRAY_CAPACITY" -gt "$CRITICAL" ]; then
EXIT_STRING="$EXIT_STRING$TRAY_NAME is at $TRAY_CAPACITY%% - OK!$SEPARATOR"
else
if [ "$TRAY_CAPACITY" -le "$WARNING" ]; then
TRAY_FEED_DIMENSION=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.8.2.1.4.1.$1 2>/dev/null )
TRAY_XFEED_DIMENSION=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.8.2.1.5.1.$1 2>/dev/null )
TRAY_DIMENSION_UNITS=$(snmpwalk -v1 -Ovq -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.8.2.1.3.1.$1 2>/dev/null )
else
esac
fi
if [ "$TRAY_CAPACITY" -le "$CRITICAL" ]; then
# we have a critical: we already know the value is less than warning
EXIT_STRING="$EXIT_STRING$TRAY_NAME is at $TRAY_CAPACITY%% - CRITICAL! Please refill with more $TRAY_DIMENSION_STRING$SEPARATOR"
TRAY_EXIT_CODE=2
else
# we are only below warning, but not yet below critical
EXIT_STRING="$EXIT_STRING$TRAY_NAME is at $TRAY_CAPACITY%% - WARNING! Please refill with more $TRAY_DIMENSION_STRING$SEPARATOR"
if [ "$TRAY_EXIT_CODE" -lt 1 ]; then
TRAY_EXIT_CODE=1
fi
fi
fi
fi
PERFDAT="$PERFDAT $TRAY_NAME=$TRAY_CAPACITY;$WARNING;$CRITICAL;"
esac
fi
return $TRAY_EXIT_CODE
## check_paper_trays Function ##
# Determines which trays to check and passes each check #
# off to check_one_tray. #
# and perf data. #
function check_paper_trays (){
TRAYS_EXIT_CODE=0
ALL_TRAYS=$(snmpwalk -v1 -On -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.8.2.1.10.1 2>/dev/null)
CURRENT_TRAY_STATUS=0
case "$1" in
"TEST")
echo "Trays you may monitor:"
echo "$(echo "$ALL_TRAYS" | egrep -oe '[[:digit:]]+\ =' | cut -d " " -f1)"
TRAYS_EXIT_CODE=3
"ALL") # let's check all trays!
for TRAY_ID in $(echo "$ALL_TRAYS" | egrep -oe '[[:digit:]]+\ =' | cut -d " " -f1)
do
check_one_tray "$TRAY_ID"
CURRENT_TRAY_STATUS=$?
if [ "$CURRENT_TRAY_STATUS" -gt "$TRAYS_EXIT_CODE" ]; then
TRAYS_EXIT_CODE="$CURRENT_TRAY_STATUS"
fi
done
for TRAY_ID in $(echo "$1" | tr "$ARG_TOKEN" "\n")
do
fi
done
esac
return $TRAYS_EXIT_CODE
## MAIN CODE ##
# Check that all required binaries for the script are available
# EXIT with an UNKNOWN status if not
binaries="snmpwalk snmpget bc egrep xxd"
for required_binary in $binaries;
do
which $required_binary > /dev/null
if [ "$?" != '0' ];then
printf "UNKNOWN: $APPNAME: No usable '$required_binary' binary in '$PATH'\n"
exit 3
fi
done
# Parse our options as passed, and make sure things are peachy
while getopts "C:H:c:w:x:S:hV" OPTION;
do
case $OPTION in
"C") # Assign community
COMMUNITY="$OPTARG"
"H") # Assign hostname
HOST_NAME="$OPTARG"
"c") # Assign CRITICAL threshold
CRITICAL="$OPTARG"
"w") # Assign WARNING threshold
WARNING="$OPTARG"
"x") # Assign check to perform
CHECK=$(echo "$OPTARG" | cut -d " " -f1)
PARAMETER=$(echo "$OPTARG" | cut -d " " -f2-)
"S") # Assign separator
SEPARATOR="$OPTARG"
"h") # Print application help
print_help
exit $?
"V") # Print application version
printf "$APPNAME - version $VERSION\n"
exit $EXIT_CODE
esac
done
# Make sure all necessary arguments were given; EXIT with an UNKNOWN status if not
if [ -z "$COMMUNITY" ] || [ -z "$HOST_NAME" ];then
# we need these parameters to continue
EXIT_STRING="UNKNOWN: Hostname and/or Community variables have not been set!\n"
EXIT_CODE=3
else
ALL_MARKERS=$(snmpwalk -v1 -On -c $COMMUNITY $HOST_NAME 1.3.6.1.2.1.43.11.1.1.6.1 2>/dev/null)
if [ $? -ne 0 ]; then
#Check for server response - is SNMP even setup okay?
EXIT_STRING="WARNING: No SNMP response from $HOST_NAME! Make sure host is up and SNMP is configured properly.\n"
EXIT_CODE=1
else
STRING_TYPE=$(echo "$ALL_MARKERS" | tr -d "\n" | cut -d " " -f3)
case "$CHECK" in
"MESSAGES")
check_messages
"MODEL")
check_model
"CONSUM")
check_consumables "$PARAMETER"
"CONSUMX")
check_exact_consumable "$PARAMETER"
"TRAY")
check_paper_trays "$PARAMETER"
"PAGECOUNT")
check_page_count
"DEVICES")
check_device_status
"STATUS")
"DISPLAY")
check_display
*) # no parameters were passed, or a parameter was incorrect (wrong spelling, etc.)
echo 'Invalid check specified by -x parameter.'
echo ''
print_help
esac
EXIT_CODE=$?
fi
fi
# If the program hasn't exited already, then a check was run okay and we can quit.
if [ "$PERFDAT" == "" ]; then
printf "$EXIT_STRING\n"
else
printf "$EXIT_STRING|$PERFDAT\n"
fi
exit $EXIT_CODE
#!/bin/bash
# Version 4.0 (June 9th, 2016) #
# Overview #
# This plugin is a rewrite of the SNMP printer check #
# provided by Monitoring Solutions. In operating the #
# plugin at our environment, I noticed the output was #
# combined as one long paragraph when using the CONSUM #
# ALL option (definitely a favorite of mine). #
# In the process, I also realized the original plugin #
# was more if/then statements than I had seen since my #
# programming class in college. So I made the code a #
# bit cleaner for faster execution. I also had to add #
# SNMP pre-flight checks, as the original would return #
# OK status to Nagios even if SNMP was broken. #
# Lastly, I decided to rewrite the options and add #
# other pre-flight checks that are present in my other #
# plugins. I like to be thorough in making sure the #
# program won't return output if the input is just #
# garbage! #
# NOTE: #
# Because CONSUM ALL uses a multi-line output, you will #
# need to use the $LONGSERVICEOUTPUT$ macro in your #
# service notification commands! #
# the GNU GPL v2. #
AUTHOR="Jason Leonard"
VERSION="4.0"
# Default settings for connection
COMMUNITY='public'
HOST_NAME='localhost'
SNMPVERSION='2c'
# State Variables
STATE_OK=0
STATE_WARN=1
STATE_CRIT=2
STATE_UNK=3
# Default Outputs
STATE=$STATE_OK
STATE_STRING=""
PERFDATA=""
STRING_TYPE=""
CHECK=""
PARAMETER=""
WARNING=20
CRITICAL=5
# SEPARATOR="\n"
SEPARATOR=","
ARG_TOKEN=","
# Universal SNMP OIDS #
OID_hrDeviceDescr="1.3.6.1.2.1.25.3.2.1.3"
OID_hrDeviceIndex="1.3.6.1.2.1.25.3.2.1.1"
OID_hrDeviceStatus="1.3.6.1.2.1.25.3.2.1.5"
OID_hrPrinterStatus="1.3.6.1.2.1.25.3.5.1.1.1"
OID_prtAlertDescription="1.3.6.1.2.1.43.18.1.1.8"
OID_prtConsoleDisplayBufferText="1.3.6.1.2.1.43.16.5.1.2.1"
OID_prtGeneralSerialNumber="1.3.6.1.2.1.43.5.1.1.17"
OID_prtInputCurrentLevel="1.3.6.1.2.1.43.8.2.1.10.1"
OID_prtInputDimUnit="1.3.6.1.2.1.43.8.2.1.3.1"
OID_prtInputMaxCapacity="1.3.6.1.2.1.43.8.2.1.9.1"
OID_prtInputMediaDimFeedDirDeclared="1.3.6.1.2.1.43.8.2.1.4.1"
OID_prtInputMediaDimXFeedDirDeclared="1.3.6.1.2.1.43.8.2.1.5.1"
OID_prtInputName="1.3.6.1.2.1.43.8.2.1.13.1"
OID_prtMarkerColorantValue="1.3.6.1.2.1.43.12.1.1.4.1"
OID_prtMarkerLifeCount="1.3.6.1.2.1.43.10.2.1.4.1.1"
OID_prtMarkerSuppliesDescription="1.3.6.1.2.1.43.11.1.1.6.1"
OID_prtMarkerSuppliesLevel="1.3.6.1.2.1.43.11.1.1.9.1"
OID_prtMarkerSuppliesMaxCapacity="1.3.6.1.2.1.43.11.1.1.8.1"
# print_version #
print_version() {
echo "$APPNAME $VERSION"
echo "$AUTHOR"
echo ""
# print_usage #
print_usage(){
echo ''
echo "Usage for SNMP v1/2c:"
echo " $APPNAME -H <host/IP> -t <type of check> [-C <SNMP community>] [-S <character>] [-w <warning value>] [-c <critical value>]"
echo ""
echo "Usage for SNMP v3:"
echo " $APPNAME -H <host/IP> -t <type of check> -u <user> -x <protocol> -X <password> -a <protocol> -A <password> -l <security mode> [-S <character>] [-w <warning value>] [-c <critical value>]"
echo ''
# plugin usage #
print_version
echo 'Description:'
echo "$APPNAME is a Nagios plugin to check the status of various components of networked printers."
echo ''
echo ''
print_usage
echo ''
echo 'OPTIONS:'
echo ' -H|--host'
echo ' Host name or IP address to check. Default is: localhost. REQUIRED OPTION'
echo ' -v|--snmpversion { 1 | 2c | 3 }'
echo " Specifies the SNMP version to use. Default is '2c'. REQUIRED OPTION"
echo ' -C|--community'
echo " SNMP v2 community string with Read access. Default is 'public'. REQUIRED OPTION"
echo ' -u|--user'
echo ' SNMP v3 username'
echo ' -l|--privlevel { noAuthNoPriv | authNoPriv | authPriv }'
echo ' SNMP v3 privilege level'
echo ' -x|--privprotocol { DES | AES }'
echo ' SNMP v3 privacy protocol'
echo ' -X|--privpassword'
echo ' SNMP v3 privacy password'
echo ' -a|--authprotocol { MD5 | SHA }'
echo ' SNMP v3 authentication protocol'
echo ' -A|--authpassword'
echo ' SNMP v3 authentication password'
echo ' -t|--type { consum | consumx | display | devices | messages | model | pagecount | status | tray }'
echo ' The check you want to perform for the printer.'
echo ' REQUIRED OPTION'
echo ' -w|--warning'
echo ' Assign WARNING value, in %, for capacity checks'
echo ' -c|--critical'
echo ' Assign CRITICAL value, in %, for capacity checks'
echo ' -S|--separator <text string>'
echo ' Assign a particular string as the separator for consumables.'
echo ' Default is , to conform to Nagios plugin development guidelines'
echo ' -h|--help'
echo ' Show this help screen'
echo ' -V|--version'
echo ' Show the current version of the plugin'
echo ''
echo 'CHECK TYPES:'
echo ''
echo ' CONSUM { <string> | TEST | ALL }'
echo ' <string> will give you all consumables matching the string'
echo ' ALL will give you all consumable output at once.'
echo ''
echo ' This gives you results only for the ***EXACT*** consumable specified by <string>'
echo " For example, 'CONSUMX \"Black Toner Cartridge\" "
echo ' DISPLAY'
echo ''
echo ' DEVICES'
echo ''
echo ' MESSAGES'
echo ''
echo ' MODEL'
echo ''
echo ' PAGECOUNT'
echo ''
echo ' STATUS'
echo ''
echo ' TRAY { <number> | TEST | ALL }'
echo ''
echo 'Examples:'
echo " $APPNAME -H 10.0.1.10 -C public -t \"CONSUM ALL\" -w 25 -c 10 "
echo " $APPNAME -H 10.0.1.10 -C public -t \"CONSUMX Punch Dust Box\" "
echo " $APPNAME -H 10.0.1.10 -C public -t MODEL "
echo " $APPNAME -H 10.0.1.10 -C public -t \"TRAY 2,3\" "
echo " $APPNAME -V"
echo ''
exit $STATE_UNK
## CheckModel function ##
function CheckModel(){
MODEL=`walk_snmp $OID_hrDeviceDescr.1 true`
check_snmp_error "$?" "$MODEL"
SERIAL=`walk_snmp $OID_prtGeneralSerialNumber true`
check_snmp_error "$?" "$SERIAL"
STATE_STRING="$MODEL, Serial # $SERIAL"
return $STATE_OK
## CheckMessages function ##
function CheckMessages(){
MESSAGES=`walk_snmp $OID_prtAlertDescription true`
check_snmp_error "$?" "$MESSAGES"
STATE_STRING="UNKNOWN: Can't determine messages. Device does not support this OID."
STATE=$STATE_UNK
else
MESSAGES=$(echo "$MESSAGES" | tr "\n" "\!")
STATE_STRING="$MESSAGES"
fi
return $STATE
## CheckPageCount function ##
function CheckPageCount(){
PAGE_COUNT=`walk_snmp $OID_prtMarkerLifeCount true`
check_snmp_error "$?" "$PAGE_COUNT"
PERFDATA="'Pages'=$PAGE_COUNT"
PAGE_COUNT=$(echo $PAGE_COUNT | sed -e :x -e 's/\([0-9][0-9]*\)\([0-9][0-9][0-9]\)/\1,\2/' -e 'tx')
STATE_STRING="Pagecount is $PAGE_COUNT."
return $STATE
## CheckDisplay function ##
function CheckDisplay(){
DISPLAY=`walk_snmp $OID_prtConsoleDisplayBufferText true`
check_snmp_error "$?" "$DISPLAY"
STATE_STRING=$(echo "$DISPLAY" | tr "\n" "$SEPARATOR")
return $STATE_OK
else
STATE_STRING="UNKNOWN - printer does not appear to support using this OID."
return $STATE_UNK
fi
## CheckPrinterStatus function ##
function CheckPrinterStatus(){
STATUS_STATE=$STATE_OK
PRINTER_STATUS=`walk_snmp $OID_hrPrinterStatus true`
check_snmp_error "$?" "$PRINTER_STATUS"
1|"other"|"other(1)")
STATE_STRING="CRITICAL: Printer status = $PRINTER_STATUS."
STATUS_STATE=$STATE_CRIT
3|"idle"|"idle(3)")
STATE_STRING="OK: Printer status = $PRINTER_STATUS."
4|"printing"|"printing(4)")
5|"warmup"|"warmup(5)")
STATE_STRING="WARNING: Printer status = $PRINTER_STATUS."
STATUS_STATE=$STATE_WARN
esac
return $STATUS_STATE
## CheckDeviceStatus function ##
function CheckDeviceStatus(){
CURRENT_STATE=$STATE_OK
CURRENT_STATUS=0
DEVICE_STATUS=""
DEVICE_NAME=""
DEVICE_IDS=`walk_snmp $OID_hrDeviceIndex true`
check_snmp_error "$?" "$DEVICE_IDS"
for ID in $DEVICE_IDS
do
DEVICE_NAME=`walk_snmp $OID_hrDeviceDescr.$ID true`
check_snmp_error "$?" "$DEVICE_NAME"
STATE_STRING="$STATE_STRING$DEVICE_NAME status is "
DEVICE_STATUS=`walk_snmp $OID_hrDeviceStatus.$ID true`
check_snmp_error "$?" "$DEVICE_STATUS"
"unknown(1)")
STATE_STRING="$STATE_STRING$DEVICE_STATUS - WARNING!$SEPARATOR"
CURRENT_STATUS=$STATE_WARN
"running(2)")
STATE_STRING="$STATE_STRING$DEVICE_STATUS - OK!$SEPARATOR"
"warning(3)")
"testing(4)")
"down(5)")
STATE_STRING="$STATE_STRING$DEVICE_STATUS - CRITICAL!$SEPARATOR"
CURRENT_STATUS=$STATE_CRIT
esac
if [ "$CURRENT_STATUS" -gt "$CURRENT_STATE" ]; then
CURRENT_STATE="$CURRENT_STATUS"
fi
done
return $CURRENT_STATE
## CheckOneConsumable function ##
# it. #
function CheckOneConsumable () {
CONSUM_STATE=$STATE_OK
CURRENT_CAPACITY=0
MAX_CAPACITY=0
MARKER_NAME=""
MARKER_COLOR=""
MARKER_NAME=`walk_snmp $OID_prtMarkerSuppliesDescription.$1 true`
check_snmp_error "$?" "$MARKER_NAME"
MARKER_NAME=$(echo "$MARKER_NAME" | tr -d ".")
MARKER_COLOR=`walk_snmp $OID_prtMarkerColorantValue.$1 true`
fi
STATE_STRING="UNKNOWN - OID not found! Your printer may not support checking this consumable."
STATE_STRING="$STATE_STRING Use the CONSUM TEST option to determine which consumables may be monitored."
PERFDATA=""
CONSUM_STATE=$STATE_UNK
else
CURRENT_CAPACITY=`walk_snmp $OID_prtMarkerSuppliesLevel.$1 true`
check_snmp_error "$?" "$CURRENT_CAPACITY"
MAX_CAPACITY=`walk_snmp $OID_prtMarkerSuppliesMaxCapacity.$1 true`
check_snmp_error "$?" "$MAX_CAPACITY"
MAX_CAPACITY=0
fi
STATE_STRING="$STATE_STRING$MARKER_NAME is OK!$SEPARATOR"
STATE_STRING="$MARKER_NAME is at WARNING level!$SEPARATOR$STATE_STRING"
if [ "$CONSUM_STATE" -lt 1 ]; then
CONSUM_STATE=$STATE_WARN
fi
STATE_STRING="$MARKER_NAME is at CRITICAL level!$SEPARATOR$STATE_STRING"
CONSUM_STATE=$STATE_CRIT
STATE_STRING="$STATE_STRING$MARKER_NAME is at $CURRENT_CAPACITY% - OK!$SEPARATOR"
else
STATE_STRING="$MARKER_NAME is at $CURRENT_CAPACITY% - WARNING!$SEPARATOR$STATE_STRING"
fi
else
STATE_STRING="$MARKER_NAME is at $CURRENT_CAPACITY% - CRITICAL!$SEPARATOR$STATE_STRING"
fi
fi
fi
esac
PERFDATA="$PERFDATA '$MARKER_NAME'=$CURRENT_CAPACITY;$WARNING;$CRITICAL"
fi
return $CONSUM_STATE
## CheckExactConsumable function ##
# and perf data. #
function CheckExactConsumable(){
CONSUMX_STATE=$STATE_OK
FOUND=false
FOUND_MARKER=0
ALL_MARKERS=`walk_snmp $OID_prtMarkerSuppliesDescription true`
ALL_MARKERS=$(echo "$ALL_MARKERS" | tr -d ".")
check_snmp_error "$?" "$ALL_MARKERS"
COUNT=1
NUM_MARKERS=$(echo "$ALL_MARKERS" | wc -l)
while [[ $COUNT -le $NUM_MARKERS ]]
do
MARKER_NAME=$(echo "$ALL_MARKERS" | awk NR==$COUNT)
FOUND=true
FOUND_MARKER="$COUNT"
fi
COUNT=$[ $COUNT+1 ];
done
if $FOUND; then
X_CURRENT_CAPACITY=`walk_snmp $OID_prtMarkerSuppliesLevel.$FOUND_MARKER true`
check_snmp_error "$?" "$X_CURRENT_CAPACITY"
MAX_CAPACITY=`walk_snmp $OID_prtMarkerSuppliesMaxCapacity.$FOUND_MARKER true`
if [[ "$MAX_CAPACITY" -lt 0 ]]; then
MAX_CAPACITY=0
fi
STATE_STRING="$STATE_STRING$1 is OK!"
STATE_STRING="$1 is at WARNING level!$SEPARATOR$STATE_STRING"
if [[ "$CONSUMX_STATE" -lt 1 ]]; then
CONSUMX_STATE=$STATE_WARN
fi
STATE_STRING="$1 is at CRITICAL level!$SEPARATOR$STATE_STRING"
CONSUMX_STATE=$STATE_CRIT
if [[ "$X_CURRENT_CAPACITY" -gt "$WARNING" ]]; then
STATE_STRING="$STATE_STRING$1 is at $X_CURRENT_CAPACITY% - OK!$SEPARATOR"
else
if [[ "$X_CURRENT_CAPACITY" -le "$WARNING" ]] && [[ "$X_CURRENT_CAPACITY" -gt "$CRITICAL" ]]; then
STATE_STRING="$1 is at $X_CURRENT_CAPACITY% - WARNING!$SEPARATOR$STATE_STRING"
fi
else
if [[ "$X_CURRENT_CAPACITY" -le "$CRITICAL" ]]; then
STATE_STRING="$1 is at $X_CURRENT_CAPACITY% - CRITICAL!$SEPARATOR$STATE_STRING"
fi
fi
fi
esac
PERFDATA="$PERFDATA '$1'=$X_CURRENT_CAPACITY;$WARNING;$CRITICAL"
else
STATE_STRING="UNKNOWN - No match found for '$1'! Use the CONSUM TEST option to determine which consumables may be monitored."
CONSUMX_STATE=$STATE_UNK
fi
return $CONSUMX_STATE
## CheckConsumables function ##
# them all off to CheckOneConsumable #
# and perf data. #
function CheckConsumables(){
CONSUMS_STATE=$STATE_OK
HEX_ID=0
CURRENT_STATUS=0
HEX_MARKER=""
ASCII_MARKER=""
MARKERS_MATCHED=""
case "$1" in
"test"|"TEST") # User passed "TEST" parameter - output what consumables are available
echo "Consumables you may monitor:"
STATE_STRING="$ALL_MARKERS"
CONSUMS_STATE=$STATE_UNK
"all"|"ALL") # User passed ALL parameter - check everything!
#--- We can do this differently with my current "REWRITE"
COUNT=1
while [[ $COUNT -le $NUM_MARKERS ]]; do
CheckOneConsumable $COUNT
CURRENT_STATUS=$?
if [ "$CURRENT_STATUS" -gt "$CONSUMS_STATE" ]; then
CONSUMS_STATE="$CURRENT_STATUS"
fi
done
ALL_MARKERS=`walk_snmp $OID_prtMarkerSuppliesDescription false`
PERFDATA=""
else
for MARKER_ID in $(echo "$MARKERS_MATCHED" | awk -F. '{print $8}' | awk -F= '{print $1}')
do
CheckOneConsumable $MARKER_ID
CURRENT_STATUS=$?
fi
done
fi
esac
return $CONSUMS_STATE
## CheckOneTray Function ##
function CheckOneTray (){
TRAY_STATE=$STATE_OK
TRAY_CAPACITY=0
TRAY_MAX_CAPACITY=0
TRAY_CAPACITY=`walk_snmp $OID_prtInputCurrentLevel.$1 true`
check_snmp_error "$?" "$TRAY_CAPACITY"
STATE_STRING="$STATE_STRING UNKNOWN - Tray $1 not found. Use the TRAY TEST option to determine which trays may be monitored."
TRAY_STATE=$STATE_UNK
else
TRAY_NAME=`walk_snmp $OID_prtInputName.$1 true`
check_snmp_error "$?" "$TRAY_NAME"
TRAY_NAME="Tray $1"
fi
STATE_STRING="$STATE_STRING$TRAY_NAME is OK!$SEPARATOR"
STATE_STRING="$STATE_STRING$TRAY_NAME status is UNKNOWN!$SEPARATOR"
TRAY_FEED_DIMENSION=`walk_snmp $OID_prtInputMediaDimFeedDirDeclared.$1 true`
TRAY_XFEED_DIMENSION=`walk_snmp $OID_prtInputMediaDimXFeedDirDeclared.$1 true`
TRAY_DIMENSION_UNITS=`walk_snmp $OID_prtInputDimUnit.$1 true`
else
esac
fi
STATE_STRING="$STATE_STRING$TRAY_NAME is at CRITICAL level - please refill with more $TRAY_DIMENSION_STRING$SEPARATOR"
TRAY_STATE=$STATE_CRIT
TRAY_MAX_CAPACITY=`walk_snmp $OID_prtInputMaxCapacity.$1 true`
check_snmp_error "$?" "$TRAY_MAX_CAPACITY"
STATE_STRING="$STATE_STRING$TRAY_NAME is at $TRAY_CAPACITY%% - OK!$SEPARATOR"
else
check_snmp_error "$?" "$TRAY_FEED_DIMENSION"
check_snmp_error "$?" "$TRAY_XFEED_DIMENSION"
check_snmp_error "$?" "$TRAY_DIMENSION_UNITS"
else
esac
fi
STATE_STRING="$STATE_STRING$TRAY_NAME is at $TRAY_CAPACITY%% - CRITICAL! Please refill with more $TRAY_DIMENSION_STRING$SEPARATOR"
else
STATE_STRING="$STATE_STRING$TRAY_NAME is at $TRAY_CAPACITY%% - WARNING! Please refill with more $TRAY_DIMENSION_STRING$SEPARATOR"
if [ "$TRAY_STATE" -lt 1 ]; then
TRAY_STATE=$STATE_WARN
fi
fi
fi
fi
PERFDATA="$PERFDATA '$TRAY_NAME'=$TRAY_CAPACITY;$WARNING;$CRITICAL"
esac
fi
return $TRAY_STATE
## CheckPaperTrays Function ##
# off to CheckOneTray. #
# and perf data. #
function CheckPaperTrays (){
TRAYS_STATE=$STATE_OK
ALL_TRAYS=`walk_snmp $OID_prtInputName true`
check_snmp_error "$?" "$ALL_TRAYS"
ALL_TRAYS=$(echo "$ALL_TRAYS" | awk -F" " '{print $2}')
case "$1" in
"test"|"TEST")
echo "$ALL_TRAYS"
TRAYS_STATE=$STATE_UNK
"all"|"ALL") # let's check all trays!
COUNT=1
NUM_TRAYS=$(echo "$ALL_TRAYS" | wc -l)
while [[ $COUNT -le $NUM_TRAYS ]]
do
CheckOneTray "$COUNT"
if [ "$CURRENT_TRAY_STATUS" -gt "$TRAYS_STATE" ]; then
TRAYS_STATE="$CURRENT_TRAY_STATUS"
fi
done
do
CheckOneTray "$TRAY_ID"
fi
done
esac
return $TRAYS_STATE
# Subroutine: walk_snmp #
walk_snmp(){
if [ $2 = true ]; then
OUTPUT_OPTIONS="-Oavq"
else
OUTPUT_OPTIONS="-Oa"
fi
if [[ $SNMPVERSION = 3 ]]; then
RESULT_TEXT=`snmpwalk -v $SNMPVERSION $OUTPUT_OPTIONS -u $SNMPUSER -l $PRIVILEGELEVEL -x $PRIVACYPROTOCOL -X $PRIVACYPASSWORD -a $AUTHPROTOCOL -A $AUTHPASSWORD $HOST_NAME $1`
RESULT_CODE=$?
else
# Check if community was also set
RESULT_TEXT=`snmpwalk -v $SNMPVERSION $OUTPUT_OPTIONS -c $COMMUNITY $HOST_NAME $1`
RESULT_CODE=$?
fi
if [[ $RESULT_CODE -ne 0 ]]; then
echo "Plugin $APPNAME failure - snmpwalk command error."
echo "$RESULT_TEXT"
exit $STATE_UNK
fi
echo "$RESULT_TEXT" | sed -e 's/^[[:space:]]*//' | tr -d "\""
else
echo "$RESULT_TEXT"
fi
# Subroutine: check_snmp_error #
# Tests errors returned by function operations #
check_snmp_error(){
if [[ $1 -ne 0 ]]; then
echo $2
exit $STATE_UNK
fi
## MAIN CODE ##
binaries="snmpwalk cut tr awk sed bc egrep wc"
do
echo "UNKNOWN: $APPNAME: No usable '$required_binary' binary in '$PATH'"
exit $STATE_UNK
fi
done
# Check to see if any parameters were passed
if [[ $# -eq 0 ]]; then
print_usage
exit $STATE_UNK
fi
while test -n "$1"; do
case "$1" in
--host|-H)
HOST_NAME=$2
shift
--community|-C)
COMMUNITY=$2
shift
--snmpversion|-v)
SNMPVERSION=$2
shift
--user|-u)
SNMPUSER=$2
shift
--privelegelevel|-l)
PRIVILEGELEVEL=$2
shift
--authprotocol|-a)
AUTHPROTOCOL=$2
shift
--authpassword|-A)
AUTHPASSWORD=$2
shift
--privacyprotocol|-x)
PRIVACYPROTOCOL=$2
shift
--privacypassword|-X)
PRIVACYPASSWORD=$2
shift
--type|-t) # Assign check to perform
CHECK_TYPE=$(echo "$2" | cut -d " " -f1)
PARAMETER=$(echo "$2" | cut -d " " -f2-)
shift
--separator|-S) # Assign separator
SEPARATOR="$2"
shift
--warning|-w) # Assign WARNING threshold
WARNING=$2
shift
--critical|-c) # Assign CRITICAL threshold
CRITICAL=$2
shift
--help|-h)
print_help
--version|-V)
print_version
exit $STATE
echo "Unknown argument: $1"
print_usage
exit $STATE_UNK
esac
shift
done
if [ ! -z $CHECK_TYPE ]; then
# Determine the check to perform
case "$CHECK_TYPE" in
"model"|"MODEL")
CheckModel
STATE=$?
"messages"|"MESSAGES")
CheckMessages
STATE=$?
"pages"|"PAGES"|"count"|"COUNT"|"pagecount"|"PAGECOUNT")
CheckPageCount
STATE=$?
"display"|"DISPLAY")
CheckDisplay
STATE=$?
"status"|"STATUS")
CheckPrinterStatus
STATE=$?
"devices"|"DEVICES")
CheckDeviceStatus
STATE=$?
"consum"|"CONSUM")
CheckConsumables "$PARAMETER"
STATE=$?
"consumx"|"CONSUMX")
CheckExactConsumable "$PARAMETER"
STATE=$?
"tray"|"TRAY"|"trays"|"TRAYS")
CheckPaperTrays "$PARAMETER"
STATE=$?
STATE_STRING="UNKNOWN: No valid check type specified to -t parameter"
STATE=$STATE_UNK
esac
else
echo "Command incomplete!"
STATE=$STATE_UNK
fi
if [ "$PERFDATA" == "" ]; then
echo "$STATE_STRING"
else
echo "$STATE_STRING|$PERFDATA"
fi
exit $STATE
# NOTE:
I don't know bash well enough to have a fix for you. Nor do we provide this solution on the support forum as it is custom development.
At this point, it's probably best to email the owner and ask if he could rewrite his code to have a flag that passes toner color through the check. That way it doesn't display every color in one line or multiple lines.
