Custom plugin to check Windows
McHenry
Post by McHenry »
Noob.
I am using check_nt commands with nsclient++ on the Windows machines to monitor, CPU, disk & memory. All works well.
I would like to check directories for age, file count etc and have found a plugin that appears to achieve this:
https://exchange.nagios.org/directory/P ... ry/details
I am able to get this plugin working on my local Nagios server, however, would like to have it check a remote Windows server.
Is this possible?
Re: Custom plugin to check Windows
that isn't going to work too well on a windows machine.
We have a document here
https://support.nagios.com/kb/article.php?id=783
Look into the"NSClient++ via check_nrpe" section
you can enable that in your NSClient++ config and run the commands.
ahumandesign.com
enneagrams.com
