Reporting Explorer is not running, when it is.
mhedtcke
Re: Reporting Explorer is not running, when it is.
Post by mhedtcke »
I've replaced the ini file. Restarted the NSClient service.
I've uncommented out the explorer check. Restarted the nagios process.
Here is the command output.
nagios01@nagios01:~$ /usr/local/nagios/libexec/check_nt -H 192.168.39.40 -p 12489 -v PROCSTATE -d SHOWALL -l explorer.exe
explorer.exe: not running
I do not have NPRE in my libexec folder. I am not using as part of the NSClient installer either.
npolovenko
Post by npolovenko »
@mhedtcke, Can you try using the check to see if other known processes are running?
