Plugin check not working
Re: Plugin check not working
Postby npolovenko » Fri Jun 08, 2018 12:01 pm
@kwhogster, Please try with the following definitions:
check_iis_conn = cmd /c echo scripts\\powershell\\check_iis_connections.ps1  $ARG1$ $ARG2$ $ARG3$ $ARG4$;
check_command check_nrpe!check_iis_conn!-a 'TGCS014-N1' 'Default Web Site' '5' '9'
npolovenko
Postby kwhogster » Fri Jun 08, 2018 9:40 pm
check_iis_conn = cmd /c echo scripts\\powershell\\check_iis_connections.ps1 "$ARG1$" "$ARG2$" "$ARG3$" "$ARG4$";
same results
Current Status:
OK
(for 1d 5h 46m 39s)
Status Information: C:Program FilesNSClient++scriptspowershellcheck_iis_connections.ps1 :
Cannot process argument transformation on parameter 'warning_value'. Cannot
convert value "$" to type "System.Int32". Error: "Input string was not in a
correct format."
At line:1 char:66
+ ... ershell\\check_iis_connections.ps1 "$ARG1$" "$ARG2$" "$ARG3$" "$ARG4$ ...
+ CategoryInfo : InvalidData: (:) [check_iis_connections.ps1], Pa
rameterBindingArgumentTransformationException
+ FullyQualifiedErrorId : ParameterArgumentTransformationError,check_iis_c
onnections.ps1
Performance Data:
Current Attempt: 1/10 (HARD state)
Last Check Time: 06-08-2018 21:52:10
Check Type: ACTIVE
Check Latency / Duration: 0.000 / 0.801 seconds
Next Scheduled Check: 06-08-2018 22:52:10
Last State Change: 06-07-2018 16:52:10
Last Notification: N/A (notification 0)
Is This Service Flapping?
NO
(0.00% state change)
In Scheduled Downtime?
NO
Last Update: 06-08-2018 22:38:46 ( 0d 0h 0m 3s ago)
This is so strange this same check work on several other servers just not this one even NODE2 in the cluster the same check works
Thanks for trying willing to try anything here.
OOOPS
Update
Now it went to Unknown
Current Status:
UNKNOWN
(for 0d 0h 12m 57s)
Status Information: Get-Counter : Unable to access the desired computer or service. Check the
permissions and authentication of the log service or the interactive user
session against those on the computer or service being monitored.
At C:\Program Files\NSClient++\scripts\powershell\check_iis_connections.ps1:40
char:12
+ $counter = Get-Counter "\\$server\Web Service($website)\Current Conne ...
+ CategoryInfo : InvalidResult: (:) [Get-Counter], Exception
+ FullyQualifiedErrorId : CounterApiError,Microsoft.PowerShell.Commands.Ge
tCounterCommand
CONNECTIONS UNKNOWN Default Web Site not found
Performance Data:
Current Attempt: 10/10 (HARD state)
Last Check Time: 06-08-2018 23:00:56
Check Type: ACTIVE
Check Latency / Duration: 0.000 / 1.995 seconds
Next Scheduled Check: 06-09-2018 00:00:56
Last State Change: 06-08-2018 22:52:10
NO
(6.25% state change)
NO
Last Update: 06-08-2018 23:05:06 ( 0d 0h 0m 1s ago)
kwhogster
Postby tgriep » Mon Jun 11, 2018 4:50 pm
Try this. In the nsclient.ini file, define the command like this.
check_iis_conn = cmd /c echo scripts\\powershell\\check_iis_connections.ps1 $ARG1$ ; exit($lastexitcode) | powershell.exe -command -
Save the file and restart nsclient++.
This will setup the command to accept all of the arguments from the check_nrpe command as one argument.
Then define the check like this on the Nagios server.
check_command           check_nrpe!check_iis_conn!-a 'TGCS014-N1 "Default Web Site" 5 9'
This will send over all of the separate arguments as one argument.
Restart nagios and test the command.
If you get an error, post the nsclient.ini file and the nsclient.log file from the Windows system as well as the command definition from the Nagios server.
Postby kwhogster » Mon Jun 11, 2018 7:34 pm
nsclient.ini
nsclient
(23.51 KiB) Downloaded 4 times
nsclient.ini
nsclient
        use                     generic-service
        host_name               TGCS014-N1
        service_description     Default Web Site Connections
        check_interval          60
        notification_interval   60
        servicegroups           WEBServices
from the Nagios page
OK 06-11-2018 19:59:23 0d 0h 34m 50s 1/10 C:Program FilesNSClient++scriptspowershellcheck_iis_connections.ps1
HTH
Thanks Tom
nsclient.log
nsclient log
(7.6 KiB) Downloaded 5 times
kwhogster
Postby tgriep » Tue Jun 12, 2018 9:39 am
There are a lot of errors in the nagios.log file so lets clean up the nsclient.ini file.
Edit the file and remove the following lines
LUAScript.dll = enabled
NSCAClient = 1
You should also change the path to the script wrapper for the powershell scripts.
Change the following from
ps1 = cmd /c echo scripts\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
to
ps1 = cmd /c echo scripts\\powershell\\%SCRIPT% %ARGS%; exit($lastexitcode) | powershell.exe -command -
Save the nsclient.ini file and restart the NSClient++ service.
Check the log file for the unknown command errors and if they are not found, test it and post any errors here.
Postby kwhogster » Tue Jun 12, 2018 2:39 pm
Made the changes and the same results does not report back correct information
the logfile was small here it is
2018-05-30 18:26:00: error:c:\source\nscp\modules\NRPEServer\NRPEServer.cpp:132: CA not found: C:\Program Files\NSClient++/security/ca.pem (generating a default CA)
2018-05-30 18:26:00: error:c:\source\nscp\modules\WEBServer\WEBServer.cpp:642: Certificate not found: C:\Program Files\NSClient++/security/certificate.pem (generating a default certificate)
2018-05-30 18:31:00: error:c:\source\nscp\service\NSClient++.cpp:216: Failed to register plugin LUAScript: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
2018-05-30 19:28:55: error:c:\source\nscp\service\NSClient++.cpp:216: Failed to register plugin LUAScript: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
2018-05-30 19:31:19: error:c:\source\nscp\service\NSClient++.cpp:216: Failed to register plugin LUAScript: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
2018-05-30 21:30:27: error:c:\source\nscp\service\NSClient++.cpp:484: Module (LUAScript.dll) was not found: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
2018-05-30 21:31:40: error:c:\source\nscp\service\NSClient++.cpp:427: Failed to load C:\Program Files\NSClient++/modules\LUAScript.dll: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
2018-05-30 21:31:40: error:c:\source\nscp\service\NSClient++.cpp:484: Module (LUAScript.dll) was not found: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
2018-05-31 20:52:10: error:c:\source\nscp\service\NSClient++.cpp:894: Unknown command(s): check_host_cluster available commands: commands {, alias_cpu, alias_cpu_ex, alias_disk, alias_disk_loose, alias_event_log, alias_file_age, alias_file_size, alias_mem, alias_process, alias_process_count, alias_process_hung, alias_process_stopped, alias_sched_all, alias_sched_long, alias_sched_task, alias_service, alias_service_ex, alias_up, alias_volumes, alias_volumes_loose, check_always_critical, check_always_ok, check_always_warning, check_counter, check_cpu, check_critical, check_drivesize, check_eventlog, check_explorer, check_files, check_iis_apppool, check_iis_conn, check_iis_sites, check_memory, check_multi, check_negate, check_nscp, check_ok, check_os_version, check_pagefile, check_pdh, check_process, check_service, check_tasksched, check_timeout, check_updates, check_uptime, check_users, check_version, check_warning, check_winfile, check_winservice, checkalwayscritical, checkalwaysok, checkalwayswarning, checkcounter, checkcpu, checkcritical, checkdrivesize, checkeventlog, checkfiles, checkmem, checkmultiple, checkok, checkprocstate, checkservicestate, checktasksched, checkuptime, checkversion, checkwarning, filter_perf, negate, nsca_submit, pscheckapplicationeventlog, pschecksystemeventlog, render_perf, timeout, xform_perf}, plugins {, 0, 1, 2, 3, 4, 5, 6, 8}
2018-05-31 20:52:10: error:c:\source\nscp\include\nscapi\nscapi_core_wrapper.cpp:159: Failed to execute command
2018-05-31 20:52:10: error:c:\source\nscp\include\nscapi\nscapi_core_helper.cpp:95: Failed to execute command: check_host_cluster
2018-06-01 21:22:21: error:c:\source\nscp\service\NSClient++.cpp:427: Failed to load C:\Program Files\NSClient++/modules\LUAScript.dll: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
2018-06-02 12:32:47: error:c:\source\nscp\service\NSClient++.cpp:427: Failed to load C:\Program Files\NSClient++/modules\LUAScript.dll: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
2018-06-05 20:02:32: error:c:\source\nscp\service\NSClient++.cpp:427: Failed to load C:\Program Files\NSClient++/modules\LUAScript.dll: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
2018-06-06 16:45:17: error:c:\source\nscp\service\NSClient++.cpp:427: Failed to load C:\Program Files\NSClient++/modules\LUAScript.dll: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
2018-06-07 17:15:54: error:c:\source\nscp\service\NSClient++.cpp:427: Failed to load C:\Program Files\NSClient++/modules\LUAScript.dll: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
2018-06-07 23:39:44: error:c:\source\nscp\service\NSClient++.cpp:894: Unknown command(s): check_cluster available commands: commands {, alias_cpu, alias_cpu_ex, alias_disk, alias_disk_loose, alias_event_log, alias_file_age, alias_file_size, alias_mem, alias_process, alias_process_count, alias_process_hung, alias_process_stopped, alias_sched_all, alias_sched_long, alias_sched_task, alias_service, alias_service_ex, alias_up, alias_volumes, alias_volumes_loose, check_always_critical, check_always_ok, check_always_warning, check_counter, check_cpu, check_critical, check_drivesize, check_eventlog, check_explorer, check_files, check_iis_apppool, check_iis_conn, check_iis_sites, check_memory, check_multi, check_negate, check_nscp, check_ok, check_os_version, check_pagefile, check_pdh, check_process, check_service, check_tasksched, check_timeout, check_updates, check_uptime, check_users, check_version, check_warning, check_winfile, check_winservice, checkalwayscritical, checkalwaysok, checkalwayswarning, checkcounter, checkcpu, checkcritical, checkdrivesize, checkeventlog, checkfiles, checkmem, checkmultiple, checkok, checkprocstate, checkservicestate, checktasksched, checkuptime, checkversion, checkwarning, filter_perf, negate, nsca_submit, pscheckapplicationeventlog, pschecksystemeventlog, render_perf, timeout, xform_perf}, plugins {, 0, 1, 2, 3, 4, 5, 6, 9}
2018-06-07 23:39:44: error:c:\source\nscp\include\nscapi\nscapi_core_wrapper.cpp:159: Failed to execute command
2018-06-07 23:39:44: error:c:\source\nscp\include\nscapi\nscapi_core_helper.cpp:95: Failed to execute command: check_cluster
2018-06-07 23:44:29: error:c:\source\nscp\service\NSClient++.cpp:894: Unknown command(s): check_host_cluster available commands: commands {, alias_cpu, alias_cpu_ex, alias_disk, alias_disk_loose, alias_event_log, alias_file_age, alias_file_size, alias_mem, alias_process, alias_process_count, alias_process_hung, alias_process_stopped, alias_sched_all, alias_sched_long, alias_sched_task, alias_service, alias_service_ex, alias_up, alias_volumes, alias_volumes_loose, check_always_critical, check_always_ok, check_always_warning, check_counter, check_cpu, check_critical, check_drivesize, check_eventlog, check_explorer, check_files, check_iis_apppool, check_iis_conn, check_iis_sites, check_memory, check_multi, check_negate, check_nscp, check_ok, check_os_version, check_pagefile, check_pdh, check_process, check_service, check_tasksched, check_timeout, check_updates, check_uptime, check_users, check_version, check_warning, check_winfile, check_winservice, checkalwayscritical, checkalwaysok, checkalwayswarning, checkcounter, checkcpu, checkcritical, checkdrivesize, checkeventlog, checkfiles, checkmem, checkmultiple, checkok, checkprocstate, checkservicestate, checktasksched, checkuptime, checkversion, checkwarning, filter_perf, negate, nsca_submit, pscheckapplicationeventlog, pschecksystemeventlog, render_perf, timeout, xform_perf}, plugins {, 0, 1, 2, 3, 4, 5, 6, 9}
2018-06-07 23:44:29: error:c:\source\nscp\include\nscapi\nscapi_core_wrapper.cpp:159: Failed to execute command
2018-06-07 23:44:29: error:c:\source\nscp\include\nscapi\nscapi_core_helper.cpp:95: Failed to execute command: check_host_cluster
2018-06-11 19:54:11: error:c:\source\nscp\service\NSClient++.cpp:427: Failed to load C:\Program Files\NSClient++/modules\LUAScript.dll: Could not load library: 126: The specified module could not be found.
: LUAScript.dll
Why is that DLL not loading " Failed to register plugin LUAScript"
kwhogster
Postby tgriep » Tue Jun 12, 2018 3:18 pm
You would have to ask the author of the NSClient++ agent on why it is not loading.
On my Windows system, I do not load that DLL and the external and alias commands load and run.
It almost looks like that entry did not get removed or that the agent did not get restarted.
Postby kwhogster » Tue Jun 12, 2018 3:31 pm
I posted this on the nsclinet site and no one responds
This is crazy the same check run on other server no problems
kwhogster
Postby tgriep » Tue Jun 12, 2018 3:39 pm
What versions of NSCLient++ are installed on a working server vs the non working one?
If the versions are close, copy the nsclient.ini file from the working one to the non working one and restart the NSClient++ agent.
Postby kwhogster » Wed Jun 13, 2018 3:33 pm
Update
I believe the problem is the fact that I first had Nsclient 5.144 installed had removed that and reverted back to 4.3
I have to rebuild this server for other reasons.
I will hopefully have results within the next few days.
Thank you.
kwhogster
PreviousNext
Return to Nagios Core
Users browsing this forum: amane and 38 guests
