Hi all,
This is my first post, I'm new to nagios.
I'm installing Nagios in a Linux Mint 18.3 environment and when I try to install webconf the installer sends an Error 1
make install-webconf
/usr/bin/install -c -m 644 sample-config/httpd.conf etc/apache2/sites-enabled/nagios.conf
/usr/bin/install: no se puede crear el fichero regular 'etc/apache2/sites-enabled/nagios.conf': No existe el archivo o el directorio
Makefile:298: fallo en las instrucciones para el objetivo 'install-webconf'
make: *** [install-webconf] Error 1
Translation of spanish lines:
/usr/bin/install: regular file cannot be created 'etc/apache2/sites-enabled/nagios.conf': File or directory doesn't exist
Makefile:298: failure in the instructions for objective 'install-webconf'
The directory does exist but not the file, Any suggestion to find or generate the file is welcome
Thanks in advance
Error 1 when make install-webconf
Re: Error 1 when make install-webconf
Are you following any particular documentation for your Nagios Core installation? It looks as if some prefixes may have been entered incorrectly during the configure step and the leading / has been stripped from the destination path.
Are you running your make commands as root? Per the official documentation, Debian-based systems need to have root handle the Nagios Core installation. Though Mint isn't a direct fork of Debian, I'd suggest using root.
Can you share the outputs of the following commands executed from the CLI of your Mint machine:
My initial hunch is it's just a permissions issue on the /etc/apache2/sites-enabled path.
cat /etc/apache2/apache2.conf
ls -al /etc/apache2
- Support Tech
Thanks for the recommendations, @mcapra. @smendoza, Let us know if that helps and also the tutorial you used to install the Core?
