I configured SSMTP to send emails, from the terminal I'm not having problems but sending email alerts for Nagios is not working.
I attach you the 2 commands that I have for send emails on commands.cfg
command_name notify-host-by-email
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\nHost: $HOSTNAME$\nState: $HOSTSTATE$\nAddress: $HOSTADDRESS$\nInfo: $HOSTOUTPUT$\n\nDate/Time: $LONGDATETIME$\n" | /usr/bin/mail -s "** $NOTIFICATIONTYPE$ Host Alert: $HOSTNAME$ is $HOSTSTATE$ **" $CONTACTEMAIL$
command_line /usr/bin/printf "%b" "***** Nagios *****\n\nNotification Type: $NOTIFICATIONTYPE$\n\nService: $SERVICEDESC$\nHost: $HOSTALIAS$\nAddress: $HOSTADDRESS$\nState: $SERVICESTATE$\n\nDate/Time: $LONGDATETIME$\n\nAdditional Info:\n\n$SERVICEOUTPUT$\n" | /usr/bin/mail -s "** $NOTIFICATIONTYPE$ Service Alert: $HOSTALIAS$/$SERVICEDESC$ is $SERVICESTATE$ **" $CONTACTEMAIL$
This what I have from \var/log/mail.log
Jun 19 23:14:52 sdnagios01 sSMTP[2117]: Creating SSL connection to host
Jun 19 23:14:52 sdnagios01 sSMTP[2117]: SSL connection using RSA_AES_128_CBC_SHA1
Jun 19 23:14:55 sdnagios01 sSMTP[2117]: Sent mail for root@sdnagios01 (221 2.0.0 closing connection k36-v6sm1278389wrc.20 - gsmtp) uid=0 username=root outbytes=541
Jun 19 23:15:15 sdnagios01 sSMTP[2129]: Creating SSL connection to host
Jun 19 23:15:15 sdnagios01 sSMTP[2129]: SSL connection using RSA_AES_128_CBC_SHA1
Jun 19 23:15:17 sdnagios01 sSMTP[2129]: Sent mail for root@sdnagios01 (221 2.0.0 closing connection n7-v6sm711134wrr.39 - gsmtp) uid=0 username=root outbytes=541
On contacts.cfg I have the following
define contact{
contact_name nagiosadmin ; Short name of user
use generic-contact ; Inherit default values from generic-contact template (defined above)
alias Nagios Admin ; Full name of user
email myemail@gmail.com ; <<***** CHANGE THIS TO YOUR EMAIL ADDRESS ******
I don't know whatelse to check, any idea?
Thanks in advance for helping me
Best regards
Can't get email notifications with SSMTP
Re: Can't get email notifications with SSMTP
How did you configure you mail sending program?
What OS is this? What mail program is this?
You are sending mail as root@sdnagios01 which is likely not going to be accepted from remote SMTP server as there is no route back because the domain is invalid
Hello, finally I got this working.
Many thanks for the reply!!
Glad to hear its working
Locking
Locking
