Hello team,
I have created a simple powershell script to test mirroring status, it works as expected from the powershell prompt. I have created a service in nagios for that and it always shows OK, with the output "no output available from command(check_mirroring_status)"
My code returns db name along with status and exit code when i run in the server. Please help
I have installed nsclient 0.5.62 version
Regards,
sannatar
Powershell script->no output returned from the command
- Support Tech
Re: Powershell script->no output returned from the command
Hello, @sannatar16. Are you using the NSClient to run this PowerShell script? Can you show me the command definition on the Nagios server as well as in the NSclient.ini file.
Hi Please find the details. I have only one db mirrored so I have hard-coded that in the script itself. So i have no arguments to be passed
Service definition:
host_name xxxxxxxxx
service_description mirroring_status
check_command check_mssql_mirroring_status
initial_state u
max_check_attempts 1
check_interval 1
retry_interval 1
check_period 24x7
notification_period 24x7
notification_options w,c,r,
register 1
Command definition:
command_name check_mssql_mirroring_status
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -p 5666 -c check_mirroring_status
NSclient.ini entry in external scripts:
check_mirroring_status = cmd /c echo scripts\\mirroring.ps1;exit($lastexitcode) | powershell.exe -command -
Service definition:
host_name xxxxxxxxx
initial_state u
check_interval 1
retry_interval 1
check_period 24x7
register 1
Command definition:
- Support Tech
@sannatar16. Thank you. Could you upload the script and the nsclinet.ini file here as well?
