[NAGIOS] error NRPE: Unable to read output
seddikalaouiismaili
Post by seddikalaouiismaili »
Hi team
I have nagios server installed on linux server (centos 6) , and all communications with nrpe clients are done .
To monitor free memory usage of (RAM),I created script perl to do this .
You can see below the result of script's execution
bash-4.1# ./check_mem -f -w 20 -c 10
CRITICAL - 9.7% (183684 kB) free!|TOTAL=1902800KB;;;; USED=1719116KB;1522240;1712520;; FREE=183684KB;;;; CACHES=458376KB;;;;
Note that the configuration on server and client is :
==> Nagios_server
on commands.cfg
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -u -c $ARG1$
on service.cfg
host_name XXXXXXX
service_description Free Memory
check_command check_nrpe!check_mem
==> Nrpe client
command[check_mem]=/usr/lib64/nagios/plugins/check_mem -f -w 20 -c 10
Problem : when it's ececuted remotly i got this error (its tha same on web interface and CLI ):
Normally the nagios server know how to execute the check remotly and configuration semms correct .
Thank you in advance
Best Regards
Seddik Alaoui
bolson
Re: [NAGIOS] error NRPE: Unable to read output
Post by bolson »
If you run:
/usr/local/nagios/libexec/check_nrpe -H <host_ip>
By itself and it returns the version of NRPE, but the command returns "Unable to read output", the issue is likely in the script itself. Not knowing the contents of the script, it's difficult to diagnose your issue. If you run one of the standard built in plugins via check_nrpe, do you get data back?
