Hey Guys, been awhile.
Using Nagios Core - 4.4.2 + https://github.com/zorkian/nagios-api
Works very well, am i suppose to be able to view the schl'ed downtime in host view? I thought i would
also no place for us to cancel it via gui/web view?
I tried to cancel the downtime via the api and it doesn't seem to work? doesnt show it in the Even log or the log files (which are the same of course)
any tips?
even under schled downtime tab all i see is
"There are no hosts with scheduled downtime"
Edit* even weirder, i restarted nagios for sh*ts and giggles, and ALL the schl'ed downtimes appeared! then the cmd to delete also worked. thinking OK now its working. tried to schl it again and it doesnt show up until i reboot. wth!?
Cancel Sch'led Downtime
Re: Cancel Sch'led Downtime
You may need to check permissions on your status.dat file. something doesn't seem correct.
