CHECK_NRPE: Error
Re: CHECK_NRPE: Error
Postby BrunoLosse1 » Wed Nov 07, 2018 11:19 am
When I run sudo systemctl status nrpe I get the following response:
root@GEUL3BNAGPAS01:/usr/local/nagios/etc/objects# sudo systemctl status nrpe
● nrpe.service - Nagios Remote Plugin Executor
Loaded: loaded (/lib/systemd/system/nrpe.service; enabled; vendor preset: enabled)
Active: active (running) since Seg 2018-11-05 12:10:43 -02; 2 days ago
Docs: http://www.nagios.org/documentation
Main PID: 20745 (nrpe)
Tasks: 1
Memory: 740.0K
CPU: 32ms
CGroup: /system.slice/nrpe.service
└─20745 /usr/local/nagios/bin/nrpe -c /usr/local/nagios/etc/nrpe.cfg -f
Nov 05 12:10:43 GEUL3BNAGPAS01 systemd[1]: Started Nagios Remote Plugin Executor.
Nov 05 12:10:43 GEUL3BNAGPAS01 nrpe[20745]: Starting up daemon
Nov 05 12:10:43 GEUL3BNAGPAS01 nrpe[20745]: Server listening on 0.0.0.0 port 5666.
Nov 05 12:10:43 GEUL3BNAGPAS01 nrpe[20745]: Server listening on :: port 5666.
Nov 05 12:10:43 GEUL3BNAGPAS01 nrpe[20745]: Listening for connections on port 5666
Nov 05 12:10:43 GEUL3BNAGPAS01 nrpe[20745]: Allowing connections from: 127.0.0.1,::1
Nov 06 14:22:39 GEUL3BNAGPAS01 nrpe[48592]: Host 10.63.248.131 is not allowed to talk to us!
Nov 07 10:28:28 GEUL3BNAGPAS01 nrpe[17313]: Host 10.63.248.131 is not allowed to talk to us!
BrunoLosse1
Postby benjaminsmith » Wed Nov 07, 2018 1:04 pm
Hi @BrunoLosse1,
We reviewed your files, and I have a few suggestions along a few questions.
1. Looks like your getting connection attempts from 10.63.24.130. What's running at this address?
2. You've got schedule jobs enabled. Is this intended? You can set Scheduler = 0 or I have attached another nsclient.ini file with the minimal settings that you can use.
3. Your file age checks such as ( check_nt! FILEAGE -l "d:\\Interfaces\SANTANDER\OUTBOX\GE200492\*.rem"! -w 600 -c 1800) are not working correctly. We tested the command here and it does work, so check your file path or permissions settings on the Window hosts. Also, this command does not support * in the file paths.
Let me know if you get it resolved.
nsclient.ini
(903 Bytes) Downloaded 83 times
benjaminsmith
Postby BrunoLosse1 » Thu Nov 08, 2018 6:45 am
Where did you get that? There's nothing with this IP.
I'm not sure I know what that means.
The path is correct, but there are no files there. Maybe that's the problem.
Is there a way to specify that I need any file with .rem extension? Can I do it using NRPE?
BrunoLosse1
Postby BrunoLosse1 » Thu Nov 08, 2018 7:38 am
I've created a .txt file to test the command and it works fine with *
I still have two problems, the one I posted here viewtopic.php?f=7&t=50931 and the fact that the command returns error if the folder is empty.
BrunoLosse1
Postby benjaminsmith » Thu Nov 08, 2018 12:22 pm
As far the IP address, my apologies, as I entered the wrong address. I was looking at your log file and noticed this entry?: Rejected connection from: 10.63.225.130.
Another option is to use check_nrpe which will support more options. Please refer to the "NSClient++ via check_nrpe" section of the following document for example checks:
File And Folder ChecksFile And Folder Checks
https://support.nagios.com/kb/article/file-and-folder-checks-783.html
benjaminsmith
Postby BrunoLosse1 » Thu Nov 08, 2018 1:32 pm
benjaminsmith wrote:Hello,
This is The IP of the old Nagios Server I was testing.
As far as the Nrpe, I can't get it to work for some reason...
BrunoLosse1
Postby benjaminsmith » Thu Nov 08, 2018 3:31 pm
Ok. That make sense.
When you run check_nrpe, what kind of error are you getting?
cd /usr/local/nagios/libexec
./check_nrpe -H <host ip adddress>
benjaminsmith
Postby BrunoLosse1 » Thu Nov 08, 2018 5:18 pm
benjaminsmith wrote:Ok. That make sense.
I get the following error: CHECK_NRPE: (ssl_err != 5) Error - Could not complete SSL handshake with
BrunoLosse1
Postby npolovenko » Thu Nov 08, 2018 5:52 pm
@BrunoLosse1, Please replace your nsclient.ini file with the one I attached to this post. Then restart the nsclient service on your windows server. And execute this command from the nagios server:
Where <host ip adddress> is the windows server IP address.
nsclient.ini
(23.17 KiB) Downloaded 87 times
npolovenko
Postby BrunoLosse1 » Fri Nov 09, 2018 6:42 am
Same error.
This is what I could see at the log that may help:
2018-11-09 09:19:31: debug:c:\source\master\include\nrpe/server/protocol.hpp:92: Accepting connection from: 10.63.248.131, count=1
2018-11-09 09:19:31: error:c:\source\master\include\socket/connection.hpp:276: Failed to establish secure connection: sslv3 alert handshake failure: 1040
2018-11-09 09:19:45: debug:c:\source\master\include\nrpe/server/protocol.hpp:92: Accepting connection from: 10.63.248.131, count=1
2018-11-09 09:19:45: error:c:\source\master\include\socket/connection.hpp:276: Failed to establish secure connection: sslv3 alert handshake failure: 1040
BrunoLosse1
PreviousNext
Return to Nagios Core
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
