merry xmas !!
I've to check an https site
https check
./check_http -H www.mysite.it -f follow -S
HTTP OK: HTTP/1.1 200 OK - 183891 bytes in 0,079 second response time |time=0,078572s;;;0,000000 size=183891B;;;0
in Nagios check...
use generic-service ; Name of service template to use
host_name www.mysite.it
service_description Https
check_command check_http!-f follow -S
the replay is..
HTTP WARNING: HTTP/1.1 404 Not Found - 492 bytes in 0,020 second response time
the commandi is...
# 'check_http' command definition
command_name check_http
command_line $USER1$/check_http -I $HOSTADDRESS$ $ARG1$
check_http It seems easy but ...
Re: check_http It seems easy but ...
Hello @nlabardi,
Thank you. Happy Holidays!
Since you are passing the hostname, please try changing the -I to -H in the check command definition:
Let me know if that resolve the issue.
command_line $USER1$/check_http -H $HOSTADDRESS$ $ARG1$
It might also be worthwhile to review the parent host definition (for www.mysite.it) and make sure address and host_name are the same, in this case.
@nlabardi, let us know if @benjaminsmith and @mcapra answered your question.
so..
I've fixed the command in ...
the host name and ip address are consistent with how they should be
use cloud-server ; Inherit default values from a template
host_name http://www.mysite.it ; The name we're giving to this host
alias mysite.it SITO ; A longer name associated with the host
address xxx.yyy.xxx.yyy ; IP address of the host
ping http://www.mysite.it
replay from xxx.yyy.xxx.yyy
ping mysite.it
am I ignoring something?
(I use -f follow)
ping mysite.it
(I use -f follow)
- Support Tech
@nlabardi, Please change $HOSTADDRESS$ to $HOSTNAME$ in your command.
OR change the address to http://www.mysite.it in the host definition:command_line $USER1$/check_http -H $HOSTADDRESS$ $ARG1$
address http://www.mysite.it
Bingo!
it's work fine !
thank you and merry new year
it's work fine !
- Support Tech
@nlabardi, Happy new year!
Closing the thread as resolved.
