Hello
I have system, where I have Unix servers (5 together). I would like to have the nagios installed to one of the servers (to get started with) and monitor the disk space, used device sizes (it is a database) etc. I am not sure which Nagios to install? Nagios blugins? I tried to install the Plugins and when I try to execute ./configure, I get the following errors:
bash-3.00# ./configure
checking for a BSD-compatible install... build-aux/install-sh -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... build-aux/install-sh -c -d
checking for gawk... no
checking for mawk... no
checking for nawk... nawk
checking whether make sets $(MAKE)... no
checking build system type... sparc-sun-solaris2.10
checking host system type... sparc-sun-solaris2.10
checking for gcc... no
checking for cc... no
checking for cl.exe... no
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
I have missing env variables and C compiler? Or what...?
Thanks!
Nappi
What version of Nagios to Install
Re: What version of Nagios to Install
Probably want to start here.
http://nagios.sourceforge.net/docs/3_0/toc.html
If you have issues after that, post them to this forum, you'll get a lot more help with any issues you encounter.
http://support.nagios.com/forum/viewforum.php?f=7
Greetings,
Install the following version:Nagios® Core™
Version 3.2.3
October 03, 2010
Version 3.2.3
October 03, 2010
The latest version of Nagios Core, and the Nagios plugins can be obtained from http://www.nagios.org. The current latest version of Nagios is 3.4.1
