perl plugins fail - can't proper install perl-nagios-plugin
gmills
Post by gmills »
I want to use the mysql_health_check.pl
however, it fails because it cannot locate
./mysql_health_check.pl
Can't locate Nagios/Plugin.pm in @INC (@INC contains: /usr/local/lib64/perl5 /usr/local/share/perl5 /usr/lib64/perl5/vendor_perl /usr/share/perl5/vendor_perl /usr/lib64/perl5 /usr/share/perl5 .) at ./mysql_health_check.pl line 37.
BEGIN failed--compilation aborted at ./mysql_health_check.pl line 37.
the plugin doesn't seem to be able to install properly due to missing dependencies
yum -y install perl-Nagios-Plugin
Loaded plugins: changelog, fastestmirror, fs-snapshot, security, ulninfo, verify
Setting up Install Process
Loading mirror speeds from cached hostfile
* epel: fedora-epel.mirror.lstn.net
* epel_6_x86_64: tnlp010001.tsg.ge.com
* ol6_x86_64_UEKR3_latest: tnlp010001.tsg.ge.com
* ol6_x86_64_UEKR4: tnlp010001.tsg.ge.com
* ol6_x86_64_UEK_latest: tnlp010001.tsg.ge.com
* ol6_x86_64_addons: tnlp010001.tsg.ge.com
* ol6_x86_64_latest: tnlp010001.tsg.ge.com
Resolving Dependencies
--> Running transaction check
---> Package perl-Nagios-Plugin.noarch 0:0.36-7.el7 will be installed
--> Processing Dependency: perl(:MODULE_COMPAT_5.16.3) for package: perl-Nagios-Plugin-0.36-7.el7.noarch
--> Processing Dependency: perl(Class::Accessor) for package: perl-Nagios-Plugin-0.36-7.el7.noarch
--> Processing Dependency: perl(Class::Accessor::Fast) for package: perl-Nagios-Plugin-0.36-7.el7.noarch
--> Processing Dependency: perl(Config::Tiny) for package: perl-Nagios-Plugin-0.36-7.el7.noarch
--> Processing Dependency: perl(Math::Calc::Units) for package: perl-Nagios-Plugin-0.36-7.el7.noarch
--> Processing Dependency: perl(Params::Validate) for package: perl-Nagios-Plugin-0.36-7.el7.noarch
---> Package perl-Class-Accessor.noarch 0:0.34-12.el7 will be installed
--> Processing Dependency: perl(:MODULE_COMPAT_5.16.3) for package: perl-Class-Accessor-0.34-12.el7.noarch
---> Package perl-Config-Tiny.noarch 0:2.12-7.1.el6 will be installed
---> Package perl-Math-Calc-Units.noarch 0:1.07-9.el7 will be installed
--> Processing Dependency: perl(:MODULE_COMPAT_5.16.3) for package: perl-Math-Calc-Units-1.07-9.el7.noarch
---> Package perl-Params-Validate.x86_64 0:0.92-3.el6 will be installed
Error: Package: perl-Class-Accessor-0.34-12.el7.noarch (epel)
Requires: perl(:MODULE_COMPAT_5.16.3)
Error: Package: perl-Nagios-Plugin-0.36-7.el7.noarch (epel)
Error: Package: perl-Math-Calc-Units-1.07-9.el7.noarch (epel)
You could try using --skip-broken to work around the problem
You could try running: rpm -Va --nofiles --nodigest
It appears that using CPAN I was able to install the Nagios plugin but not the perl-Nagios-Plugin but the
cpan Nagios::Monitoring::Plugin
Reading '/root/.cpan/Metadata'
Database was generated on Tue, 18 Jun 2019 17:17:03 GMT
Nagios::Monitoring::Plugin is up to date (0.51).
then running
When I try to find it on the system
find / -name Plugins.pm
nothing is found ???
Re: perl plugins fail - can't proper install perl-nagios-plu
You need to modify the plugin by running the following
sed -i 's/Nagios::Plugin/Nagios::Monitoring::Plugin/g' mysql_health_check.pl
ahumandesign.com
enneagrams.com
gmills
Post by gmills »
thank you!!!
geese, yeah, boy, I should have caught that. thank you so much!
This worked! Please close this ticket as RESOLVED
kind regards,
Gary Mills
gmills wrote:thank you!!!
kind regards,
Gary Mills
Great!
Locking thread
ahumandesign.com
enneagrams.com
