having trouble using strings on return
gmills
Re: having trouble using strings on return
Post by gmills »
Nagios Screen Shot
Nagios UI Pic
Nagios UI Pic
Hmm, can you try wrapping the user macro in double quotes in the service definition to see if this is going to fix the issue?
        host_name                       alphprdfuse1i
        service_description             Container Delta FADEC Broker Health
        check_command                   check_nrpe!check_remote_container_broker_health!-a '--user deltafadec --password B@dM0nk3y --url http://localhost:9093/jolokia --mbean org.apache.activemq:type=Broker,brokerName=amq,service=Health --attribute CurrentStatus --string --critical "$USER3$"'
gmills
Post by gmills »
Hi lmiltchev
I've attached the screen shot. thanks again
Have you tried wrapping the user macro in double quotes?
gmills
Post by gmills »
actually yes, I tried double and single quotes :)
NRPE is still seeing the splat ! as a field delimiter ????
How is "check_remote_container_broker_health" defined on the remote box?
gmills
Post by gmills »
command[check_remote_container_broker_health]=/usr/local/nagios/libexec/check_jmx4perl $ARG1$ $ARG2$
[1563223708] Running command: /usr/local/nagios/libexec/check_jmx4perl --user deltamro --password F@c3B00k --url http://localhost:9092/jolokia --mbean org.apache.activemq:type=Broker,brokerName=amq,service=Health --attribute CurrentStatus --string --critical 'Good'
[1563223708] Command completed with return code 2 and output: CRITICAL - [org.apache.activemq:type=Broker,brokerName=amq,service=Health,CurrentStatus] : 'Good' matches threshold 'Good'
[1563223708] Return Code: 2, Output: CRITICAL - [org.apache.activemq:type=Broker,brokerName=amq,service=Health,CurrentStatus] : 'Good' matches threshold 'Good'
Question, does the NRPE system need to be compiled or built with some option to allow this to take place?
OK, try this:
1. Modify your command to look like this:
command[check_remote_container_broker_health]=/usr/local/nagios/libexec/check_jmx4perl $ARG1$ '!$ARG2$'
Save, exit, and restart NRPE (or xinetd, depending on how you are running NRPE) so that changes can take effect.
2. In your service, pass everything in $ARG1$, but "Good". Pass "Good" in $ARG2$. Don't pass "!Good" - the "!" is already in $ARG2$ on the remote box.
This *should* work, at least it worked for us in-house.
gmills
Post by gmills »
well, I be.. that worked. tricks of the trade, still leaning. thank you so much!!!
        command_name    check_remote_container_broker_health
        command_line    $USER1$/check_jmx4perl $ARG1$ $ARG2$
        check_command                   check_nrpe!check_remote_container_broker_health!-a "--user deltafadec --password B@dM0nk3y --url http://localhost:9093/jolokia --mbean org.apache.activemq:type=Broker,brokerName=amq,service=Health --attribute CurrentStatus --string --critical" "Good"
NRPE Server
I am glad I was able to help! :)
I am closing this topic now. If you have any further questions, please start a new thread.
